#1 Posted : 11 August 2014 16:53:45(UTC)
Hi everyone,
I received a 34231 Wismar railbus I bought second hand and it did not bring the manual. I've looked in Marklin's database and it does not list a manual for this unit.
If you have a scan of it could you please post it or send it to me?
Thanks in advance,
Offline franciscohg
#2 Posted : 11 August 2014 17:56:41(UTC)
franciscohg
Chile
Must be somewhere, will check when i get home later
#3 Posted : 11 August 2014 17:58:44(UTC)
Thanks Francisco. Would be very grateful!
Offline franciscohg
#4 Posted : 11 August 2014 19:43:48(UTC)
franciscohg
Chile
Ok Ray, found it at first attempt! What is much to say due to my messy house... 😜
Will scan and send it to you in the afternoon.
Lunch time here!
thanks 3 users liked this useful post by franciscohg
#5 Posted : 11 August 2014 20:00:33(UTC)
Lunch time here!
ThumpUp Brilliant! Thanks!
Offline franciscohg
#6 Posted : 12 August 2014 03:01:38(UTC)
franciscohg
Chile
Well, here it is, those nice old printings, REALLY miss them....
File Attachment(s):
34231.pdf (10,055kb) downloaded 123 time(s).
#7 Posted : 12 August 2014 07:35:03(UTC)
Thanks Francisco! I really appreciate your going to all this trouble.
The railbus came set for analogue operation, so I need to open it up and change the settings to Delta/Digital. I wasn't sure how to get the body off and I was scared I would break something if I tried to force it.
Update:
I had a go before work and managed to get the body off. I won't try that again in a hurry! It's one of these where you have to gently pry the sides apart and then the chassis falls away (in theory!). Unfortunately it took rather more force than I liked!
Anyway, to cut a long story short I managed to get the body off eventually and change the DIP switches to a Delta address. I chose 60 as that is the address pre-stored in the MS2 for this model.
I gave it a quick run on the layout just to make sure it worked in digital. I had already tested it in analogue. The little railbus ran well, for a Delta, if not terribly fast, but this is probably prototypical anyway.
This evening I will give it a quick service and run it for a while. If I have time I'll take a couple of photos.
Offline franciscohg
#8 Posted : 12 August 2014 17:04:50(UTC)
franciscohg
Chile
You are welcome Ray!
Glad to be of any help!
This page was generated in 0.436 seconds.
