Offline petestra
#1 Posted : 13 July 2014 21:07:40(UTC)
Hi Friends, I was wondering. As some of you might know I am recently (since last Oct.) switched to digital operations, using 2x MS2s. I also can switch over
to analogue ops. Here's the ?. I have some and are getting more digital Loks with sounds. Is there a way to connect a resistor to these signals so that
the Loks lights/sounds will not go off at a red light? Where is the resistor placed? I operate signals using control boxes, not digitally. If these resistors work, how will they effect
analogue ops? Thanks for your help. Peter Smile
#2 Posted : 13 July 2014 21:18:17(UTC)
Don't think this is feasable...
In the "old" digital days it was recommended to have a 1,5 kOhm resistor from the layout power
to the isolated section so the decoders would not lose memory. However this is not enough to keep
decoder functions working with modern decoders as I understand.
Offline petestra
#3 Posted : 13 July 2014 21:30:49(UTC)
Thanks so much for the info, Juhan. It's not a big deal. As you know, I like my signals. cheers, Peter Smile
#4 Posted : 14 July 2014 08:26:40(UTC)
Is there a way to connect a resistor to these signals so that the Loks lights/sounds will not go off at a red light?
For decoders that support ABC braking (e.g. ESU LokSound 4) you can use diodes to achieve that.
It's a general problem with new decoder features that many older locos do not support it.
The Märklin braking modules have not much more than a diode. This is an older technique that will work with more decoders, but requires more parts. Also check Bogobit braking modules and others that implement the same technique.
Just a resistor will not work.
Offline Johnvr
#5 Posted : 14 July 2014 20:36:21(UTC)
Johnvr
Peter,
I have the ideal solution for you Cool Cool
You can use your 7039 Marklin signals operated by 7072 switch boxes and connected to a Braking Module.
A Braking Module allows the trains to slow down and stop at the end of the platform, with brakes squealing away merrily.
The smoke and sound functions remain on while the train waits at the station.
When the signal goes green again, then the train accelerates slowly away, choof .. choof .. choof .. it sounds so nice !
Have a look at my video attached :
http://youtu.be/bMvqutoz1LU
Regards,BigGrin
This page was generated in 0.308 seconds.
