Offline Roman
#1 Posted : 10 January 2014 01:30:16(UTC)
Roman
Hello all,
Besides the five pole motor and close coupler on the tender, what other cosmetic differences are there between the 3102 and 3502 steam locomotive? Are the curved headlight guards metal or plastic? Thank you.
Roman
Offline franciscohg
#2 Posted : 10 January 2014 01:36:09(UTC)
franciscohg
Chile
Hi, dont have it, but presumably plastic, the 3 versions i have got it in this material
#3 Posted : 10 January 2014 07:50:08(UTC)
The 3102 has spoked running wheels, the 3702 has disc wheels and I've seen pictures of the 3502 with disc wheels.
However it is possible that Märklin used different wheels over time for the same ref. number.
Offline BrandonVA
#4 Posted : 10 January 2014 16:01:33(UTC)
BrandonVA
This may have been updated over time with the same reference number as well, but 3102 had slightly less accurate valve gear (M 1970s style) than 3502 (M 1980s style) as far as I can see from photos.
-Brandon
Offline Gregor
#5 Posted : 10 January 2014 20:47:49(UTC)
Gregor
Hi Roman,
I checked the headlight guards of my 3102 (first edition) with a magnet => they are metal.
Gregor
#6 Posted : 10 January 2014 20:58:16(UTC)
The 3502 also has "blackened" wheels as 3702, I think, while 3102 has the old-fashioned classic shiny metal wheels.
#7 Posted : 11 January 2014 06:11:00(UTC)
you may find the driving characteristics mainly the adhesive traction, some of the models I had (3102) the driving bogy with its adhesive tyres on both outside axles doesn't sit properly flat on the track, the cause: the whole boiler assembly sits on it (screwed on) with the cabin being plastic and the main weight lies or is resting on the front bogy because of the heavier weight distribution on the front, the driving bogy is slightly raised on the back axle and therefore losing its traction force. it may had been rectified or it is a hit and miss purchase whereas you will not find the problem.
This page was generated in 0.649 seconds.
