Offline glight1
#1 Posted : 01 February 2014 01:39:32(UTC)
glight1
I am considering converting my 33951 BR 03 Delta Locomotive.
I have never attempted a conversion before and I haven't soldered anything for quite some time. My digital knowledge is limited. In the exploded view of the tender of this Lok, the decoder looks very different from what I have.
Should I get a 60760 conversion kit with both motor and decoder, or just buy the 60942 decoder? The Loco lacks the gradual speed steps and doesn't maintain a consistent speed. Also, the reversing light is mounted directly onto the Delta decoder board. Do I need to buy the 61008 2-pin light bulbs? Any advice or tips would be most welcome.
Gary
[img]http://www.mejuba.com/member/functions/PicturesResize.ashx?aspect=1&height=&width=546&path=//174.142.61.69/e/1/1d17787f-0d7a-4e9c-851b-7441e3865fe8.jpg!546[/img)
glight1 attached the following image(s):
Offline franciscohg
#2 Posted : 01 February 2014 02:05:51(UTC)
franciscohg
Chile
Hello Gary, i think the 60760 is your better choice, you get a basic decoder plus the parts for converting the DCM motor, 60942 is just the decoder, you will have to get the motor parts separately.
Using the 60760 you can always add a better decoder later.
As for the lights I dont have that particular loco and your picture does not load....
Offline glight1
#3 Posted : 01 February 2014 02:16:22(UTC)
glight1
francishohg,
I attached the pic of the decoder with the bulb.
Offline franciscohg
#4 Posted : 01 February 2014 02:22:29(UTC)
franciscohg
Chile
Hi, yes, now it loads.
More "challenging" task, you may try to fit a socket for a two pin bulb or a more radical solution that i have used in similar locos may be to cut the pcb keeping the parts that just allows you to keep the bulbe in the right place, then cut the strips on the pcb to isolate the bulb for other remainings parts of the circuit and sold the feeder wires there
thanks 3 users liked this useful post by franciscohg
Offline glight1
#5 Posted : 01 February 2014 02:37:36(UTC)
glight1
Thank you franciscohg. I think that I am going to have to do some 'practice soldering' before I attempt anything yet.
thanks 1 user liked this useful post by glight1
Offline biedmatt
#6 Posted : 01 February 2014 04:24:54(UTC)
biedmatt
I like lights for the headlamps on my lokos. They look like they should and not give the odd colors LEDs provide. I've done conversions with similar decoders. To salvage the rear lamp, I cut the circuit board just in front of the holes for screw and locating post. This provides the room needed for the new decoder. I remove the rest of the stuff from the board except the lamp socket. I then solder the two lamp leads from the decoder either directly to the socket or to circuit foils on the board leading to the lamp socket. Now you do not have to fabricate some way to hold the lamp socket, you've salvaged the bit of the board you need to keep it just where Marklin placed it.
LOL Looks like Francisco and I do the same thing.
Matt
Era 3
thanks 3 users liked this useful post by biedmatt
Offline Chook
#7 Posted : 01 February 2014 04:51:35(UTC)
Chook
Gary, with the soldering, use a resin cored solder for this electronic work. The thinner the better and get the stuff with lead in it as it is much easier to use especially when just starting off and learning.
As Francisco has suggested you can cut the existing printed circuit board so that the mounting holes and lamp securement are preserved.
The most difficult parts of the soldering are firstly identifying the tracks that you want to use and secondly preparing that track to take the solder.
You could simply solder your new wires from the decoder to the existing solder "blobs" which the lamp wires are already using. If however you want to use the track then you will have to VERY gently scrape the conformal coating (that green stuff) with a scalpel blade or similar. A you remove the coating you will see the bright copper underneath.
The actual soldering process - less solder is better and be careful with the amount of heat that you use on the tracks. The glue that they use to stick the copper to the fiberglass board is good but it does have its limitations when it comes to heat. Keep the time that you have the tip on the copper down to less than say 4 seconds.
Remember to "tin" your wires before applying them to the printed circuit board. Strip about 2mm of the insulating plastic from the end and then apply the soldering iron tip to the wire and also the solder to both the wire and the tip simultaneously. Yes you need 3 hands but with practice you will get the hang of it. You will notice that as you apply the heat to the wire that the remaining insulation will heat up and retract exposing more wire. You can cut the excess wire later before terminating it onto your printed cct board.
I also keep the tip of my soldering iron clean by using a damp (not wet) cloth. Simply apply some solder to your tip and wipe it onto the cloth. That solder will attract the rubbish and the be removed by the wiping action.
If your joints start to take on a grey rather than a shiny look it means that you are overheating them and causing the lead to evaporate and leaving more tin on the joint. Better to just reheat that that joint and flick the solder off. (wear safety goggles or glasses!)
Enjoy.
Regards............Chook.
thanks 5 users liked this useful post by Chook
#8 Posted : 01 February 2014 06:45:28(UTC)
there are a lot more led's on the market than there used to be especially with the right colour scheme but they are not always easy to find, I've bought some rectangle led's last year and now they are no longer available, I bought them for my SBB Re 4/IV locos but didn't buy enough of them. Led's can be bought to day as white, golden white, sunny white but most of the dealers just order the main lines, I bought some led's years ago with just a point of light which indicated the earlier lamps they've used in older locos.
Offline Moritz-BR365
#9 Posted : 02 December 2014 10:13:45(UTC)
Moritz-BR365
Hi Gary,
did You finish the conversionm of the 33951? I got this model yesterday and realized the bad driving performance. Therefore, I will change the decoder, too and install the 5-pole HLA (60760) in the first step.
There are two undocumented AUX ports on the 60760 decoder, which can be used for switching the steam generator on and off and e.g. for cabin light.
https://www.marklin-user...itor-and-F3-enabled.aspx
Moritz
This page was generated in 0.683 seconds.
