Offline thanethm11
#1 Posted : 09 July 2013 04:46:31(UTC)
thanethm11
Dear Sir,
I have just received new measuring car Marklin#49960 in last week. Km/hr is working normally.
But mobile station can not control this car to change measuring mode such as speed , distance, time. Becase MS1 have no F1,F2,F3F4.
Anyway i trial to use address 75 directly...But this car is still not to work.
I don't sure that this car decorder is broken or MS1 is not suitation for this car.
Please help me...
Thank and Regards,
ThanethM
thanethm11 attached the following image(s):
Offline franciscohg
#2 Posted : 09 July 2013 05:13:02(UTC)
franciscohg
Chile
Hi taneth, it seems that the car is not compatible with a MS1
take a look here
https://www.marklin-user...g=posts&t=5779&=
It is an old thread, dont know if perhaps the problem might have been fixed with a firmware update of the MS1
#3 Posted : 09 July 2013 07:04:05(UTC)
I confirm: just using an MS1 as your CPU, you will not be able to control the 49960.
I use my MS1 as a walk around controller (i.e; "slave" ) to my ECOs2 .
The 49660 on the Ecos has been entered under the "M14fx" format (it is *not* mentionned in the ECOS database!!) and then it can eventually be controlled via the MS1.
Hope this helps.
#4 Posted : 17 July 2013 03:01:18(UTC)
To be able go contrl my 49960 with a MS1 connected to my CS1 I gave it certain icons for the functions to be able to use the f1 to f4 buttons (the left ones) on the MS1:
f1= light bulb with no. 1 inside
f2= Acc& braking delay (Almost triangle)
f3 = shunting speed (Turtle)
f4 = flute
screenshot of my CS1:
49960 screenshot
A small warning:
After approx. 40 hours running time I opened my measuring car and found that the rear red bulb had melted some of the plastic holding it
49960 rear LED
I replaced it with a LED
At the same time I installed an old c80 decoder to be able to switch the light on and off with the f0 function.
49960_6080
The purple wire has the same function as the orange one on the more modern decoders (plus for functions)
A future improvement will be to use the f0 function from the c80 decoder to switch the power to the measuring unit on and off via a small relay. This is to prevent that the seven segment LEDs are on all the time
Offline Moritz-BR365
#5 Posted : 30 June 2014 12:15:07(UTC)
Moritz-BR365
The same for the MS2, the 49960 can't be used with the MS2!
The Decoder does not recognize the commands in MM2 format but only MM1. But the MS2 does only support MM2. Therefore, only the speed is displayed.
Therefore, I'm waiting for a CS2, better to say, I'm waiting for money to buy the CS2.
#6 Posted : 30 June 2014 16:04:27(UTC)
Moritz-BR365
I found a report about how to replace the original MM1 decoder by a Esu LokPilot fx function decoder (any other function decoder possible):
http://donaupeter.de/moba/Messwagen/messwagen.htm
I'm thinking about doing the same, but either with LokPilot V4.0 Plux (9 function ports) or with two Uhlenbrock function decoders.
Moritz
Edited by user 01 July 2014 10:33:41(UTC)  | Reason: Not specified
thanks 2 users liked this useful post by Moritz-BR365
Offline Shamu
#7 Posted : 01 July 2014 04:50:04(UTC)
Shamu
Thanks for that Moritz.
This has changed my mind about getting one of these coaches next time I see one for a good price. Been a very long time since I made circuit boards, that will be the challenge Confused Blink
Thanks heaps for the link ThumpUp
thanks 3 users liked this useful post by Shamu
#8 Posted : 06 July 2014 19:18:31(UTC)
Moritz-BR365
Yesterday, I received a circuit board to connect a new decoder to the 49960:
The Zimo MX686 seems to be a good choice, because it has 8 AUX ports and a connectors for a buffer capacitor. This would be enough to realize:
- Headlight front
- rearlights front
- rearlights back
- switch on/off measure board
- Measure function 1
- Measure function 2
- Measure function 3
- Measure function 4
http://www.zimo.at/web20...cts/funktionsdecoder.htm
Moritz
Offline Shamu
#9 Posted : 07 July 2014 07:04:06(UTC)
Shamu
Hi Moritz,
Just curious as to were you got the circuit board from as I could find no indication on the donaupeter site that they sold them ?
Sorry if I missed a bleeding obvious link or page on that site but I'd be happier now days to pay for one as opposed to trying several times to etch a circuit board myself. (And get very cranky with myself for not being to do it anymore)
Look forward to seeing your final results with the modernising of this coach.
Shane
#10 Posted : 08 July 2014 09:02:43(UTC)
Moritz-BR365
In meantime, Märklin support told me, the MS2 should be able to control the 49960. I replied that it isn't possible because of the decoder does only "spaek" MM1 but the MS2 does only speak MM2 protocol.
Now, they replied they would take their test sample from the board and check it by themselve. I'm waiting for the result of this test run.
#11 Posted : 08 July 2014 09:28:12(UTC)
Moritz-BR365
A further option I think about is to use the TAMS FD-R extended. Well, this function decoder provides only 6 AUX ports, but on the other sinde, it has 4 integrated sounds like a bell and a horn. Furthermore, it provides 3 input ports, a SUSI interface and direct support for a buffer capacitor!
http://www.tams-online.d...d/produkte_fd_r_ext.html
With this decoder, I would realize:
Functions:
F0: Headlight front
F0: rearlights front
F1: Measure function 1
F2: Measure function 2
F3: Measure function 3
F4: Measure function 4
Sounds:
F5: Bell
F6: Horn
F7: conductor whistle
F8: door closing beep
I would switch of the rear backlights, because they don't make sense, there will allways be a loco on the rear side. So why have backlights there?
A bit sad that it would not be possible to switch on/off measure board. But it would need an additional decoder. Is it worth?
As compromise, I could switch on/off the measure unit together with head/rear lights! This would make it possible to switch off the measure unit when the measure waggon is not in use on a siding but it is always on when the head/rear lights are switched on. This may be a good solution:
Functions:
F0 forward: Headlight front + measure unit ON
F0 backward: Rearlights front + measure unit ON
Hard decision!
#12 Posted : 08 July 2014 11:22:01(UTC)
Moritz-BR365
Circuit for TAMS FD-R Extended:
#13 Posted : 09 July 2014 07:54:52(UTC)
Moritz-BR365
There will be another option to switch off the LED segments but continue measuring! I will get this solution soon. It is quite usefull, because You can run the measure train with LED segments switched off but continue the measure. Then, in the main station, You can switch on the LED segments to read the values.
Stay tuned!
#14 Posted : 10 July 2014 08:23:03(UTC)
Moritz-BR365
Here, this shows the place where I can put the linear servo for the pantograph:
Still not decided whether I should use the Tams FD-R Extended or the Zimo MX687W, whch comes with a 5V current output for the servo, but it is 15€ more expensive as the Tams FD-R Extended!
Moritz
Offline Dangermouse
#15 Posted : 10 July 2014 13:54:42(UTC)
Dangermouse
It's weird that Marklin haven't re-released this with an updated decoder. Did it not sell as well as expected the first time around?
I picked mine up brand new in about 2007, it had evidently sat on the shelf for some years! Often been tempted by a 49961 to go with it but as I don't have overhead wiring (and will never have live overhead anyway) I don't see much point, beyond completeness.
You can never have too many Silberlinge
thanks 1 user liked this useful post by Dangermouse
#16 Posted : 10 July 2014 14:54:47(UTC)
Moritz-BR365
Yes, I don't understand, too, why they haven't released again with mfx decoder. The same for the BR701 with its nice functions. But I think, it is to expensive in manufacturing and the price doesn't return the investment.
I will look for the 49961, too, because I plan to set up overhead. But the market price for used 49961 is very high, the same for the 49960. I payed 75, which was not too much for this model.
Moritz
Offline Dangermouse
#17 Posted : 11 July 2014 20:12:31(UTC)
Dangermouse
I think mine was about £110, given that it was brand new (box a little faded but contents untouched) that seemed a fair deal.
49961 is behind a few locos and coaches on my shopping list.
#18 Posted : 03 August 2014 16:17:44(UTC)
Moritz-BR365
In meantime I replaced the decoder eleltronic with a DCC Uhlenbrock function decoder 76900 for F1-F4.
The following slides show the replacement circuit board and the decoder behind the main circuit board:
Speed measure
F1 = OFF
F2 = OFF
F3 = OFF
F4 = OFF
Measure in km/h (Vorbild)
F1 = OFF
F2 = OFF
F3 = ON
F4 = OFF
Measure in m/s (Modell)
Distance Measure
F1 = ON
F2 = OFF
F3 = OFF
F4 = OFF
Measure in km (Vorbild)
F1 = ON
F2 = OFF
F3 = ON
F4 = OFF
Measure in m (Modell)
Time Measure
F1 = OFF
F2 = ON
F3 = OFF
F4 = OFF
Measure in Minutes (long)
F1 = OFF
F2 = ON
F3 = OFF
F4 = OFF
Measure in seconds (short)
Driving time measure
F1 = ON
F2 = ON
F3 = OFF
F4 = OFF
Measure in hours (total running time)
F1 = ON
F2 = ON
F3 = ON
F4 = OFF
Measure in minutes (single run)
F4 is to reset the measure values except the total running time.
#19 Posted : 03 August 2014 18:46:24(UTC)
Moritz-BR365
Video:
#20 Posted : 03 August 2014 22:53:39(UTC)
Moritz-BR365
The rear light is here a bit too bright and it shines through the upper headlight. I dimmed now the rear lights (after this photo shot) and now it looks better.
Guest (4)
This page was generated in 0.524 seconds.
