Offline Armando
#1 Posted : 31 March 2014 18:24:44(UTC)
Armando
Hello all,
I have been trying in vain to remove the body on my BR 39, Märklin 39390, in order to install the smoke unit.
I followed the instructions, as per the operations manual. However, after removing the 4 screws, as per the diagram on page 29, it is still not possible to lift the cabin. Maybe there is an additional step, which is not shown in the manual, that needs to be taken before being able to remove the body.
Has someone on this forum ever open this locomotive or any of its successors?
Here's a link to the operations manual. Page 29.
http://medienpdb.maerkli.../1/pdf/39390_betrieb.pdf
(In order to open the manual, the link address needs to be copied and pasted onto the browser field)
Thank you and best regards,
Edited by user 31 March 2014 22:12:34(UTC)  | Reason: Repasted link
Armando García
Offline kbvrod
#2 Posted : 31 March 2014 19:42:51(UTC)
kbvrod
Hi Armando,all,
The link did not work for me.can't you insert the smoke unit through the stack?
Dr Dirt
Offline Renato
#3 Posted : 31 March 2014 19:54:10(UTC)
Renato
Hi Kevin,
Copy and paste the link in your browser (Märklin does not allow to reach their site clicking on the link with the mouse and only the Märklin logo is displayed).
Renato
Offline biedmatt
#4 Posted : 31 March 2014 20:17:11(UTC)
biedmatt
The screws are clearly shown in the instructions. I'm guessing you removed the right four screws. Probably something stuck, like two painted surfaces sticking together. Pull harder.
Matt
Era 3
Online steventrain
#5 Posted : 31 March 2014 20:47:27(UTC)
Hi Armando,all,
Dr Dirt
Renato said 'Copy and paste the link in your browser' the link below
http://medienpdb.maerklin.de/product_files/1/pdf/39390_betrieb.pdf
Offline kbvrod
#6 Posted : 31 March 2014 21:17:50(UTC)
kbvrod
How 21st century of M,..........ThumbDown
I proved links here all the time.As was provided above.Just a wee bit cranky I guess,...BigGrin
D
Offline Armando
#7 Posted : 31 March 2014 22:08:55(UTC)
Armando
Hi Armando,all,
Dr Dirt
No, it is not possible, as it is the tapered smoke unit, that has to be inserted from under the stack. And in order to do this, the body needs to be removed.
Armando García
Offline Janne75
#8 Posted : 31 March 2014 23:29:33(UTC)
Janne75
Hi Armando,
Does the locomotive body move at all? What about the cabin, does it move at all? When I see the exposing diagram on page 36 it is clear for me that there are those four screws that hold the body/boiler. As you have removed them already you should just try to lift the cabin harder and before doing this I recommend that you try to move it also little sideways to get it to loose, but don't use much force for this. There can be some tabs or pins which can hold it too, who knows.
I will get this 39390 BR 39 Insider and also 37915 BR 03.10 Insider after some weeks/around one month. 39390 is mint like new, but 37915 has some broken parts and I will fix it.
Please let us all know how you will progress with this 39390 loco body removal as I want to install smoke unit too, if there is not one already.
Edit: It looks like there is a groove in the loco tender/cabin and you should just try to get it to loose and then lift it up. Look at the photos on pages 29 and 36.
Good luck! RollEyes
Janne
Offline Shamu
#9 Posted : 01 April 2014 06:34:03(UTC)
Shamu
How do,
I could be wrong but from what I can make out in the manual and in the exploded parts view http://www.maerklin.de/s...&artikelnummer=39390 it looks as though it may be binding on the "tanks ?" that protrude thru the footplates along the sides of the boiler.
Maybe try removing the cab first ?
Just a thought. So had to advise "brut force" without seeing the loco in front of me.
Best of luck.
Online steventrain
#10 Posted : 01 April 2014 17:55:43(UTC)
I look at page 29 of 39390.
It show '1' removed four screw and '3' removed cab and body.
Where is '2'?, Cant find it.
Offline Armando
#11 Posted : 01 April 2014 23:55:00(UTC)
Armando
Hi Steven,
Yes, that was one of the first things that I noticed. However, it is possible to understand that 1) you remove the screws, 2) Remove the cab, and 3) remove the boiler.
The problem is that after removing the 4 screws, the cab will not come off.
Armando García
Offline Shamu
#12 Posted : 02 April 2014 00:50:58(UTC)
Shamu
Morning Armando,
Ok, this is purely based on looking at the exploded parts view I provided above (view at 300%) and my old Piko BR01.
Try gently applying outward pressure on the inside of the cab as this has to come off first, there "may" be locating tabs at floor level on both sides that have to be released.
As to the boiler, looking at the exploded view I can see 7 locating "pins" and depending how the screw holes are aligned that could be another 4, so that's 11 possibly tight'ish connections that need gentle persuasion.
Is there any movement at all in any direction ?
thanks 2 users liked this useful post by Shamu
Offline Armando
#13 Posted : 02 April 2014 17:06:36(UTC)
Armando
Morning Armando,
No, unfortunately, it is rock-solid Crying
Armando García
Offline Shamu
#14 Posted : 03 April 2014 00:40:49(UTC)
Shamu
Morning Armando,
Hummmm,
This is starting to become a real worry, mainly as the "worm drive gear" is supposed to be greased every 20 hours.
I'm trying to think what I've got that is close but coming up a blank ATM.
Need to think on this a bit more. Will see if I can come up with something in a few hours.
So sorry Armando that this is happening, chin up.
Arh, just to clarify, did you buy it new or is it second hand ? Just curious in case a previous owner did something silly.
Also just to rule out the really stupid (yes I know there shouldn't be one) there isn't a plug in one of the dome tops is there ?
Offline Shamu
#15 Posted : 03 April 2014 05:11:01(UTC)
Shamu
OK,
Grasping at straws here BUT, if you look at the photo (red circled bits) it looks like tabs "may" hook thru and onto here from the boiler. OR maybe slide boiler forward (or backward) then up Confused it would only be 3mm at a guess.
See if they are visible from underneath ?
If so and there are tab hooks try a bit of gentle persuasion.
Beyond that I'll have to un-crate a few of my newer loco's to see what I've got that's similar, though I don't think my BR 03.10's are that similar but who knows Confused
Sorry Armando, I've looked thru all my loco's and nothing I have comes even remotely close in the "pull it to bits" department.
Hope the advice above is the trick ? ARH, then there is still the issue of those locating pins, This has me stumped.
Ok, the locating pins will stop forward/backwards movement so those little red circled recesses must be for small hook tabs, you might (if their there) need to use a small screwdriver to tease them out, use a toothpick to slip into the gap then do the other 3. It the only thing that makes sense to me.
Edited by user 03 April 2014 12:26:33(UTC)  | Reason: Final thoughts
Shamu attached the following image(s):
Offline waorb
#16 Posted : 03 April 2014 15:10:05(UTC)
waorb
Brazil
Hello Armando!
This is not a solution, but maybe you could find a clue in this link:
http://www.railroad24.de/modellbahnbilder/bilder.php?id=1596
It shows an already openned BR 39 in good detailed photos...
Good luck.
Walter
thanks 2 users liked this useful post by waorb
Offline Shamu
#17 Posted : 04 April 2014 03:13:57(UTC)
Shamu
Thanks for the link to those photos Walter,
Starting to wonder if in usual Marklin instruction manual fashion that that boiler AND the catwalk/cab base don't come off as a unit ?
Although its a beautiful loco there is nowhere on the boiler you can firmly hold it without risking doing serious damage.
If it is like my old Piko BR 01 than that is the way it comes off, from memory it had 2 tongues that held it on after the screws came out.
Just have to wait for Armando to report back before damaging any more brain cells.
Offline Armando
#18 Posted : 04 April 2014 04:18:01(UTC)
Armando
Thanks to everyone who posted his comments and suggestions in response to my question.
The pictures that were posted by Walter (obrigadinho!) were most enlightening. And Shamu was right: As it turned out, the boiler and the cabin are to be removed together by lifting the boiler. I pulled firmly at the very front of the boiler, on both sides, where the walkway tapers off towards the front. The front end of the boiler could be lifted off the chassis, and I was finally able to remove the body, slowly and carefully, in order not to brake any of the separately applied parts, which are many, and fragile on this locomotive.
Obviously, the Märklin instructions are flawed. They show that the cabin is to be removed first. Luckily, I didn't try to pull it off too strongly, because otherwise, I could have broken off the roof part.
My warmest thanks again to all. I am now proceeding to install the smoke unit, and check for the level of Trix grease in the gearbox.
Armando García
thanks 2 users liked this useful post by Armando
Offline Shamu
#19 Posted : 04 April 2014 04:39:56(UTC)
Shamu
Fantastic Armando,
That was my major concern for you if no solution was found, putting grease in the worm drive every 20 hours.
For something that MUST be done on a regular basis not providing clear instructions for disassembly could be disastrous for someone.
Glad the penny finally dropped.
All the best, now you can enjoy that 39. BigGrin
Perhaps someone fluent in German could contact Marklin about this issue and ask them at the very least to "modify" the on-line PDF so at least the solution is somewhat easier to find for those other owners of this fine loco that maybe don't go to Forums for their information ? ThumpUp
#20 Posted : 04 April 2014 04:40:00(UTC)
Armando, I've looked at the detailed photos and one can say there has been a lot of work gone into it to reproduce it like that. One thing I would like to see from Märklin is to use the spare room especially with all the electronic circuit board (waste of space) to replace it with metal to make the loco even heavier.
Offline Armando
#21 Posted : 04 April 2014 05:57:33(UTC)
Armando
Hi again,
I actually wrote to the Märklin Service earlier this week to ask them to look at the instruction manual and check that a mistake had not been made. Their reply was that of course I had to follow the instructions to the letter and remove the cabin first. They even "advised" me to check that I had removed the right screws.
I hope that somehow, somebody will be curious enough to follow up on my question and that the manual eventually be corrected.
Cheers!
Armando García
#22 Posted : 04 April 2014 09:17:27(UTC)
Hi Steven,
I have opened this locomotive twice to oil her,it is impossible to make a mistake,there are only 4 screws under the locomotive.I removed the screws and i remove the boiler and the cab together in one piece i do not seperate them.I have just do it in a few seconds now to be sure for what i am saying.I hope i help you,regards from Greece.
Offline biedmatt
#23 Posted : 04 April 2014 13:33:32(UTC)
biedmatt
I installed a smoke generator in my 39393 and upgraded to a LoSnd V4. I do not remember anything being special about opening it up. If the instructions were wrong, I would have remembered it. Something has the pieces stuck together. This has happened to me before. Perhaps some paint had not fully cured, or some substance during assembly. Try gently prying with a fine blade screwdriver between the two mating surfaces (post #4: "pull harder"), or send it back and let Marklin deal with it.
Matt
Era 3
Offline Armando
#24 Posted : 04 April 2014 14:46:28(UTC)
Armando
Hi Steven,
Thank you Foumaro. However, I tried following the instructions, as per the Marklin booklet. The instructions seemed clear: First remove the screws, then remove the cab, and then remove the boiler. However, the cab would not come off. The same is shown in the explosion drawing of the locomotive. It wasn't until I saw the pictures in the link published by Walter that I realized that it wasn't necessary to remove the cab to lift the boiler.
Armando García
thanks 3 users liked this useful post by Armando
Offline Gert-Jan
#25 Posted : 09 January 2015 09:20:13(UTC)
Gert-Jan
As often with manuals, it is challenging to get it readable for all situations and interpretation
Page 29 should have been about removing/lifting the whole body.
My thoughts are they shouldn't have depicted the removal of the cabin at this page.
I 'guess' (guessing is basically wrong from start) the procedure steps should have been (from left to right):
1. Removing the 4 screws
2. Lifting the whole body
3. Remove the Cabin (optional)
Anyway, I had the same 'stuck' issue with my 39644 BR 64 'Bubikopf'
The body didn't just simply lift off as it was 'glued' on the chassis.
Mosty era III DB.
#26 Posted : 09 January 2015 10:11:43(UTC)
Sometimes it requires a bit of force to seperate parts assembled at the factory. When I tried to remove the top of the tender on my 37972 Br34 it was so well held together that when it "let go" I broke the tie bar connecting the loco to the tender. I had to order the part and then spent the best part of a couple of hours replacing it. Not an experience I would care to repeat!
Offline SteamNut
#27 Posted : 09 January 2015 18:05:54(UTC)
SteamNut
As a side note the lubricating instructions says that the axes and the side rods should be oiled after 40 hrs. First time that I have seen that the side rods need to lubricated.
I added the Marklin smoke unit to mine and it is a very tight fit because it rubs towards the front of the lok. Also don't push it up all the way leave it a little down to make sure makes contact with the copper strip. I run this lok on a analog system and it really does not smoke. I suspect if I would use a Seuthe #20 it would work better because the voltage rating is lower to make it work. When I apply full voltage on my work bench the Marklin does work nicely and would most likely work great on a digital system. It's a great model and runs great on my M track - Fred
Edited by user 09 January 2015 22:31:13(UTC)  | Reason: Not specified
Offline Token
#28 Posted : 10 January 2015 00:47:29(UTC)
Token
Hi all, at the risk of asking a dumb question and for my own reference (as I have two of these beautiful machines), the exploded diagram appears to indicate the smoke box cover can be removed independently. Could the smoke generator have been installed from the front or is it too large to access?
Michael.
Offline SteamNut
#29 Posted : 10 January 2015 02:06:28(UTC)
SteamNut
It's really not that bad once you remove the body just a tight fit remember you have to push it some force so the front access won't do you any good.
This page was generated in 1.318 seconds.
