Offline danmarklinman
#1 Posted : 10 July 2014 15:22:03(UTC)
danmarklinman
Hi can anyone tell me if there is any red conductive paint for pantographs please. I have some Z locomotives which have silver pantographs which I will be using with powered overhead! So the paint needs to be conductive. Help! Cheers Dan
Wiking model car Fan
Instagram: marklin1978
Wiking fan
Offline Dangermouse
#2 Posted : 10 July 2014 17:27:46(UTC)
Dangermouse
If you look at photos of real locos with red pans the actual contacts are usually black (I think they're generally coated with a graphite paste, which reduces wear).
If the Z loco pans are blackened then spraying them red before removing the paint from the contacts (try a track cleaning block) might do the trick. Rather you than me though - there's a risk of gluing them solid with paint, given how tiny the fittings are!
You can never have too many Silberlinge
thanks 1 user liked this useful post by Dangermouse
Offline kbvrod
#3 Posted : 12 July 2014 02:08:04(UTC)
kbvrod
Hi Dan,all,
The paint itself does not have to be conductive,only the contact areas(pans and to the motor).I can walk you through it.
Dr D
thanks 1 user liked this useful post by kbvrod
This page was generated in 0.439 seconds.
