Offline civileye
#1 Posted : 08 July 2014 23:50:58(UTC)
civileye
I'm just getting started into European AC (3 rail) trains and want to know if I can mix different kinds of Marklin track, for instance, M track and K track without some kind of an adapter? Do I need a special transformer for Marklin track or can I use my DC transformer? If so, how do I wire it? Can I solder the wires to the track?
Bill (Civileye)
Offline Irish Rail
#2 Posted : 09 July 2014 12:22:24(UTC)
Irish Rail
Ireland
Hi Bill, and welcome to the forum.
I'm not an expert, but you can certainly mix M and K track using an adapter track (part# 2291).
To apply power to M track, there are feeder tracks (straight and curved) with live and earth connections from the supplying transformer.
Marklin transformers for analog operation have three connections - red (live), brown (earth) and yellow (for accessories like lights). Provided the DC voltages were the same, there is no reason another brand of transformer couldn't be used. However, Marklin analog locomotives have a reversing mechanism that requires the application of a specific voltage which is provided by a Marklin transformer. I don't know if other brands of transformer can do the same.
I'm sure someone will expand on the above, soon.
Des
Edited by user 09 July 2014 19:20:29(UTC)  | Reason: Not specified
Offline Dangermouse
#3 Posted : 09 July 2014 15:11:50(UTC)
Dangermouse
The DC transformer won't be able to generate a reversing pulse to change direction, you need either a Marklin analog controller or one of their Delta/Digital systems.
Cheapest way is probably to find one of the white-cased 32VA transformers, you might find a cheap starter set including one if you keep your eyes open. Make sure that the transformer is designed for 110v AC rather than the 230v used in Europe, any you buy locally should be fine. These are very easy to wire - just connect the red terminal to the centre studs and the brown terminal next to it to the rails. In order to change direction you turn the knob briefly anticlockwise against the end stop.
Don't be tempted by the old blue transformers as they're not safe for the latest locos, the reversing pulse they produce is too powerful.
You can connect pretty much any Marklin track to any other Marklin track with adapters, I've had 1950s M track (with solid centre rail) connected to 2010s C track via the adapter pieces.
You can never have too many Silberlinge
#4 Posted : 09 July 2014 15:14:38(UTC)
Make sure that the transformer is designed for 120 V AC, not 110 V AC, if you intend to use current locomotives.
Offline Dangermouse
#5 Posted : 09 July 2014 15:33:46(UTC)
Dangermouse
Oh, are they on 120v now? Oops! I know we standardised on 230v here in Europe but wasn't sure what the USA had done.
Offline MACER
#6 Posted : 12 July 2014 19:26:39(UTC)
MACER
Argentina
Sorry for my english i new in the forum, this forum is complety, very nyce, and ask me as up pictures?
thanks.
Offline Renato
#7 Posted : 13 July 2014 00:19:27(UTC)
Renato
Hi macer,
Welcome to the forum and don't worry for your English, you will improve it reading the posts and writing your questions...
Renato
Help with Marklin Track Cleaning cars (H0-scale)
by jimwallace1652 11/04/2024 23:55:53(UTC)
Looking at redoing my outdoor railway with Marklin track vs the LGB it has now (Big scale)
by artfull dodger 27/07/2023 19:45:44(UTC)
Marklin track C plans (Track plans)
by Thewolf 27/04/2023 12:53:01(UTC)
Use of RailModellerPro Software Program for Marklin Track Layouts (General MRR)
by mjborelli 22/01/2023 22:35:24(UTC)
DC wheelsets and Marklin track (H0-scale)
by revmox 17/06/2022 07:03:57(UTC)
by Mr. Ron 14/09/2021 04:39:51(UTC)
Building Marklin track 3 (Small scale)
by Nrwatson 20/01/2020 15:29:32(UTC)
Marklin track ? Solder (Small scale)
by Nrwatson 23/11/2019 23:18:42(UTC)
Marklin track layout problem (H0-scale)
by LongHairedDavid 01/06/2019 20:05:21(UTC)
Marklin track types and how they work (H0-scale)
by wojo12 04/01/2019 20:17:00(UTC)
Roco DCC Loco on Marklin Track (H0-scale)
by Gforce250 04/12/2018 23:21:24(UTC)
Older Marklin track & switches (H0-scale)
by rhschulz2000 25/06/2018 04:10:41(UTC)
PDF dl of lots of old Marlin track plans from Marklin Track plan books? (Track plans)
by ShannonN 24/12/2017 01:15:20(UTC)
Starting up my Marklin track again (H0-scale)
by FV1974 05/11/2017 22:28:10(UTC)
Just bought my first Marklin track on ebay... (General MRR)
by Tony O 02/10/2017 18:38:06(UTC)
The Best Marklin Track Cleaner (H0-scale)
by Johnvr 09/08/2017 19:30:19(UTC)
Z Scale Marklin Track Plan (Track plans)
by CanadianKid 21/03/2017 05:41:35(UTC)
questions about vintage marklin track (H0-scale)
by thomas buckley 28/11/2016 02:01:43(UTC)
Marklin Track Cleaning Car (Small scale)
by BillO 02/11/2016 03:05:17(UTC)
Question on Marklin Track Sets 20*** (H0-scale)
by madhu.gn.71 18/11/2015 16:10:26(UTC)
Finally Justification of Marklin Track (H0-scale)
by SteamNut 16/05/2015 18:18:15(UTC)
Marklin track geometry (H0-scale)
by quarkhirad 04/05/2015 16:37:06(UTC)
Electrotren AC 3 rail how well do they run on Marklin track and do you have one? (H0-scale)
by danmarklinman 10/06/2014 17:10:13(UTC)
brawa diesel locos on marklin tracks. (General MRR)
by christos563 21/01/2014 18:41:27(UTC)
Cleanng Marklin Tracks (Collector's Corner general)
by kumarvartak 11/08/2013 15:34:48(UTC)
Roughness on the surface of Marklin track rails (Small scale)
by chiemgau 24/06/2013 02:01:27(UTC)
Download software for Marklin track planning help (Track plans)
by danmarklinman 02/04/2013 14:36:47(UTC)
cleaning the studs on marklin tracks.. (H0-scale)
by chelseadrake 12/10/2012 11:34:52(UTC)
Micro Metakit 02 running on Marklin Tracks (H0-scale)
by I_love_Marklin_37538 13/05/2012 08:38:10(UTC)
Esu locomotives on Marklin track (H0-scale)
by dan67millie 26/03/2012 17:39:34(UTC)
Running Trix Adler (three rail) on Marklin track (H0-scale)
by Angus 27/01/2012 12:57:59(UTC)
Marklin track plan books - where to find? (Collector's Corner general)
by BrandonVA 24/01/2012 21:27:31(UTC)
POLL - Marklin track. (H0-scale)
by steventrain 13/08/2011 18:45:07(UTC)
building a layout using old marklin track (General MRR)
by dmphilipson 20/12/2010 19:34:07(UTC)
Could Tomix/Kato Japanese models run on Marklin tracks? (General MRR)
by I_love_Marklin_37538 23/05/2010 05:06:59(UTC)
Marklin Track Plan CD (Digital)
by epoche_ii 15/11/2009 16:16:24(UTC)
Marklin Track - which one? (General MRR)
by Breitenfurt 23/07/2009 01:02:40(UTC)
Marklin Track Help (H0-scale)
by choochin3 19/06/2009 09:09:25(UTC)
Marklin Track (General MRR)
by charles Sharpe 23/02/2009 12:54:05(UTC)
Possiblity of NZR trains to run on Marklin track? (H0-scale)
by I_love_Marklin_37538 25/11/2008 12:29:16(UTC)
US DC Rolling Stock on Marklin Track (H0-scale)
by leesauer 21/02/2008 22:52:13(UTC)
gapping marklin tracks? (General MRR)
by littledragon 14/04/2007 04:04:54(UTC)
Marklin Track Plan Book (H0-scale)
by nevw 05/10/2005 15:33:44(UTC)
marklin tracks.... (H0-scale)
by littledragon 05/08/2005 01:33:56(UTC)
Weathering Marklin Tracks (H0-scale)
by David 01/08/2004 09:20:45(UTC)
Huebner vs. Marklin tracks (Big scale)
by leohcheung 13/05/2004 20:58:15(UTC)
This page was generated in 0.915 seconds.
