Offline christos563
#1 Posted : 23 October 2013 19:15:04(UTC)
christos563
I would ask if you bought some dummy and spoke tracks of the set 7287 and how long they are. Can they be put in "7-30'" intervals ?
christos563, thessaloniki, gr, hellas
Edited by user 23 May 2014 19:15:35(UTC)  | Reason: Not specified
#2 Posted : 30 October 2013 12:52:14(UTC)
Yes, they can be installed en 7-30 intervals.
I dont know how long they are, but I can tell you that they are identical to those that comes with the turntable set.
Offline christos563
#3 Posted : 30 October 2013 19:06:24(UTC)
christos563
And, Henrik, did you lay marklin K ? And which type of turntable and sheds ?
christos563.
Offline kbvrod
#4 Posted : 30 October 2013 21:23:11(UTC)
kbvrod
7.5 or 15 or more.
#5 Posted : 31 October 2013 16:11:54(UTC)
christos563.
Yes, I lay K-track. My turntable is the same as yours, but I havent gotten any sheds yet. I dont think there are many with 7:30 separation out there. A Faller model (old Pola molds). Maybe Fleischmann sells one too...¿?
Offline efel
#6 Posted : 01 November 2013 14:29:26(UTC)
efel
yes, Fleishmann sells a 7.5° roundhouse, with a rustic mechanical system for opening/closing doors (i had to add some springs for a good working).
Faller uses servo motors for moving the doors. Probably more realistic!
Fred
thanks 1 user liked this useful post by efel
#7 Posted : 11 February 2014 02:35:39(UTC)
of course the Märklin roundhouse works well with the turntable but only at the 15° (every second spoke) tracks
http://layout.mixmox.com/1/Roundhouse-3
Offline kbvrod
#8 Posted : 11 February 2014 16:19:57(UTC)
kbvrod
Fred
Not really,...
Sorry all,I should clarify what I meant,......
Roundhouse doors where moved by the 'Armstrong' method by crews.Left opened in warm weather and closed in colder weather.There was no motor to do this,in fact some RH had smaller doors so that workers could go in and out without having to open the lok door.Now,using this on your layout is not a bad thing and as more animation to your model railroad.
Dirt
Edited by user 11 February 2014 19:52:03(UTC)  | Reason: Not specified
Offline christos563
#9 Posted : 12 March 2014 19:17:07(UTC)
christos563
And ... if someone lays one remise with K tracks and one with M tracks in order to see the difference ... ?
christos, thessaloniki.
Offline kbvrod
#10 Posted : 12 March 2014 19:32:45(UTC)
kbvrod
Confused
Offline christos563
#11 Posted : 31 March 2014 18:46:25(UTC)
christos563
emm ..
I think about two approaches for the dummy track at 52 degrees and 30'. If one is laid with M tracks and the other is laid with C tracks the result is equal.
I am also thinking about an approach with K track. We can use a cut 2231 or 2233 at 8 degrees and 04'.
2275+2201+2251+2202+cut2233+2200+2200+dummy track.
the total angle will be 52 degrees and 30'. in order to approach the seventh dummy track of the turntable.
greetings from thess/niki, mfg, christos563.
Offline kbvrod
#12 Posted : 31 March 2014 19:38:24(UTC)
kbvrod
This is Greek to meConfused
Edited by user 01 April 2014 16:39:34(UTC)  | Reason: Not specified
Offline Shamu
#13 Posted : 01 April 2014 09:56:06(UTC)
Shamu
I could be wrong, but I think there talking about the feeder tracks as below right;
Shamu attached the following image(s):
Offline christos563
#14 Posted : 06 June 2014 19:14:53(UTC)
christos563
Em,
Why don't you understand what i am writing ?
And why marklin produces a so expensive set for anyone who wants to serve 20 or 44 locos around a turntable ? It is very stupid to have so many dummy tracks and pay much more money for completing a group of tracks for locos because the outer circle has a diameter of 169 cm or more.
And the only nessecary gap must be on at 45, 135, 225 and 315 degrees in order to put 4 masts for electrification and lighting.
gruss, greetings, christos563.
Edited by user 17 March 2016 22:08:46(UTC)  | Reason: Not specified
Offline christos563
#15 Posted : 17 March 2016 22:06:17(UTC)
christos563
Good afternoon after 17 months.
I bought the set 7287. Every spoke track is 76 mm long. But i think it is very expensive to have three dummy trucks in every set and l have "low ability" in using as many remises as i want.
I also saw the photo from shamu and will work on it. thank you.
christos.
Guest (4)
This page was generated in 0.380 seconds.
