Offline Drongo
#1 Posted : 03 September 2013 12:56:16(UTC)
Drongo
I'm trying to install an ESU Loksound M4 decoder 64499 into a Marklin 29483 Cargo electric loco mfx.
Is it possible to program the decoder with my CS2 or do I need a lokprogrammer? If it's possible with the CS2 - how do I do it?
Greg
#2 Posted : 03 September 2013 13:10:14(UTC)
Greg,
one can assume the CS 2 is restricted to 16 functions whereas the ESU decoder can reach 21 functions, as mentioned before, there are the basic CV's you can change but I would think any sound functions you wouldn't be able.
Also the 64499 is a universal sound decoder, so how do you expect to get the right sound functions for your model ?
if you have any queries about ESU decoders you can always ask me for free advice.
regards.,
Offline biedmatt
#3 Posted : 03 September 2013 13:32:21(UTC)
biedmatt
Hi Greg,
Did you order it with the correct sound files already installed?
See the LokSound V4 manual at ESU. It's a downloadable PDF.
They give instructions on how to program with several control stations and I believe there's a CV cart in the back.
Good luck!
Edit: See page 35 of the manual
Matt
Era 3
#4 Posted : 03 September 2013 14:12:55(UTC)
Everything that can be achieved via CV programming can also be done with a CS2.
But you cannot upload sound projects.
Tip: you can download the LokProgrammer software, make the changes with that software (e.g. function mapping) and get a list of changed CVs from the software. This is much easier than finding the correct CVs in the manual.
But probably you don't need CVs anyway. The decoder is mfx and you should be able to make (most) adjustments using the normal mfx screens of the CS2.
#5 Posted : 20 September 2013 04:30:56(UTC)
Tom,
I believe the latest ESU decoders (sound) V4 M4 you also can change CV's whereas before this wasn't possible with mfx decoders.
This page was generated in 0.486 seconds.
