Offline Moritz-BR365
#1 Posted : 02 April 2014 11:12:19(UTC)
Moritz-BR365
I will show my little crafting projects I did with my Märklin railway models.
!CAUTION! All these modifications with electrolytic capacitors are for pure digital usage only. Analog usage is not allowed with these modifications or You should add a switch to switch off the capacitor for analog usage and/or use 63V capacitors! !CAUTION!
Starting with my latest LED illumination of my double stack waggons:
For the illumination of my passenger waggons, I use LED stripes, as they can be bought very cheap from Taiwan or China directly by Amazon or eBay. For this project, I used cold white coloured LED stripes. They look quite modern in this waggon.
To illuminate not only the seat areas but also the entry area of each waggon, I split the stripes for the upper deck into 3 parts. One with 3 LEDs for each entry area and one with 9 LEDs for the upper deck seats area. The lower deck is illuminated with one stripe of 6 LEDs.
Here, You can see, that I connected the three parts of the stripes with a short cable, to go around the middle stirrup.
The lower deck stripe is connected to the upper deck stripe with a small self made connector:
And this is, how it looks finally:
First test with a 9V battery and not completely closed:
Now, I connect the power coupler:
The power coupler of both ends are connected with a red wire:
To buffer the energy, I use here two 470µF elko (electrolytical capacitors), the bridge rectifier is mounted on the elko together with the charge resistor and the dropping resistor:
Here again a little plug connector:
The package with the elkon the bridge rectifier and the resisitors is placed here, where it can't be seen from outside:
And this is how it looks like:
These are two possible circuit diagrams. I have chosen the second version:
R1 = 100 Ohm
R2 = 1.65kOhm
C = 2 x 470µF = 940µF
Bridge Rectifier: SMD DF 005
Moritz
Edited by user 06 August 2014 13:19:39(UTC)  | Reason: Not specified
thanks 24 users liked this useful post by Moritz-BR365
#2 Posted : 02 April 2014 11:46:37(UTC)
Moritz-BR365
Märklin NS 1202 - New frontlighting with LED and red rear light
Next project, I will show, is the Netherlands NS1202. This model has a three point front light and two (unused) rearlights. Märklin modelled the light guide for all five lights, but only the white lights are used.
Therefore, I created a circuit board with white-warm LEDs for the head light and red LEDs for the rear light:
I mounted a second circuit board on the mounting point for the old analog drive direction switch:
The circuit borad contains two plug connectors with three connection points. They are to plug in the head light cables:
I know, the front light for Netherland should be yellow and not white!
thanks 11 users liked this useful post by Moritz-BR365
Offline waorb
#3 Posted : 02 April 2014 18:29:42(UTC)
waorb
Brazil
Hello Moritz!
Nice job! Both of them.
The result was beautiful.
I had done a similar job in an ICE 2 that it's not supposed to have lights inside, and was pleasurable to create it from scratch.
Thanks for sharing.
Walter
#4 Posted : 02 April 2014 21:06:04(UTC)
Moritz-BR365
Hello Walter,
thanks, I will post some more little projects. They all are not very complex and easy to rebuild. But I think, they're helpfull for some of you here in the forum.
Moritz
thanks 2 users liked this useful post by Moritz-BR365
#5 Posted : 03 April 2014 09:00:25(UTC)
Moritz-BR365
Ball Bearing for motor shield, gears and gear box:
https://www.marklin-user...r-shield.aspx#post452055
#6 Posted : 03 April 2014 09:18:31(UTC)
Moritz-BR365
LED interior lightning for ICE 1 (33701)
https://www.marklin-user...1--33701.aspx#post452059
#7 Posted : 03 April 2014 10:38:38(UTC)
Moritz-BR365
LED interior lightning for Märklin Pendolino BR 610 (37761)
https://www.marklin-user...olino-BR-610--37761.aspx
Offline JakDah
#8 Posted : 03 April 2014 22:37:32(UTC)
JakDah
Hi Moritz,
Very nice. What connectors are you using and where do you purchase them??
Jakob D.
thanks 1 user liked this useful post by JakDah
Offline Hackcell
#9 Posted : 04 April 2014 06:24:09(UTC)
Hackcell
Costa Rica
Aswesome job!!
Danilo Jiménez
Costa Rica, pura vida!!
thanks 1 user liked this useful post by Hackcell
#10 Posted : 04 April 2014 08:03:26(UTC)
Moritz-BR365
Originally Posted by: JakDah Go to Quoted Post
Hi Moritz,
Jakob D.
Hello Jakob,
I use male and female connector strip like those from Conrad:
Präzisions-Buchsenleiste: http://www.conrad.de/ce/...nic-Inhalt-1-St?ref=list
Präzisions-Stiftleiste: http://www.conrad.de/ce/...amp;rt=detview1&rb=2
Then, I cut them and solder the cable to the connectors solder contact. Then I protect at least one of the contacts with shrinking hose for the case, the cable breaks from the solder contact. Finally, I pull a big shrinking hose over the complete connector strip element, so it looks like a plug and the cable solder contact is protected, too.
Moritz
#11 Posted : 04 April 2014 09:08:24(UTC)
Moritz,
When I do my Led alterations I'm trying to use mini connectors so you can separate the wires from the frame and housing but closer to the application. you've used other electronic parts on your double decker carriages, are they for the protection of led's ? C = 2 x 470µF = 940µF,
Bridge Rectifier: SMD DF 005, the recifier is for flicker free led's ?
#12 Posted : 04 April 2014 11:00:48(UTC)
Moritz-BR365
Hello John,
First, I wanted to solder the connector to the LED circuit board, but then I realized, that there is not enough space between the LED circuit board and the gear box. Therefore I decided to solder the cable directly onto the LED circuit board and place the connector to the circuit board in the middle of the loko.
The elektrolytical capacitors (in germany we call it Elko) are to buffer the LED voltage. For LED interior lightning, 470µF or 940µF are quite enough.
In the NS1202 I use a bigger Elko, because this Elko is connected to the Esu LokPilot decoder. It buffers the decoder, motor and the LEDs connected to the decoder. So it should be up to 2.200µF.
The bridge rectifier is necessary in the double decker carriages, because there, I use the direct rail voltage! The rail voltage is digital voltage and must be rectified before it can be used for LED lightning.
See the full circuit plan of my double decker carriages:
Moritz
thanks 3 users liked this useful post by Moritz-BR365
#13 Posted : 04 April 2014 22:26:14(UTC)
Moritz-BR365
#14 Posted : 04 April 2014 23:02:49(UTC)
Moritz-BR365
Märklin E 60 (37562) with bell-armature can motor and buffer elco
https://www.marklin-user...tor-and-buffer-elco.aspx
Offline seatrains
#15 Posted : 05 April 2014 03:31:27(UTC)
seatrains
Moritz, Excellent Work!ThumpUp
Thom
thanks 1 user liked this useful post by seatrains
Offline Renato
#16 Posted : 05 April 2014 18:46:00(UTC)
Renato
Hi Moritz,
A professional and perfect work !
Renato
thanks 1 user liked this useful post by Renato
#17 Posted : 22 April 2014 12:47:21(UTC)
Moritz-BR365
Märklin Crocodile (3352) with Ball Bearing and HLA motor
https://www.marklin-user...aring-and-HLA-motor.aspx
#18 Posted : 22 May 2014 10:56:22(UTC)
Moritz-BR365
Märklin Hobby 36xxx - mSD upgrade + buffer capacitor
https://www.marklin-user...e--buffer-capacitor.aspx
Content:
- mSD Sound Decoder and buffer capacitor modification for Märklin Hobby models
- Description of soldering contacts on mtc21
- Experience with mSD decoder with buffer capacitor
#19 Posted : 23 May 2014 12:17:22(UTC)
Excellent job. Thanks for sharing.
I have very liltle understanding about electronics, so I ask; Doesnt R1 get a bit warm¿?
Also; Is one R2 needed for every LED in the strip?
#20 Posted : 23 May 2014 13:22:33(UTC)
Moritz-BR365
Hello Henrik,
if we talk about this picture the lower circuit:
then let us calculate:
U = 18V
R = R1 + R2 + R(LED) (I don't know R(LED), therefore we simplify to R(LED)=0 Ohm, worst case)
R = 100 Ohm + 1.650 Ohm = 1.750 Ohm
I (total) = U / R = 18 V / 1.750 Ohm = 0,01029 A = 10,29mA
Remark
I(total) = I(1) + I(2); But when the capacitor is fully loaded, then I(1) = 0A! Therefore, we can calculate with I(total) = I(2) = I !
Now, we continue...
U(R1) = R1 * I = 100 Ohm * 0,01029A = 1,03 V
U(R2) = R2 * I = 1.650 Ohm * 0,01029 = 16,97 V
U = U(R1) + U(R2) = 1,03V + 16,97V = 18V (Yeah, we have done no mistake!)
1st Question
Now, we come to Your question, if R1 will get a bit warm:
P = U * I
P (R1) = U(R1) * I(total) = 1,03V * 0,0103A = 0,01 W !!!
R1 is rated for 0,5 W !
==> We use R1 with 2% of the maximum rated power. It will not become warm!
2nd Question
No, R2 is for the whole LED stripe. On the stripe there are already resistors mounted for each 3 LEDs in one group, but they are not enough, because it will be too bright. Therefore, I use one R2 for the whole stripe.
Moritz
thanks 5 users liked this useful post by Moritz-BR365
Offline jonquinn
#21 Posted : 31 May 2014 05:13:21(UTC)
jonquinn
Thanks for the outstanding post with diagrams and instructions. This is one of the best "how to do it" posts I've seen done here.
thanks 1 user liked this useful post by jonquinn
#22 Posted : 03 June 2014 09:17:09(UTC)
Moritz-BR365
Trix V80 (22075) with driver's cabin light
Conversion of a Trix V 80 005 (22075) by using the not documented but existing AUX port, mapped to F1, for a driver's cabin light.
Offline waorb
#23 Posted : 03 June 2014 16:33:34(UTC)
waorb
Brazil
Hello Moritz!
Nice job! How did you learned/discovered that 'not used AUX port'?
Walter
#24 Posted : 03 June 2014 20:34:47(UTC)
Moritz-BR365
Hello Walter,
the info about the free AUX port came from here: http://www.web-hgh-moba....omotiven#anschl%C3%BCsse
To activate the AUX port, You have only to use the F1 function. In case You use a MS2, You have to assign a function symbol to the F1 button:
Now, You can switch on/off the AUX port.
Moritz
#25 Posted : 14 June 2014 19:13:32(UTC)
Moritz-BR365
Märklin 191 099-1 (3329) - Self made LED circuit board with red rearlights
Perfboard with SMD LED for head lights and rear lights
#26 Posted : 31 July 2014 08:05:21(UTC)
Moritz-BR365
Silence pickup shoe for Märklin MaK locos
How to convert a standard pickup shoe from a Märklin MaK 1206 (37635) into a silence pickup shoe. This conversion is usefull for the following locos:
- 33641
- 33642
- 33645
- 37626
- 37627
- 37630
- 37631
- 37636
- 37641
- 37642
- 37643
- 37644
- 37645
- 37646
- 37647
- 37656
- 37657
- 37658
- 37659
- 37693
- 37694
Edited by user 31 July 2014 16:31:40(UTC)  | Reason: Not specified
#27 Posted : 04 August 2014 08:50:42(UTC)
Moritz-BR365
Märklin Einheitsmesswagen 49960 - Conversion to DCC Decoder
Replace the decoder with a DCC function decoder and white-red switchable headlight
#28 Posted : 06 August 2014 08:09:42(UTC)
Moritz-BR365
New:
Märklin BR 185 (36850) with low beam, high beam and rear light
How to implement a new light board, ased on Märklin E190372, high beam LEDs must be soldered by your own.
Offline GlennM
#29 Posted : 12 August 2016 12:51:02(UTC)
GlennM
R1 = 100 Ohm
R2 = 1.65kOhm
Moritz
Moritz,
My apologies if I am asking a questions you have already answered but I cannot see it anywhere.
Who's LED lighting stripes do you use, do you have a recommended supplier?
And how do you secure them to the inside of the coach roof, glue or double-sided sticky tape?
You seem to be using the standard earthing clips from Marklin to trasnfer the earth to the wheels?
How do you transfer current from one coach to the next, or is each coach wired with its own slider?
BR
Offline biedmatt
#30 Posted : 12 August 2016 13:20:11(UTC)
biedmatt
Glen, Search "high density LED strips" at your ebay site. The strips come with an adhesive back, but clean to roof of your wagen with rubbing alcohol so they will reliably stick. I chose warm white for my era 3 equipment.
http://www.ebay.com/sch/...+led+strips&_sacat=0
Matt
Era 3
Offline GlennM
#31 Posted : 12 August 2016 13:33:13(UTC)
GlennM
Thanks Matt.
I am looking forward to having a go at this, I especially think the double decker coaches look great with internal lighting.
BR
#32 Posted : 12 August 2016 13:51:52(UTC)
Moritz-BR365
Hello Glenn,
I buy 5m stripes from eBay or Amazon, directly from China. Is most cheapest way, like this one: http://www.ebay.de/cln/t...ite-600leds/323238835012
600 LEDs/5m is better then 300 LEDs/m!
They have self-adhesive back, normally original 3M tape!
The coaches have the common 1-pole power coupler (RTS-coupler):
As You can see, the RTS-coupler is connected via a relais (FTR B3S) directly to the track voltage! The relais is switched on/off from the function decoder. This is to secure the function decoder. But this cause, that each coach must be equipped with a voltage rectifier, buffer capacitor, ....
This is a complete view of the circuit:
Offline GlennM
#33 Posted : 12 August 2016 21:04:08(UTC)
GlennM
Hello Glenn,
Moritz,
Thanks for this, I have followed your many conversions and projects with interest and I am looking forward to having a go. My only problem is when it comes to electronics I know less than nothing, the only good thing going is that I recognise I know less than nothing LOL LOL LOL LOL LOL
All the best ThumpUp ThumpUp
This page was generated in 1.148 seconds.
