#1 Posted : 25 July 2014 04:36:25(UTC)
Video is at: http://cabinlayout.mixmo...idden-station-automation
The accelerations inside te hidden areas is not done prototypically, since speed is the essence in those areas.
The hidden station is not yet hidden, except at one end.
Edited by user 12 August 2014 16:56:35(UTC)  | Reason: Corrected spelling in heading
thanks 9 users liked this useful post by DaleSchultz
#2 Posted : 25 July 2014 09:15:03(UTC)
Very good, Dale!
I've seen this done electromechanically, but it's nice to see it done with software.
Offline Renato
#3 Posted : 25 July 2014 11:41:08(UTC)
Renato
Hi Dale,
Fantastic !
What did you use to acknowledge the train presence ?
Renato
Offline French_Fabrice
#4 Posted : 29 July 2014 16:56:34(UTC)
French_Fabrice
Hi Dale,
Really nice !ThumpUp
May I ask you which software you use ?
And how many blocks did you use on the long straight line (I'd guess 2 or probably three, or some special feature like "staging block" ?)
Fabrice
#5 Posted : 12 August 2014 16:44:55(UTC)
Originally Posted by: Renato Go to Quoted Post
Hi Dale,
Fantastic !
Renato
I use s88 detection points to track train movements.
#6 Posted : 12 August 2014 16:54:40(UTC)
Hi Dale,
Fabrice
Hi Fabrice,
I use my own software that I wrote.
6 of the tracks have 3 'blocks' each and the 2 longest tracks (in each direction) have 2 'blocks'
With my system a train does not have to fit inside a block. It can occupy more than one, thus the train with 3 'block' could be occupied by one very long train or one lone and one short or three 'short' ones. (short = about 2m)
Each 'block' uses 3 detection points:
1. entry into block (= exit from previous)
2. slow to creep speed
3. Stop/exit (= entry of next one)
thus a long track to hold three trains has the following seven s88 detection points:
>=a=========b===c===========d===e===========f===g=
if a train has to stop at 'g', it travels at a high speed until 'f' then it creeps along to 'g' and stops.
if a train has to stop at 'e', it travels at a high speed until 'd' then it creeps along to 'e' and stops.
if a train has to stop at 'c', it travels at a high speed until 'b' then it creeps along to 'c' and stops.
I d not use braking sections nor train Id feedback systems. They are unnecessary. I just track where each train is and monitor the s88 feedback.
This page was generated in 0.332 seconds.
