Offline Yaasan
#1 Posted : 27 April 2014 23:52:01(UTC)
Yaasan
Japan
I have developed new S88 alternative solution which is "CameraS88".
Please watch the following video.
Camera S88 Video
This solution can use with Desktop Station. I will release this solution for free in my web page.
If you have Desktop Station(Railuino or DCC/MM2 Shield) and web cam, please try.
Yaasan
thanks 9 users liked this useful post by Yaasan
Offline bo
#2 Posted : 28 April 2014 00:31:10(UTC)
bo
Ukraine
Hi Yaasan,
looks amazing!ThumpUp
But how about running several locs simultaneously?
Offline Yaasan
#3 Posted : 28 April 2014 00:47:29(UTC)
Yaasan
Japan
Hi bo,
Thank you for reply.
CameraS88 application can detect the difference between pre-registered and realtime image.
Because you can register many Monitoring areas, several locs may be recognized at several monitoring areas.
Yaasan
Originally Posted by: bo Go to Quoted Post
Hi Yaasan,
thanks 2 users liked this useful post by Yaasan
Offline franciscohg
#4 Posted : 28 April 2014 05:48:27(UTC)
franciscohg
Chile
Hello Yasaan, looks great!
Finally a good use for a webcam!
Will check the site and try it, no doubt!
Offline Yaasan
#5 Posted : 28 April 2014 08:27:00(UTC)
Yaasan
Japan
You can find Camera S88 app and corresponding Desktop Station 0.90 in my web page.
If you play, please run CameraS88 and also Desktop Station. You don't have to configure something of the CameraS88 in the Desktop Station. Desktop Station can automatically receive S88 sensor data from CameraS88 app. Of course, you need the registration of virtual S88 sensor in the CameraS88 app.
I'd like to show you CameraS88 processing. CameraS88 uses template matching which is a image recognizance method.
Application screen:
Dictionary Image(Template):
Online Image(Target)
Difference image:
CameraS88 divides the image by 16x16 pixels block. You can register areas based on the block(16x16).
If the area includes some different block, CameraS88 regards the area as having a locomotive.
Of course, this algorithm is very common but not the best approach. I will add the other algorithm.
Yaasan
Offline franciscohg
#6 Posted : 29 April 2014 01:24:23(UTC)
franciscohg
Chile
Hello Yasaan, i am trying to setup the new features, but i think i will need more detailed instructions on how to proceed, also, i am having troubles with mfx autorecognition with 0.90 version of Desktop Station.
Francisco
Offline Yaasan
#7 Posted : 29 April 2014 08:03:10(UTC)
Yaasan
Japan
Hi Francisco,
You will find the following instruction.
0. Connect Arduino with CAN-BUS Shield or DCC/MM2 Shield and web cam. If you connect 2 web cams, please check the selected camera later.
1. Run CameraS88 app. *
2. Run Desktop Station 0.9 or later *
3. Open CameraS88 window and click Config button. Please check the selected camera. If ok, close the config window.
4. Click Start button. You need to remove all of locomotives on the rail temporary. After that, move and adjust position of web cam. If finished, click Register button. The dictionary image (template) is registered. You can check the dictionary image on the config window.
5. You need to add monitoring areas like as this video.
6. If added all of monitoring areas, please check whether recognition works correctly or not.
7. Desktop Station can detect data of CameraS88 same as normal S88 decoder. Not need any configuration.
*Step 1 and 2 can change the order.
I captured the above procedure as video. See http://youtu.be/HgRJYg2c95A.
Instrunction of mfx recognization describes at How to add mfx locomotives. However, mfx locomotives are many habits. I can't check all behavior of mfx locomotives. Please note.
Yaasan
Francisco
Edited by user 30 April 2014 03:45:02(UTC)  | Reason: Not specified
Offline franciscohg
#8 Posted : 08 May 2014 02:58:24(UTC)
franciscohg
Chile
Hello, well i have tried to use the S88 camera on the past days, everything seems to work ok, but it seems that my old netbook is not enough for the task, the camera delay is huge!!!!!!!
Will try so set up the systems in my deskop in a few days
Offline Yaasan
#9 Posted : 09 May 2014 23:04:09(UTC)
Yaasan
Japan
Hi franciscohg,
I improve the delay problem. Please download the latest version.
http://yaasan.mints.ne.jp/bin/CameraS88_R2.ZIP
You can adjust skip level which large value means skip rates.
Yaasan
Offline Christoffer
#10 Posted : 10 May 2014 06:54:46(UTC)
Christoffer
Hello Yaasan
very interesting stuff you have here,
maybe you have answered this several times already but i'll ask anyway :
What in terms of hardware do you need for this to work? and where do you buy it? Have you written a complete guide on how to get and how to use ?
this is very interesting for us that have layouts with the track allready ballasted.. so thanks alot ! ThumpUp ThumpUp
Christoffer
Offline Yaasan
#11 Posted : 10 May 2014 10:11:58(UTC)
Yaasan
Japan
Hi Christoffer,
Do you have a marklin MS2? If you have MS2, you use Railuino kits.
Components:
marklin MS2, 60113 (Track box), AC adapter (66361), locomotives, CTrack rails.
Railuino cable kit : http://www.watterott.com...ge=product&info=2872
CANdiy Shield : http://www.watterott.com/en/Arduino-CANdiy-Shield
Arduino UNO R3: http://www.watterott.com/en/Arduino-Uno
USB cable, Windows PC, of course web cams too.
Software (you can get all of the following softwares for free):
Arduino IDE : http://arduino.cc/en/main/software
Desktop Station, Camera S88: http://yaasan.mints.ne.jp/download.html
The detail describes at http://yaasan.mints.ne.jp/ready.html.
If you have questions, please tell me not to hesitate.
Yaasan
Originally Posted by: Christoffer Go to Quoted Post
Hello Yaasan
Christoffer
thanks 1 user liked this useful post by Yaasan
This page was generated in 0.349 seconds.
