Offline christos563
#1 Posted : 21 January 2014 18:41:27(UTC)
christos563
Hi from thessaloniki.
If i buy a brawa diesel loco, how can i use it on a marklin system ?
greetings, christos563.
Edited by user 24 January 2014 16:33:44(UTC)  | Reason: Not specified
Offline French_Fabrice
#2 Posted : 21 January 2014 19:39:22(UTC)
French_Fabrice
Yes, just order a 3 rails Brawa version of your Diesel loco.
Most (if not all ?) of Brawa locos are produced with 2 versions: A 2 rail and a 3 rail version.
fabrice
#3 Posted : 21 January 2014 22:57:02(UTC)
I have three Brawa Locos and they work fine on my m-track layout.
#4 Posted : 22 January 2014 00:33:40(UTC)
I have 2 Brawa Locos and they great on my C track Layout.
NN
Offline glight1
#5 Posted : 22 January 2014 02:10:30(UTC)
glight1
I also have 2 Brawa locos. The Wurttemberg Hh runs great except that it doesn't like turnouts on my C track. The 98 DRG doesn't have traction tires so it will not climb any grades. However, they both are very detailed models and run very smoothy around a flat oval track.
Gary
#6 Posted : 22 January 2014 05:09:08(UTC)
Yes...
Depends what type of turnouts you have.
If you use short turnouts from Märklin,it may sometimes derailment because of too thight curves in the short turnouts.
With long turnouts it will been fine to use Brawas locomotivs.
#7 Posted : 22 January 2014 10:05:46(UTC)
I am planning to try my first Brawa loco this year, though I'm slightly apprehensive because my layout has R1 curves and R2 turnouts. I would hate to have to confine it to the display shelf.
Offline christos563
#8 Posted : 24 January 2014 16:38:58(UTC)
christos563
eh, if i want the 41137 or 41132 how can i recognize their current ?
christos
#9 Posted : 24 January 2014 16:49:38(UTC)
christos
On the Brawa website, look on the page for the locomotive. You can see the different versions with their catalogue numbers. Follow my link below, you can see that the 41137 is an AC model without sound.
http://www.brawa.de/en/p...locomotive-v-160-db.html
41132 is a DC model without sound. If you want the AC model the number is 41133 or 41135 with sound
http://www.brawa.de/en/p...ocomotive-br-216-db.html
Offline mbarreto
#10 Posted : 24 January 2014 22:30:36(UTC)
mbarreto
I think Brawa is the best in detail, but much more fragile than M*.
I have only experience with steamers and 2 electrics. The steamers sound is superb and the very few plastic of the Tn is not so good.
Some, like the T5 run great, others like the Tn needs the track be very clean.
Miguel
Mostly Märklin H0.
#11 Posted : 25 January 2014 14:45:10(UTC)
The Tn model is quiet light locomotiv and the pick up shoe hit against Tn underframe body,which makes sometimes bad contact with the wheels on the rail.
It happens so by pass over the turnouts like K tracks.
Offline christos563
#12 Posted : 27 January 2014 18:57:11(UTC)
christos563
Hi.
Eh, so i must see the symbols of the catalogue.
But if I'm careless how do i recognize the suitable box ?
greetings and thank you all.
christos
Edited by user 12 June 2014 14:14:30(UTC)  | Reason: Not specified
This page was generated in 0.754 seconds.
