Offline grnwtrs
#1 Posted : 21 August 2014 17:27:11(UTC)
grnwtrs
I recently ordered some plugs for my test stand. I couldn't find any red ones
quickly, and as I was ordering a lot of stuff of Marklin's, I thought I may as well
order some more plugs, etc.
As it turned out, I ordered the wrong ones.!! I didn't realize this at first, but when
I tried to insert the plug in the roller test stand, it would not fit!!
I pulled out the other brown plugs, and compared them to my new red plug.
Nope they were not the same. Now what? Confused
Checked the Marklin site and the description for "both series" of plugs is the same!!
See for example 71415 versus 71422
So now I have a bunch of useless plugs, or can someone tell me what these 7142
series plug can be used on/with/for? Mad
Thanks in advance.,
gene
#2 Posted : 21 August 2014 18:00:21(UTC)
71422 are sockets, 71415 are plugs. A plug and a socket should fit together.
Offline Renato
#3 Posted : 21 August 2014 18:27:27(UTC)
Renato
71415 = plugs = stecker
71422 = sockets = muffen
Automatic translator at your service. BigGrin
Renato
thanks 1 user liked this useful post by Renato
Offline waorb
#4 Posted : 22 August 2014 15:21:29(UTC)
waorb
Brazil
71415 = plugs = stecker = male
71422 = sockets = muffen = female
Let me add my two cents... RollEyes
Walter
#5 Posted : 22 August 2014 18:53:40(UTC)
Gene over the years and I think the new plugs have been introduced when they've changed the K 83, K 84 decoders from old to new. what used to be the old plugs for years and years are no longer compatible with the new plugs, the may look similar but you will see by closer inspection the plug itself is thinner and connecting both is also slightly different, they fit into a mould.
the same happen to me before I've realized what was going on. you will find the old plugs and sockets are still available on ebay
regards.,
Offline grnwtrs
#6 Posted : 22 August 2014 21:36:39(UTC)
grnwtrs
Hey guys
Thank you all for straightening me out. I was hung up on the outward appearance.Confused
I had expected the plugs not to be so similar in appearance to the sockets.
I guess I got hung up on "what used to be" I was aware of the design change, but never
have had a instance to have to hook them up together. Consequently never paid attention.
Details get you every time!
Again thanks,
geneBlushing
P S I guess I better match up (even up) the quantities of each
This page was generated in 0.304 seconds.
