Offline mancsaint
#1 Posted : 11 July 2014 14:50:51(UTC)
mancsaint
I have just bought a boxed Marklin 3430 which should be a Delta. I attach a photo of the decoder for your assistance. My MS2 does not recognise it.
Any advice would be gratefully received.
Mancsaint
I was too quick to ask, this is an older version of the Delta where the address is set by soldering.
Thanks all.
mancsaint attached the following image(s):
Offline Renato
#2 Posted : 11 July 2014 19:36:29(UTC)
Renato
Hi Sean,
Now if you know the address of the locomotive, simply input it in your MS2 and you will be able to control it.
Renato
Offline mancsaint
#3 Posted : 11 July 2014 19:56:06(UTC)
mancsaint
Thanks Renato,
The MS2 database loads it as address 24, and as the address is soldered I have to assume that is what it is. Unfortunately nothing happened when I tried it out, so will investigate further.
Thanks again
Sean
Offline Renato
#4 Posted : 11 July 2014 20:02:56(UTC)
Renato
Hi Sean,
And if the owner decided to change the address desoldering and resoldering?
Only one remote possibility, but it could have happened...
Renato
Offline mancsaint
#5 Posted : 11 July 2014 20:31:16(UTC)
mancsaint
Always possible, soldering seems VERY neat but will continue investigating.
Sean
#6 Posted : 11 July 2014 22:17:14(UTC)
For an address table with the old solder bridge Delta - see https://www.marklin-user...Digital/DIdeltaaddr.html
Photo shows that it should be 24 indeed...
Offline mancsaint
#7 Posted : 11 July 2014 23:25:54(UTC)
mancsaint
Thank you all for clarification.
Sean
Offline Shamu
#8 Posted : 12 July 2014 07:10:01(UTC)
Shamu
Just out of curiosity Juhan, that page you list on it is a reference to "Dr König's digital site", its gone "poof" and wondering if you know of another source ?
Sorry for butting into Sean's thread. Blushing
Offline mancsaint
#9 Posted : 12 July 2014 07:50:30(UTC)
mancsaint
Shamu try this one.
http://home.arcor.de/dr....nig/digital/ehomepag.htm
I hope you enjoy your Hunter Valley reds as much as I used to do.
Sean
thanks 1 user liked this useful post by mancsaint
Offline Shamu
#10 Posted: : 12 July 2014 08:01:28(UTC)
Shamu
Originally Posted by: mancsaint Go to Quoted Post
Shamu try this one.
Sean
Cheers Sean,
I was just about to post that link, lucky I checked first.
A awful lot of really interesting information for "Delta" and other stuff on that site but a lot of dead links as well. Could be worth while someone with more brains than me to see what's worth trying to salvage from it before it all trickles away.
Prefer the Barossa ones myself...... before I stopped drinking a few years back Crying
Offline mancsaint
#11 Posted : 12 July 2014 23:58:20(UTC)
mancsaint
Just a quick finale, all is working well now with MS2, minor problem lights at one end not working probably blown bulb.
Cheers to all
Sean
Offline Renato
#12 Posted : 13 July 2014 00:14:36(UTC)
Renato
Hi Sean,
So finally what did you do to have the locomotive working with your MS2?
Only my curiosity...BigGrin
Renato
Offline mancsaint
#13 Posted : 13 July 2014 00:41:15(UTC)
mancsaint
Renato,
Had a red wine to loosen myself to start.
Cleaned and oiled things, with a gentle nudge, off it went, a bit hesitantly initially but soon ran well and at top speed. It looked as if it hadn't been run for a while, so it needed a bit of TLC.
I will get some spare bulbs and that should solve the problem with the non working light.
Sean
Offline Renato
#14 Posted : 13 July 2014 17:01:32(UTC)
Renato
Hi Sean,
So it was only a mechanical trouble, not electronic (decoder).
Glad to know all is working now.
Enjoy it ! BigGrin
Renato
This page was generated in 0.608 seconds.
