Offline johnalexander16
#1 Posted : 31 March 2014 10:42:07(UTC)
johnalexander16
Hi All
I have question regarding Marklin turn out motors. I have had 2 batches that just die. They work well for a few months then start operating in one direction and then usually stop altogether.
Anybody else have the same problem ? Any solutions ?
Best wishes
#2 Posted : 31 March 2014 10:45:44(UTC)
Originally Posted by: johnalexander16 Go to Quoted Post
Hi All
Best wishes
Can you expand on your comment with some examples, ie part/item numbers?
There was a problem many years ago with the K-track motor and the end shut-off switch, and I recall a topic a while ago regarding some C-track motors failing early.
Steve
Offline Shamu
#3 Posted : 31 March 2014 14:00:53(UTC)
Shamu
Hi All
Best wishes
Steve
Yeah, I recall that as well and from what I remember there was a fix (of sorts) for it.
I'm knackered and about to hit the sack, I'll have a snoop tomorrow morning and see if I can find the thread or article about it, hopefully with the fix (bodge)
Offline MikeR
#4 Posted : 31 March 2014 14:57:14(UTC)
MikeR
Hi John
Apparently the problem is the micro switches located at the each end of the coil. These fail after some time but as long as you are using a digital system these can be 'shorted out' as the system will limit the pulse length needed to switch the turnout. In analog mode the micro switches can also be 'shorted out' as long as you are careful to limit the length of the pulse used to switch the turnout..
Have a look at the link below which includes a video showing how you can correct the problem on the 74990/1 turnout motors. I have applied this procedure to all of my turnout motors and to date have had no problems. Friends who have been running trains for some years have also applied this procedure and the turnout problems they had disappeared.
https://www.marklin-users.net/fo...rs-74990.aspx#post405391
Member of ETE
thanks 2 users liked this useful post by MikeR
Offline Shamu
#5 Posted : 01 April 2014 02:03:41(UTC)
Shamu
Morning John,
I've spent all morning trolling and can not find the article I was thinking about however the post Mike has referenced above covers the same details as the one I can't find.
Guess the only difference was it has step by step photos as opposed to a video, (easier for old gits like me to follow).
Best of luck with them, I'm starting to get worried myself now as I have around 60+ of them packed away until we move to north Qld later this year (new layout, yippee!) and all of them are well and truly out of warranty.
#6 Posted : 01 April 2014 03:03:59(UTC)
John,
there have been 2 scenarios with turnout solenoids,
K-track: these solenoids had been faulty for one reason: the solder had overlapped two separate electrical circuits and therefore the power was never switched off and eventually they've burned out. or if they don't wok, the end cut off power plate is not touching the contact.
C-track: 2 faults I've experienced: a.) the circuit board was faulty: no contact, b.) the micro switches: what I've noticed the micro switches lever didn't have the spring action anymore to go back to the starting position: reason: when they've soldered the micro switch onto the circuit board with excessive heat and therefore diminishing the spring action of the lever, the result: no more electrical contact, the same happened with the C-track switching tracks (micro switch)
This page was generated in 0.571 seconds.
