Offline Moritz-BR365
#1 Posted : 06 August 2014 13:49:39(UTC)
Moritz-BR365
I wanted to use a function decoder to switch the low beam, rear lights and interior lighting with a function decoder. Furthermore, the DBbzf 761 has high beams. Therefore, I finally bought a replacement of the LED board, which comes with warm-white LEDs and high beam LEDS, too.
LED board WBP-DOSTO from HGH
-- warm white low beam
-- warm white high beam
-- red rear light
Function decoder
- Uhlenbrockdecoder 76 900
The Uhlenbrock 76 900 is a good choice, because it can be buffered with a capacitor:
The Bi-level Cab Control Car is ready for current-conducting couplings. Therefore, the standard Bi-level Cars will be provided with current for the interior lighting from the Cab Control car. I decided to use a relais to switch rail current to the current-conducting couplings. Here, You see the full circuit:
As You can see, I switch the destination display together with the interior lighting. This is in my oppinion the best solution. The head lights must be switchable without interior lighting, too. Alternatively, You should use a function decoder with 5 AUX ports.
Here, You see the full circuit together with a trailing wagon (click to enlarge):
Final view:
Video:
thanks 4 users liked this useful post by Moritz-BR365
Offline Renato
#2 Posted : 06 August 2014 16:11:53(UTC)
Renato
Hi Moritz,
Nice job and well done !
Renato
thanks 1 user liked this useful post by Renato
This page was generated in 0.330 seconds.
