Offline Stasjonsmester
#1 Posted : 29 January 2013 22:49:13(UTC)
Stasjonsmester
My Cs2 can't find any K83's i have 4 and all dip settings are correct. Red and brown power wires are Connected to the Cs. Butt still no connections . I am confused please help
Arild (Stasjonsmester)
Märklin H0 Norwegian trains
Offline MikeR
#2 Posted : 30 January 2013 06:36:43(UTC)
MikeR
Hi Arild
Check that you have the red and brown wires connected the correct way round at the CS2. I had a similar problem and found that I had reversed the red and brown wires.
Member of ETE
#3 Posted : 30 January 2013 09:39:28(UTC)
Check your correct address on CS2?
#4 Posted : 30 January 2013 12:55:07(UTC)
Stasjonsmester
Originally Posted by: MikeR Go to Quoted Post
Hi Arild
Thank you Mike this solved the problem Love
thanks 2 users liked this useful post by Stasjonsmester
Offline ecastrog
#5 Posted : 02 October 2014 04:44:11(UTC)
ecastrog
Ecuador
Hi Arild
Hi all
I have the same exact problem. My CS2 won't get the k83 decoders to do anything.
I saw the answers here, so I checked all the connections, dip settings, voltage, everything, but still the k83 won't do anything
I tried several k83's just in case is a problem of the decoder, but still no luck
BTW, the k83 were working just fine, but I don't know what happened (I disassembled my layout to start a new one)
I have tried k84 and m84 and they all work just fine
Any ideas??
(I also updated to latest version of CS2, but the problem was present before the update)
Any help will be highly appreciated
Esteban
Offline ecastrog
#6 Posted : 03 October 2014 19:49:10(UTC)
ecastrog
Ecuador
Hi Arild
Hi all
Any ideas??
Esteban
I solved the problem! Blink actually it was a big mistake from me..
The k83 were just fine, and also the connections of the CS2.
I was doing the connection of the accesories wrong, and also I was specting to hear a "click" on the k83 (as k84 does), so since I didn't hear the click (which now I know k83 doesn't do!!) I thought it was not working
Everything is fine now
thanks 2 users liked this useful post by ecastrog
This page was generated in 0.492 seconds.
