Offline jlopez
#1 Posted : 19 July 2014 06:46:55(UTC)
jlopez
Hi all wasn't even thinking and used a metal clip to uncouple the cars from the locomotive. I saw a spark, then the car lights went out. All other functions work. Except the car interior lighting. I reset the locomotive and the the cs2. Did I just fry the lights or the function in the chip controlling them.
Offline jlopez
#2 Posted : 19 July 2014 07:05:16(UTC)
jlopez
Well I was able to test the lights using another coach, they work. So I am assuming I did something to the coupler off the engine or the decoder itself. Any help would be greatly appreciated.
#3 Posted : 19 July 2014 07:35:46(UTC)
when you say the lights are working, did you use another loco/decoder ? and if so you could test the decoder you think is faulty by using either a led (make sure if the connection has a resistor on the decoder or are the resistors on the light strip either way but most probably you contacted the coupler with earth and common plus and there fore ruined the light function.
if its a sound decoder I wouldn't throw it away or get it fixed unless you know how much it costs but rather get a function decoder and this will replace the interior lighting outlet.
Offline jlopez
#4 Posted : 19 July 2014 07:53:18(UTC)
jlopez
I tested it with another coach that had current conducting couplers and a pick up shoe the lights worked. I think I did make contact with the third rail if you will and ruined the light function. It just came today and I spent a a pretty penny for the set. So I will return the locomotive set and see of they can fix it. Otherwise it a gorgeous set and was running marvelously.
Thanks for the advice.
#5 Posted : 19 July 2014 11:13:23(UTC)
I think most of us here have a similar story to tell of a moments innattention or carelessness and an unfortunate outcome so in that at least you are not alone.
I sure can feel your disappointment (at yourself as much as anything else) especially with a new item and all, the excitement and enthusiasm of getting to know it.
Hope the story has a happy ending for you
#6 Posted : 19 July 2014 13:39:42(UTC)
Where ever you send it I would make sure to get some quote of how much it will cost you including postage before sending it off
Offline jlopez
#7 Posted : 19 July 2014 14:40:32(UTC)
jlopez
Thanks again, I definitely feel very bad about it. It was a birthday present to myself and really hate that I broke such a great model. I bought it new, I just hope that the warranty might cover it. At this point being so much $$ into it, if I'm going to have to pay to have fixed so be it. :(
#8 Posted : 19 July 2014 20:11:51(UTC)
Probably not.
The question is: will they be able to tell user fault (no warranty) from material fault (warranty)? Probably not (but that depends on how many people kill their decoders this way).
Offline Hackcell
#9 Posted : 20 July 2014 06:09:29(UTC)
Hackcell
Costa Rica
I wonder if it's possible to install any sort of fuse in the locos...Confused
Danilo Jiménez
Costa Rica, pura vida!!
thanks 1 user liked this useful post by Hackcell
Offline jlopez
#10 Posted : 20 July 2014 07:30:31(UTC)
jlopez
I wish they did! Just on the off chance there might have been one inside I opened it up. No luck. I think it is a great idea, I was hoping just de powering it or resetting the cs and the engine would do the trick( it does on a 737 ;) ) I did call the store where I bought, they were very sympathetic, told me to ship it back. Hopefully it is covered and an easy fix. If not lesson learned.
Thanks again for the advice and kind words I do feel like such crap ( for lack of a better word) about it all!
#11 Posted : 20 July 2014 08:38:47(UTC)
Good point. The decoder should have short circuit and overload protection on all function outputs.
Jaime, I don't have the Super Chief and I don't know whether the interior lights are controlled from a decoder output directly or through an external board.
Maybe you or any other owner of a Super Chief can check with a CS2 what F1 does (either one of AUX1 through AUX4 or a pseudo sound function).
Problem can easily be fixed by replacing the faulty part (either decoder or external board). Repair time will depend on availability of spare parts (decoders should always be available).
I bought a new Trix BR 103 where the external light board was defective out of the box. It arrived at Göppingen more than two months ago and is now waiting for availability of spare parts ...
If it turns out the overload protection failed then there would be ground for a warranty claim.
Offline grnwtrs
#12 Posted : 21 July 2014 03:37:37(UTC)
grnwtrs
Oh Boy, that is really scary. I also have this set, but have yet to put it on the carpebahn.
Matter of fact, I finally got out the Roller Test Stand this past week to test a couple of loks, but
more importantly to see if it would operate.
Well I learned that I could not use the 60653 directly with the test stand, but I digress, and
had to use my favorite 6021. Anyway all went well.
Back to the Super Chief. There is a Marklin/European train meet of July 27/28 (Eurowest 2014)
at the Hiller Air Museum. There are always Marklin reps there in addition to a few of guys that know
their way around Marklin and other European model trains.
Might be worth the gas and admission to have another set of eyes look at your set.
Good luck and think positive!!
gene
Offline jlopez
#13 Posted : 22 July 2014 09:49:27(UTC)
jlopez
gene
Hi Gene,
I got it through Reynaulds and they are taking care of the problem. Can not say enough about the great customer service from them! My suggestion to you would be any time you are messing with the couplers hit the stop button, just cut off power while you work on it. Other then that it ran great, fantastic sound. I ran it on M-track with all the associated switches and some tight turns and it worked great no issues. Solid heavy engine, great cars. You do just have to be careful with the older style switch lanterns as the there is no clearance for the longer cars to pass over them. Not a big deal nor do I expect Marklin to make models at are compatible with those turnouts.
Any way lesson learned and can't wait to get the set back on the rails.
J
Offline Dangermouse
#14 Posted : 22 July 2014 12:01:08(UTC)
Dangermouse
Coffee stirrers make great uncoupling sticks. There seems to be a vogue for wooden ones here at the moment, they're long, narrow, and light coloured so easy to see in the darkness between a couple of coaches. Plus they're non-conductive.
That's a poor decoder design IMO. There should be some sort of overload protection if a short will kill the decoder before it trips the controller out. It's not hard to implement (ESU do it) and the risk of accidentally touching the live rail to the coupler contact should have been foreseen.
You can never have too many Silberlinge
Online RayF
#15 Posted : 22 July 2014 13:01:59(UTC)
I've blown light outputs on two ESU decoders by accidentally shorting the light cable to chassis. They are not that well protected. A sudden large current flow like this will kill a decoder irrespective of over-current protection circuits. Shorting to the 3rd rail/pukos is probably even more drastic.
I use the Marklin black plastic manual uncouplers. They are safe and easy to use, and they came for free with a starter set and also with some coupler sets I bought. Being cranked they are easy to get below the level of the coupler bar.
#16 Posted : 22 July 2014 15:15:00(UTC)
Shorting to the chassis/the outer rails should be more drastic than shorting to the centre rail. Decoder output is minus, centre rail is minus most of the time, outer rails are plus most of the time.
Online RayF
#17 Posted : 22 July 2014 17:34:27(UTC)
I think it would depend on the circuit. There might be protection on the decoder output against short circuits to ground, but the output transistors might not like having the outputs connected to the full rail voltage.
It would be hard to know for sure without a look at the circuit diagram.
Offline biedmatt
#18 Posted : 22 July 2014 20:03:12(UTC)
biedmatt
With my ECoS 50200 the digital multi meter says there is less than 1VDC between the third rail and ground and 17VAC between third rail and ground.The decoder outputs are rectified and the polarity is negative for each output and positive for decoder output return (ESU blue wire). When you wire a function between decoder output (-) and (loko) ground (AC signal or alternating + and -), you get a half wave rectified signal-potential across the output only when ground is positive in the AC sine wave, or 50% of the time. The other 50% of the time when ground is at negative in the AC sine wave there is no potential across the output as it and ground are both negative at that moment. That is why the lamps flash when wired to ground and not output return.
As to fuses, they will neither react fast enough nor when needed. The specs for fuses typically allow a 200% variance in the fusing window. Much too high a value and much to slow to react and protect the decoder.
Matt
Era 3
#19 Posted : 22 July 2014 22:01:07(UTC)
Both centre rail and outer rail have the full rail voltage - polarity changes 5000+ times a second.
How do you define "ground"? Common return (orange wire with Märklin colour scheme) is plus. Difference between "orange wire" and full track voltage are just rectifier diodes.
#20 Posted : 22 July 2014 22:03:48(UTC)
No sine wave with digital operation. Make this about 75 % with MM protocol. With DCC it depends on the implementation.
Offline biedmatt
#21 Posted : 22 July 2014 22:30:12(UTC)
biedmatt
We no longer have an o-scope, so I figured it was a sine wave. Must be a square wave then, but still an alternating circuit with polarities switching back and forth positive and negative. Otherwise, the DMM would not show 17VAC. It would be interesting to put an o-scope between the decoder output and loko ground to see it visually.
Matt
Era 3
This page was generated in 0.607 seconds.
