Offline DamonKelly
#1 Posted : 30 May 2013 15:32:33(UTC)
DamonKelly
I have recently acquired a Bollinger Edgerly Scale Trains wood-cut kit. This one, in fact.
I have never built a kit like this, so I would appreciate any tips or links as to how to get the best results from these sort of kits.
I have experience with plastic kits, and white metal figures, so I'm not a complete newbie, but I'd like some advice on how to build this laser-cut wood kit.
Any suggestions?
Damon
thanks 2 users liked this useful post by DamonKelly
#2 Posted : 31 May 2013 17:32:12(UTC)
Hey!
I suggest you shall try laser wood-cut kit.
I use wood glue to fasten cardboard walls and woods.
A tip...never use acryl color on the thin cardboards.
Use enamel color thinned with special thinner.
If you decides to paint and weathering yours building.
thanks 3 users liked this useful post by Goofy
Offline Christoffer
#3 Posted : 04 July 2013 14:39:39(UTC)
Christoffer
Hello.
I'll jump on this.
Need tips for paint and glue.
Paint before assembling just as plastic kits ? Testors Model master good enough ?
What type of glue? Name examples are welcome. There are diffrent type of glues as far as i have seen, with diffrent drying end results ( drying blank or not etc) What do you who have build this kit used?
Thanks for answers ThumpUp
Christoffer
thanks 1 user liked this useful post by Christoffer
Offline kbvrod
#4 Posted : 04 July 2013 16:55:43(UTC)
kbvrod
thanks 1 user liked this useful post by kbvrod
Offline Iamnotthecrazyone
#5 Posted : 09 July 2013 05:58:30(UTC)
Iamnotthecrazyone
I understand it is better to paint both sides of the panels to avoid warping. Paint them in very thin layers to prevent the wood absorbing the paint and then getting deformed. I have a couple of kits but never dedicated the time to build them. I only see them as a last resort option, when nothing else is available, they seem to require an awful amount of care to get top results.
Offline kbvrod
#6 Posted : 09 July 2013 16:42:48(UTC)
kbvrod
Remember there is a difference between a laser cut kit and craftsmen kit,...
Dr D
Offline kbvrod
#7 Posted : 09 July 2013 16:54:10(UTC)
kbvrod
Any suggestions?
Hi Damon,all,
As with any kit,....
Copy the instructions and make notes:painting/weathering/assembly/sub-assemblies,etc.
Next post a photo of the kit itself(raw wood?) then painting or staining the wood prior to construction maybe in order.
A 'true' flat work surface for the walls
Clamps,lots of them!Smile
Adhesives: your going to need something to join different materials together.
Dr D
thanks 3 users liked this useful post by kbvrod
Offline DamonKelly
#8 Posted : 10 July 2013 14:08:31(UTC)
DamonKelly
Thanks everybody!
I've just received this DVD which seems like a good introduction. I've also got the kit under discussion in the DVD.
I quite like the range of laser-cut kits out there. I'm planning a US section of my (future) layout, and some of these kits really appeal to me.
The video mentions a lot of MicroMark tools. Are they good quality?
Damon
Offline kbvrod
#9 Posted : 10 July 2013 15:04:39(UTC)
kbvrod
Hi Damon,all,
Yes,they always have items in stock and hard to find tools:
See: https://www.micromark.com/
They will also send you a free paper catalog.
Dr D
#10 Posted : 15 July 2013 07:42:39(UTC)
Originally Posted by: Christoffer Go to Quoted Post
Hello.
I'll jump on this.
Christoffer
Testor model master has acryl color which is not good for thin card board!
Use Humbrol enamel color instead...if you like thinn it too.
For laser cut kit made of wood and card board i use wood glue for indoor.
They dries transparent.
This page was generated in 0.539 seconds.
