Offline SteamNut
#1 Posted : 19 June 2014 05:55:31(UTC)
SteamNut
Received today my Marklin 4228 Rheingold set from ebay. It has seen better days but not too bad for the price. One of the cars needs a new pocket were the close coupler goes into (missing copper contact). Is there a parts sheet for this and how to take apart the d**** thing ? I did send a email to Marklin about this and waiting for a reply. Any help would be appreciated - Fred
Offline 3rail4life
#2 Posted : 19 June 2014 07:36:22(UTC)
3rail4life
Hi Fred,
Gently pull off the roof and you will sell how it is all held together, lots of metal tabs. To access the coupler pockets for replacement, I took the whole thing apart, a bit of a job , but I saw no other way. I started with the bulkheads and worked my way down, not easy at all and you have to be careful not scratch or break anything else along the way. The coupler pockets are E271140, not sure on the conducting springs.
Hope this helps:
4228 coach parts picture
Gordon
thanks 4 users liked this useful post by 3rail4life
Offline Markus Schild
#3 Posted : 19 June 2014 08:15:04(UTC)
Markus Schild
Hi Fred,
The contact-spring is
Code:
E271150 - Kontaktfeder ( Kuppl.)5 Stück
6,00 € Unverbindliche Preisempfehlung(VPE: 5) E
If Märklin does not reply immediately please notice that today is a public holiday in southern Germany and most companies also don't work tomorrow.
Markus
Offline SteamNut
#4 Posted : 19 June 2014 13:20:03(UTC)
SteamNut
Thanks for the replies. When I have some time this weekend I will try to tackle this some more.
Offline SteamNut
#5 Posted : 21 June 2014 01:20:54(UTC)
SteamNut
Thanks to you I was able to take it apart without damage BigGrin Now I know why Marklin is sometimes referred to as "Mother Marklin" The coupling contactor spring is completely missing someone used it for parts somewhere. Marklin has the part in stock however I can not buy directly from Marklin as I live in the US. The part # is E271150 can someone offer a suggestion or help ?
Offline biedmatt
#6 Posted : 21 June 2014 03:09:47(UTC)
biedmatt
Perhaps it is part of current conducting coupler kit 7319. These clips can be damaged if the copper conductor on the draw bar does not slip under (assuming the coach is right side up) the coupler pocket clip.
Matt
Era 3
#7 Posted : 21 June 2014 07:38:25(UTC)
If you could they would charge you €50 for postage and handling.
Can't you order through Walthers? Or through an American dealer?
Märklin sometimes economise their trains - it could be by design that the coach running next to the loco only gets one of these copper thingies (I don't know about the 4228, but they did that with other coach sets).
Offline SteamNut
#8 Posted : 21 June 2014 15:05:54(UTC)
SteamNut
This car fits between the other couches the two ends have regular couplers. I will try Walthers today as they are only about 45 miles from my house.
Offline SteamNut
#9 Posted : 14 September 2014 22:33:09(UTC)
SteamNut
I received last week the part I needed and put everything back together again. Thanks for all the help! Now I find out that derailments are no fun with these type of couplers Blink
#10 Posted : 15 September 2014 08:08:42(UTC)
There should be no derailing with Märklin rolling stock on properly laid Märklin tracks.
I found it's easier to couple this type of coaches while they lie upside down. Turning six coaches with just two hands was a bit of a challenge once all coaches were coupled together.
Do they always derail at the same spots?
Trucks can be mounted in two positions: one that allows running on small radii, one that looks good.
Small radii is the factory default.
#11 Posted : 15 September 2014 10:07:12(UTC)
...Trucks can be mounted in two positions: one that allows running on small radii, one that looks good.
Oh that's interesting. I have the 4228 and have no derailment problems on my M-track layout, but I am interested to know a little more about the two positions. Smile
#12 Posted : 15 September 2014 14:04:42(UTC)
... but I am interested to know a little more about the two positions.
RTFM - read the funny manual (copy URL to address field):
Code:
http://medienpdb.maerklin.de/product_files/1/pdf/42283_betrieb.pdf
See pages 2 and 3.
This is the 42283 manual, but I assume the 4228 is the same with respect to lowering.
I never tried it myself, I just know it can be done.
And for a second-hand purchase this is one aspect that has to be checked if the train derails.
Offline Gregor
#13 Posted : 15 September 2014 14:57:46(UTC)
Gregor
Yes, I have the 4228 and indeed it has the same washers to increase the height.
My 4228 sometimes derails as well. On the previous analog layout it shortened, but apparently not enough to have the protection kick in. The heat deformed the bottom which tilted the bogie stud. It was a hell of a job aligning this back to 90°.
best regards,
Gregor
thanks 1 user liked this useful post by Gregor
Offline SteamNut
#14 Posted : 16 September 2014 08:11:26(UTC)
SteamNut
I will check that out but it seems to be at the turnouts mostly which are the 200 series.
This page was generated in 0.445 seconds.
