#1 Posted : 06 May 2014 12:20:09(UTC)
Have a look at 3097 (left) and 3005 (right).
Have you see the different? Wheels gears, coupling rods etc.
Online RayF
#2 Posted : 06 May 2014 12:42:15(UTC)
Hi Stephen,
Thanks for the photos, it's interesting to compare these two locos.
The 3097 is a simplified version of the 3005, with less gears and also simpler valve gear. I believe the body is also plastic, whereas the 3005 had mostly metal bodies apart from some examples in the 1950s.
#3 Posted : 06 May 2014 13:07:57(UTC)
Hi Ray,
The body was metal and production in 1969 - 1970.
In 1971 the 3097 was dropped and return of the 3005 to the production after two years break.
3005 was not production in 1969/70 because of 3097 Low cost and More power running?
Online RayF
#4 Posted : 06 May 2014 13:20:19(UTC)
Thanks Stephen, I didn't know the 3097 was metal.
I don't know why the design was changed in 1969 and 1970, but I remember seeing the catalogue (1971?) where they said they welcomed back the 3005.
It was taken out of the catalogue completely after 1972, so it seems a bit strange they spent so much time over it.
In 1973 they started selling the Br23 as the Primex 3097, and afterwards as the Primex 3191 and in 2000 as the Primex 33005. Maybe the simplified design was meant for the change to the Primex brand?
#5 Posted : 06 May 2014 13:46:24(UTC)
Yes BR23 was not in 1973 catalogue.
3005 and 3097 BR23 Detail wrote in catalogue '....Dull black all metal body'
1967/68 Catalogue
1969 catalogue
1970 catalogue
1971 catalogue (Wiederaufnahme - Recovery)
Offline Janne75
#6 Posted : 06 May 2014 14:13:16(UTC)
Janne75
Thanks for showing the differences between these two models. I (we) have at the moment three BR 23`s and there is very soon coming one more from Finland. I think it is 3005 model as the box is light blue when I saw a photo of it.
All of them have came without the original box except the newest soon coming one. I have bought one light blue box and instructions separately for them. One is a plastic body DA 800 and the other two are metal models. If I remember right these two are without those extra gears and only powered axle is the rear axle and power is then transfered by siderods to other driving wheels. DA 800 has all axles with gears and all six drive wheels are driven by them like 3005 in the photos. I have noticed one other difference in some models. There is a marking "P 35" in some of the metal models, but not all.
Also there are different color part where the rear trailing wheel is attached (rear bogie?). Most have black ones, but some have red. It seems like our two current metal models are then some Primex models or 3097? They can be also modified by some previous owner or something similar. One of them has circlips to attach the siderods and not bolts or nuts... Confused
Here are five links to German Lokshow website, if some German member could tell the differences?
DA 800 BR 23
3005 BR 23
Early model 3097 BR 23
Later model 3097 BR 23
Primex 3191 BR 23
Edit: When I try to see these small and not very clear Lokshow website photos it seems like the DA 800 is the only BR 23 with red front and rear "bogies". Others have black ones. So our DA 800 is missing one of it´s original parts as the other one of them is black. When I try to see the Primex 3191 photos it looks like there is a gear in the front driving wheel too. Maybe 3097 is the only model without these then?
Janne
Edited by user 06 May 2014 19:00:12(UTC)  | Reason: Typo
thanks 3 users liked this useful post by Janne75
#7 Posted : 06 May 2014 14:31:07(UTC)
3005 and 3097
Offline Janne75
#8 Posted : 06 May 2014 14:43:47(UTC)
Janne75
Hi again,
I can not German, but I figured out that this must be the model with circlip attached siderods:
3097 Version: 1973
Bauzeit: 1973 - 1975, Steuerungsstangen mit Sprengringen montiert
"Mystery" with this version is now solved BigGrin ...
Janne
#9 Posted : 06 May 2014 15:04:29(UTC)
Coupling rods.
3097
30050 reproduction
#10 Posted : 06 May 2014 15:06:00(UTC)
Boxed of BR23 My collection.
Offline Iamnotthecrazyone
#11 Posted : 07 May 2014 00:10:32(UTC)
Iamnotthecrazyone
I don't know if I missed it but there are some that all the wheels (one side) are driven by gears while in others only one wheel is and the rest are pushed by the rods. I think there are two Primex, the one I have is made of metal. now with more time I can see I did miss itLOL
#12 Posted : 07 May 2014 01:43:13(UTC)
I have a Primex 33005, made in 2000.
Primex 33005
It is all metal and the axles are driven by cog wheels, as in Steventrain's 3005 photo.
The rods are secured by screws
More details, see http://www.saebonet.com/Svein/Tog/Sites/D/33005.htm
primex had a Br 23 in 1985, item no. 3191, which seemed to be more like the Märklin 3097.
Edited by user 07 May 2014 17:14:35(UTC)  | Reason: typing error
thanks 4 users liked this useful post by intruder
#13 Posted : 07 May 2014 02:33:51(UTC)
Iamnotthecrazyone
Primex 33005
It is all metal and the axles are driven by cog wheels, as in Seventrain's 3005 photo.
I think is the first time I see a good close up of that one, it is very nice, I am surprised the light bulbs are not directly exposed. I'll try to upload a photo of mine soon, I have the other primex 3191. What camera did you use for that photo? The tender in mind is not the right one, I should have one like yours with the white writing on it.
Iamnotthecrazyone attached the following image(s):
thanks 2 users liked this useful post by Iamnotthecrazyone
#14 Posted : 07 May 2014 17:51:05(UTC)
You are right about the tender according to a photo from Märklin and this from ebay
http://www.ebay.com/itm/MARKLIN...xed-Tested-/200914026374
yhr tenfer should look like the one from 33005.
I shot my 3305 WITH my good old CANON Powershot G6, focal length 21mm (135mm equivalent = 100mm), f/8, 1/6 second, white background, white paper under the track, ambient light in our conservatory (three glass walls and a transparent roof)
#15 Posted : 08 May 2014 08:47:54(UTC)
Iamnotthecrazyone
Seems like a very good camera to photograph the trains at close up range, your photo looks very professional. Also now that I see your version properly photographed I like it a lot more than before.
thanks 1 user liked this useful post by Iamnotthecrazyone
This page was generated in 0.645 seconds.
