Offline MSanches
#1 Posted : 05 March 2014 09:34:03(UTC)
MSanches
Anyone recommend a good book or e-site about the right way to do wiring and connections on a layout?
I'm a relatively expereinced modeler from Portugal, bu need to improve my skills.
Many thanks in advance.
Offline Irish Rail
#2 Posted : 05 March 2014 11:45:00(UTC)
Irish Rail
Ireland
I found this from another post here and it might be of use.
http://www.macbeth66.com...rklin_Wiring_Booklet.pdf
thanks 1 user liked this useful post by Irish Rail
Offline MSanches
#3 Posted : 05 March 2014 13:49:04(UTC)
MSanches
Many thanks for yr info.
Actually, i'm working with CS2, and looking for something more updated.
Miguel
thanks 2 users liked this useful post by MSanches
Offline Irish Rail
#4 Posted : 27 March 2014 16:37:47(UTC)
Irish Rail
Ireland
I can see why, Miguel. Me too. The digital wiring process is not clear - there are lots of different elements but their functions are not stated. Is there a difference between signal and power? Are these provided separately? Or over the data bus? If there was a simple explanation of digital wiring, I would also appreciate it.
Offline kbvrod
#5 Posted : 27 March 2014 17:28:24(UTC)
kbvrod
Boyo,you need to tell us what your planning to do.MS?CS? How many trains/signals/accessories?
Dr D
thanks 1 user liked this useful post by kbvrod
Offline Irish Rail
#6 Posted : 27 March 2014 18:50:41(UTC)
Irish Rail
Ireland
Dr D
I'm not ready for that level of detail, Dr D. But trying to understand the options is very confusing. I need to understand the electrical and logical basics of how it all works. I understand analogue, no problem. I understand digital data, busses, etc. What isn't clear to me in the Marklin Digital world is the bus design, wiring and connections; the supply of power to the circuit (locos, solenoids, accessories); and the function of the various "boxes" e.g. converter, power pack (why are there so many?); decoders (why are there so many?); the data structure of the bus and its wiring. Does that make sense?
I'm looking at p542 of the current full line Marklin catalogue. There is a 6017 bus, a Marklin bus, and an S 88 bus. There are power supplies, boosters, and transformers but no indication of how power is distributed.
I don't want or expect detailed answers here, but is there any technical documentation that helps explain all this?
Offline Danlake
#7 Posted : 27 March 2014 19:41:43(UTC)
Danlake
The schematic drawing of the Marklin digital systems you are referering to shows all the possibilities. That does not mean that you will need a 6017 bus, but merely that you can use a 6017 unit as a separate booster (note how the tracks are divided into blocks on the drawing). The use of bus is probably a bit confusing it’s more just showing how the connections should be made.
I haven't found any good books in English but I believe something is available in German.
If you are very keen I found the best source of material to be the digital newsletter from the Marklin digital club. When you sign up you can buy copies of all the old newsletters as well. They actually do contain a lot of info and shows the development of the system and more importantly gives a hint of the design concept and how Marklin thinks you should be using the various components. https://www.marklin.com/club/
But else ask specific questions here.
Brgds - Lasse
thanks 3 users liked this useful post by Danlake
#8 Posted : 27 March 2014 21:17:48(UTC)
I would recommend (as usual) the Märklin 07421 Electric Manual "Controlling Switching Running" even if it's based on the earlier CS1 as the main digital controller.
Must be the most overlooked book ever by model railroaders, even if it is the best one around as I know of...
Shows both analog and Digital connection principles...
Could maybe still be found on Ebay or Amazon...
Offline kbvrod
#9 Posted : 27 March 2014 21:40:47(UTC)
kbvrod
Well,lad you had better start!LOL
If your layout is small,you can do such a certain way,if it large and your train control gets a wee bit more complicated,ya have to rethink it.Depend what ya want to do.You getting my drift boyo?Tongue
D
Offline Irish Rail
#10 Posted : 27 March 2014 22:43:12(UTC)
Irish Rail
Ireland
Good news. 07421 is available from the Marklin online shop!! Thanks, guys. That looks like just what I need right now.
One question before I order it: is the current transformer (66470) a direct equivalent of the old blue transformers? Going to need another transformer anyway...
Offline Danlake
#11 Posted : 28 March 2014 04:33:49(UTC)
Danlake
Yes -that is the new type of 16VAC transformer. Please note that these types are not to power mobile stations/central stations etc. They need the special switch mode powerpacks.
Brgds - Lasse
Offline Irish Rail
#12 Posted : 31 March 2014 19:53:33(UTC)
Irish Rail
Ireland
Thanks for the advice. 07421 Electrical Manual has been ordered, as well as a new transformer. Oh, and the Catenary Manual, too (there is a long-term development plan).
Hopefully, my next set of questions will be much better informed? :)
Offline Irish Rail
#13 Posted : 07 April 2014 22:36:15(UTC)
Irish Rail
Ireland
07421 Electrical Manual - Controlling, Switching, Running has arrived. And it does the trick for me, mostly.
The book is a hardback in landscape layout with just over 100 pages, divided into five sections, copyright 2007. Production values are high, but the editing and translation could have been better. Sometimes the English is difficult to understand and some of the diagrams have not been translated from German.
Having bought this book to answer a number of questions, and having read through the book once, I can confirm that almost all my questions were answered. The book give all the basics of electrical operation in analogue mode, and, by going through the development of the Marklin digital products, it explains and positions all the various products, what they do and what they work with. Up to page 23, the discussion is of analogue operation, then Delta, 6021 (and all its related modules); why boosters are needed and what they do; Mobile station, connections and the reason for different power supplies; Central Station and its basic connections.
Section 3 deals with Solenoid accessories - analogue for all three track types; turnout decoders, k83 and k84 decoders; Signals (analogue and digital operation, their control boxes, etc.).
Section 4 deals with electrical accessories and the controllers for them - the difference between 72730 and 72740 and where to use each. Also special accessories - transfer table, turntable, grade crossing, rotary crane, mobile crane.
Section 5 is about automating a layout, the tools and how to use them. Reed switches, contact tracks, block operation, braking module, etc.
Every section has lots of big, clear wiring diagrams that really illustrate how to incorporate each element into the overall circuit and its control. With a little more attention to detail in the editing and translation, this would have been almost perfect. As it is, for a native English speaker, there are occasional phrases and sentences that are a little difficult to interpret, but still comprehensible. The diagrams are superb.
Overall, I would recommend this book for anyone who isn't entirely clear on how to wire an analogue or digital circuit. It will also help those starting with digital to determine which pieces they need and how they go together.
Thanks for the recommendation, Webmaster (should I bow, your lordship?) ;)
thanks 3 users liked this useful post by Irish Rail
#14 Posted : 08 April 2014 20:15:24(UTC)
Of course you may bow if you wish to... LOL LOL LOL
This is by far the best "electrical wiring" book so far from M, and I hope there will be an updated one including CS2/MS2, new signals and such soon...
Offline Irish Rail
#15 Posted : 09 April 2014 10:20:16(UTC)
Irish Rail
Ireland
*bowing deeply*
Note that it includes a section on the 76XXX signals for both analogue and digital connections.
The MS refers to 60652 and the CS to 60212
#16 Posted : 09 April 2014 21:37:55(UTC)
Hey, sent a question to M about a possible update to the book - and got this answer...
Dear Mr. Palm,
thanks for your question.
In the near future we will have a new book which has also included CS2/MS2 and other newer Digital features too.
Sincerely yours,
your account manager
Markus Schurr
Gebr. Maerklin & Cie. GmbH
Customer Service
P.O. Box 960
73009 GOEPPINGEN
GERMANY
Phone: +49 7161 608 222
Fax: +49 7161 608 225
E-mail: Service@maerklin.de
Website: www.maerklin.com
thanks 5 users liked this useful post by Webmaster
Offline BwanaJoe
#17 Posted : 21 March 2015 18:40:53(UTC)
BwanaJoe
May I ask how this book compares to Model Railroad Electronics 2 - Digital Trains by Rutger Friberg?
#18 Posted : 23 March 2015 06:15:50(UTC)
Totally different aim. Rutgers books are for hobbyists wanting to add various features, gimmicks, control etc via electronic projects onto an already existing system. The Marklin book is about how the various Marklin off-the-shelf items work together and possibilities for expansion. HTH
Steve
Offline Memeyer2020
#19 Posted : 08 September 2020 06:49:37(UTC)
Memeyer2020
Costa Rica
THANKS A LOT FOR THIS CLASSIC MANUAL.
IT'S A HUGE HELP FOR BEGINNERS WITH LIMITED EXPERIENCE OR KNOWLEDGE ABOUT ELECTRICAL PRINCIPLES FOR LAYOUTS.
REGARDS,
DR. GUILLERMO MARTÍNEZ
thanks 1 user liked this useful post by Memeyer2020
#20 Posted : 08 September 2020 11:42:14(UTC)
Can we please not type in full capitals, doing so in internet speak is equivalent to shouting at everyone.....
I cringe every time I see this happening....
Layout wiring (General MRR)
by Mr. Ron 05/03/2021 19:34:46(UTC)
layout wiring options (Model railroad wiring)
by biswasg 13/01/2021 21:46:39(UTC)
Basic Layout Wiring (Model railroad wiring)
by Drjoe11 13/03/2019 17:01:20(UTC)
Noch Cortina Layout Wiring Instructions (Small scale)
by Bob24 09/03/2019 07:53:36(UTC)
Multiple Viessmann 6096 (or other) street lamp layout wiring (Digital)
by Hhjg2y 27/03/2017 20:33:11(UTC)
Layout wiring -analog turnouts,signals & other accessories (General MRR)
by cmobrienjr 31/01/2017 20:49:35(UTC)
layout wiring (Model railroad wiring)
by ASz 25/03/2014 18:52:50(UTC)
Z Cortina layout wiring (Model railroad wiring)
by michaelp 25/11/2012 23:23:57(UTC)
This page was generated in 0.885 seconds.
