Offline Oliver nagel
#1 Posted : 27 January 2014 14:19:32(UTC)
Oliver nagel
Does anyone have the instructions for a Brawa 8817 signal.Glare
Oliver nagel attached the following image(s):
Offline kbvrod
#2 Posted : 27 January 2014 22:14:57(UTC)
kbvrod
Hi Oliver,all,
Could not find it in the Brawa database,..............what type of signal is it?
http://www.sh1.org/eisenbahn/
Dr D
#3 Posted : 28 January 2014 11:43:26(UTC)
Hello Oliver,
Brawa have not made signals for a very long time but they were quality work in metal, now displaced by plastic.
I bought most of mine in Zurich in 1983!!!
I see 8817 in my 1998 BRAWA cattledog.
What is the particular problem you have regarding the lightsignal?
Attached is scan of the usual instruction leaflet that came in most of the different BRAWA lightsignals.
Hope this helps.
PJ
#4 Posted : 28 January 2014 11:53:19(UTC)
Hello Oliver,
Hope this helps.
PJ
#5 Posted : 28 January 2014 12:18:29(UTC)
Sorry, I have not been successful in uploading the scans but I will try again soon after taking advice.
PJ
#6 Posted : 28 January 2014 12:24:48(UTC)
PJ
What advice do you need? Cool
Offline petestra
#7 Posted : 28 January 2014 14:49:21(UTC)
Hi Oliver. I would email Brawa. They may still have a copy that they can scan and email
back to you. It's worth a try? Good luck, Peter Smile
#8 Posted : 28 January 2014 16:34:19(UTC)
Oliver nagel
I bought the the signal from ebay for 10 bucks and it came with no instruction . The signal has 6 wires coming from it and no resistors for the LEDs like viessman signals. I have tried to email Brawa but the email won' t go thought.That is why I need the instructions.
Oliver
thanks 1 user liked this useful post by Oliver nagel
Offline kbvrod
#9 Posted : 28 January 2014 17:10:18(UTC)
kbvrod
Oliver,this is a distant signal (Hp system) see: http://www.sh1.org/eisenbahn/shhp.htm,so it should be wired to the main(home) signal.
So the 5 wires are for the lights(1 is a repeater,white left,upper side) and them a common ground wire.What colors are the wires?
Dr D
Offline bqg
#10 Posted : 28 January 2014 20:04:21(UTC)
bqg
Oliver
You could try their contact form:
http://www.brawa.de/serv...akt/kontaktformular.html
Hans Kurt
#11 Posted : 29 January 2014 00:42:10(UTC)
I've bought a lot of these signals back in the 80's in he year around 2000 I treid to connect them again and failed miserable by ruining the led's.
6 wires is a bit odd, you would think 4 wires for the led's and one common wire unless there are 2 common wires. I'll have a look if I still go the instructions for the signals.
#12 Posted : 29 January 2014 14:29:41(UTC)
Oliver nagel
Thank you bqg you link worked Brawa has sent me the instruction. Now I have to find the Brawa Signal Brochure.
File Attachment(s):
Anleitung Lichtsignale.pdf (1,411kb) downloaded 64 time(s).
thanks 3 users liked this useful post by Oliver nagel
Offline kbvrod
#13 Posted : 29 January 2014 23:32:59(UTC)
kbvrod
Better check,those look like bulbs!
#14 Posted : 30 January 2014 02:32:29(UTC)
Oliver nagel
I hooked up the signal to a old blue box transformer and it worked, and they are light bulbs !, each bulb uses 50ma of current at 16vac.
#15 Posted : 30 January 2014 09:53:12(UTC)
Hello again Oliver,
The signal has bulbs and even though BRAWA stopped making the signallicht side of things long ago, they still provide the parts.
I do have the instructions from my very old BRAWA signals (still work fine) and will get them to you soon, I am just currently learning (with Adrian's help) how to post the scan images.
PJ
#16 Posted : 30 January 2014 11:45:18(UTC)
Hello Oliver,
Hope I have it right with the images now, but I see you have, I think, already obtained the info, sorry for delay
PJ
Edited by moderator 30 January 2014 17:41:03(UTC)  | Reason: Not specified
#17 Posted : 30 January 2014 11:47:48(UTC)
Edited by moderator 30 January 2014 17:41:47(UTC)  | Reason: Not specified
#18 Posted : 30 January 2014 13:54:08(UTC)
Oliver nagel
Thank you for your help Pjmarklin.BigGrin
#19 Posted : 31 January 2014 12:11:55(UTC)
Hello again Oliver,
Have you worked out the wires yet?
PJ
Offline Hirayama
#20 Posted : 02 April 2017 22:35:36(UTC)
Hirayama
Japan
Hello Oliver,
Hope this helps.
PJ
PJ
Brawa has made signals and there was no break. As you said the earlier versions were metal.
Today, all are made with plastic but with new items too. I know it because I live here in Switzerland.
Oliver
Regarding the one you posted, there is an instruction on it. Märklin once publiched a book on Brawa
Signals but now out of print. All the information are there, but only in German.
#21 Posted : 03 April 2017 13:03:53(UTC)
Hello Oliver or Hirayama of Switzerland or Japan,
Originally Posted by: Hirayama Go to Quoted Post
PJ
Doesn't seem to be any light signals now, or for long time at Brawa : https://www.brawa.de/en/...eisenbahn-englisch.html,
maybe only in Switzerland (or is it Japan) ?
I have such a book, but not published by Märklin and in both German and English :
PJ
This page was generated in 0.822 seconds.
