Offline jonas_sthlm
#1 Posted : 17 December 2012 21:10:42(UTC)
jonas_sthlm
Has anyone try this tool yet ?
mDecoderTool
I am download soundlibrary right now 280MB, will be interesting what's inside Cool
thanks 3 users liked this useful post by jonas_sthlm
Offline FrankF
#2 Posted : 17 December 2012 21:57:41(UTC)
FrankF
I Have already installed the mDecoderTool-Software from Marklin and it looks very good from my point of view.
But take a look yourself at the pictures i have uploaded :
FrankF attached the following image(s):
CS3+ 60216 ( SW:2.5.2 ) - MASTER / CS2 60215 ( SW:4.3.0 ) - SLAVE
MS2 60653/57 ( SW:4.13 ) / MS1 60652 ( SW:1.8AP ) / 60883 S88 LINK ( SW:1.1 )
MDT 3 (SW 3.6.0) - HW: 60970 / 60971 / 60801
ESU LOKPROGRAMMER ( SW 5.2.6 ) / ESU HW: 53451 / 53900 / 53901
thanks 3 users liked this useful post by FrankF
#3 Posted : 17 December 2012 22:08:10(UTC)
Download in English?
#4 Posted : 17 December 2012 22:24:59(UTC)
During setup you can choose between four languages (IIRC German, English, French, Dutch).
The software requires version 2.1 on the CS2.
Offline jonas_sthlm
#5 Posted : 17 December 2012 22:44:13(UTC)
jonas_sthlm
Should PC need a USB cable between CS2 ?
#6 Posted : 17 December 2012 22:52:05(UTC)
Should PC need a USB cable between CS2?
No, USB memory stick moved between PC and CS2.
Create the project on the PC, save it on USB stick, then move to CS2 and update the loco.
Offline GSRR
#7 Posted : 17 December 2012 23:11:39(UTC)
GSRR
Have the mSD sound decoders been installed in new production items yet, or is it still just an add on kit?
r/Thomas
Offline jonas_sthlm
#8 Posted : 17 December 2012 23:12:23(UTC)
jonas_sthlm
Com1 port under Settings > Programming > Sound Confused
Missing sound for NOHAB and Rc/1043 engine Sneaky
Offline 3rail4life
#9 Posted : 18 December 2012 00:43:44(UTC)
3rail4life
"Sie können sogar eigene aufgenommene WAV-Files umwandeln und der Soundbibliothek hinzufügen."
translated:
You can even convert your own recorded WAV files and add them to the sound library.
This looks to be very cool ThumpUp , I think this is what many of us have been waiting for and I like the fact that no new programming hardware is required. I am really looking forward to playing around with the tool. I will try it out with a mLD equipped Loco soon and hopefully someday will be creating new sound files for the programmable sound decoders, I have installed.
Gordon
thanks 3 users liked this useful post by 3rail4life
Offline jonas_sthlm
#10 Posted : 18 December 2012 00:50:51(UTC)
jonas_sthlm
Has anyone managed to open existing project from M site ?
Offline 3rail4life
#11 Posted : 18 December 2012 00:59:41(UTC)
3rail4life
I think I have wait for for the CS2 software version 2.1 to be re-released in final form before I can get started Huh .
#12 Posted : 18 December 2012 07:37:46(UTC)
That's for the new 60801 Märklin Programmer (Com1 doesn't sound like USB, sounds like a legacy port).
Offline jonas_sthlm
#13 Posted : 20 December 2012 21:07:17(UTC)
jonas_sthlm
Only 21MTC Sound decoder and not possible to connection for rail Confused
Offline GSRR
#14 Posted : 20 December 2012 21:18:14(UTC)
GSRR
Nice score on the photo, not even in the database yet? I wonder if there will be a test board with a motor for the decoder prior to installation like ESU?
r/Thomas
thanks 1 user liked this useful post by GSRR
Offline tulit
#15 Posted : 20 December 2012 21:41:21(UTC)
tulit
I think that having the direct 21MTC connection will be a big advantage. I'd imagine programming with this must be much quicker than with the CS2. The data rate over rail is very limited.
thanks 1 user liked this useful post by tulit
Offline jeehring
#16 Posted : 20 December 2012 22:17:11(UTC)
jeehring
r/Thomas
Even with ESU programmer, you have to buy the Test Board separately...$$$$$$$.....
Anyway, once you have programmed with Marklin sound programmer, I think you can use the ESU test board....
Two wires from a piece of track connected to MS2
IMO, the ESU test board should be compatible with any kind of decoders....Only one thing must be checked : the impedance of the speaker installed on it. (Must be similar to Marklin speakers impedance)
It seems that ESU made it more or less for shops or workshops. As an enthusiast I find it somewhat useless ...we cannot get the same sound as a speaker is mounted into a lok....
Our Loks are the best Test board of the world....Wink
thanks 1 user liked this useful post by jeehring
Offline jonas_sthlm
#17 Posted : 20 December 2012 22:17:19(UTC)
jonas_sthlm
More info haertle.de
Offline jeehring
#18 Posted : 21 December 2012 01:47:45(UTC)
jeehring
Originally Posted by: tulit Go to Quoted Post
[img]
About programming, electrical contacts must be perfect, that's why programmation track and wheels have to be clean.
Yes, direct MTC connection is advantage over the ESU Lokprogrammer as well. (over many other programmers too)
Offline jeehring
#19 Posted : 21 December 2012 12:26:09(UTC)
jeehring
...finally, I don't think that data transfert from a Sound programmer is time saver for the operator ...I rather think that direct connection with the decoder is more "safe"....I often have read that people may encounter problems with programming on the track, just because wheels and rails are not clean.
Offline pa-pauls
#20 Posted : 21 December 2012 13:09:56(UTC)
pa-pauls
On the newest version of the ESU test board there is a switch. You can choose OFF, 100 Ohm ore 16 Ohm for the speaker.
Pål Paulsen
thanks 1 user liked this useful post by pa-pauls
#21 Posted : 21 December 2012 14:50:39(UTC)
The programmer is for dealers. They take the decoder out of the box, plug it in the programmer, transfer the sounds, and put it back into the box.
It's not such a big time saver for decoders that are already in a loco (but on Stummi's Forum they write that it can take up to 30 minutes to update the sounds from the CS2).
Offline Mark5
#22 Posted : 22 December 2012 08:21:42(UTC)
Mark5
Is the question of transfer a matter of time or also of possible corruptibility of the file?
If plugging in the decoder directly produces better results, why would anyone not bother to do it that way?
I would just unscrew the cover of the lok and plug in the decoder....
BTW ... I suppose this is OT but... Can all this be done with ESU equipment?...
and if so which equipment to program sound.
I am guessing there have been posts on this already.
If anyone knows which posts, please send a link.
I'd love to read the discussion.
- Mark
#23 Posted : 22 December 2012 09:12:29(UTC)
Sure. For ESU decoders this can be done with ESU equipment. For Zimo decoders this can be done with Zimo equipment. For Uhlenbrock decoders this can be done with Uhlenbrock equipment. For Märklin decoders this can be done with Märklin equipment.
So better stick with the decoders you like best.
The ESU decoder might work with decoders from other brands (but I don't know if the AUX3/4 problem plays a role here).
Offline jonas_sthlm
#24 Posted : 22 December 2012 10:11:21(UTC)
jonas_sthlm
M application doesn’t work with ESU programing box, try that yesterday…
I have done a lot of programing with engine on rail with EUS equipment without any issues, it never take any 30 minutes to get the sound uploaded.
It’s only when you have a SDS engine like the Swedish T44 that you need to use ESU test bench with 21MTC
#25 Posted : 22 December 2012 10:37:57(UTC)
The ESU programmer doesn't use the normal mfx programming mode, but a proprietary ESU mode (and therefore it only works with ESU mfx decoders).
If you don't have the test bench, you can still put the decoder into any non-SDS loco and do the programming there.
As I wrote before: when it comes to sound updates, there are no public standards and every company uses own proprietary solutions.
Offline Dgriman
#26 Posted : 01 February 2014 17:31:57(UTC)
Dgriman
After many retrofits of old locos with new mLD / mSD, I decided to create my own decoder-tester, which I use to test and/or programme and update the decoders before I put them in the locomotive.
I find this way easier and safer rather than testing the locos on tracks with a bad electrical connection and having the locomotive in front of me.
I'm sharing the idea for anyone who likes it
21pin Decoder Tester - 11 by dgriman, on Flickr
21pin Decoder Tester - 14 by dgriman, on Flickr
21pin Decoder Tester - 15 by dgriman, on Flickr
My web directory for Model RailRoading (Greek and English Language)
http://trains.dgservices.gr
My Photo Album
http://www.flickr.com/photos/dgriman/
My Video Channel
Trainsmodeler Video Channel
Thank you for visiting
Dimitris
thanks 5 users liked this useful post by Dgriman
Offline 3rail4life
#27 Posted : 01 February 2014 19:47:12(UTC)
3rail4life
Very Cool DimitrisThumpUp ThumpUp That is a great idea, I think I will build one too when I have a spare mSD/mSD mounting board. I too have the need for a tester as many times I do not have the loco available for programming or testing.
Just last week I decided to upgrade my Delta 3374 to mLD and it now serves as my "test mule" for mSD programming. With a easy to remove housing and plenty of room under the hood it makes for a great test bed.
3374 with mSD decoder
Gordon
Offline biedmatt
#28 Posted : 01 February 2014 20:14:25(UTC)
biedmatt
http://www.esu.eu/en/products/decoder-tester/
I added a green led to mine so I could readily tell which way the motor was running.
Matt
Era 3
Offline jonas_sthlm
#29 Posted : 14 September 2014 13:59:50(UTC)
jonas_sthlm
Anyone playing creating your own sound Project ?
I am interesting to know how motor sound files can be mapped inside tool Confused
It's about 65 files inside excited motor from M files Huh
Try to do my own project for Da-engine and is already in place now and working fine...
Offline jonas_sthlm
#30 Posted : 21 September 2014 18:45:12(UTC)
jonas_sthlm
No one who knows how to put together its own Engine (motor) sound Confused
Offline waorb
#31 Posted : 22 September 2014 17:53:10(UTC)
waorb
Brazil
Hello Jonas!
Rodrigo from Argentina (username RodLinar) it's working on a self made sound/motor decoder for analog Märklins. (to be digitilized)
Maybe you both could exchange experiences.
Walter
Offline jonas_sthlm
#32 Posted : 03 October 2014 05:58:07(UTC)
jonas_sthlm
Hello Jonas!
Walter
Thanks for the suggestion, I contacted, but no response yet
Inside document (Sounddecoder Beschreibung Rel01.pdf) that downloads thru CS2 Sound update to USB stick says ToDo since 27.03.2012.....
But when Confused
Offline waorb
#33 Posted : 03 October 2014 13:17:48(UTC)
waorb
Brazil
Maybe you should contact him directly via his website:
(contact form)
http://www.trenesdigitales.com.ar/es/5-decoders
Walter
mDecoderTool v3.6.0 update, including decoder firmware to v3.3.0.x (Digital)
Belarus bph 06/04/2023 18:58:39(UTC)
mDecoderTool V3.50 update (Digital)
by Bryan 13/09/2022 02:06:59(UTC)
mDecoderTool3 (mDT3) Advanced Programming with Dynamic Braking (Digital)
by nuhme_niels 16/07/2021 23:50:11(UTC)
any updates rumors CS3 and mDecoderTool3 ? (Digital)
by jonas_sthlm 06/10/2019 11:11:03(UTC)
MDecoderTool3 - Motor Options (Digital)
by xxup 24/06/2019 04:55:08(UTC)
mDecoderTool and CS2 (Digital)
by mbarreto 19/01/2016 18:06:29(UTC)
How to make sound file for BR24 (with 60965) by mDecoderTool? (Digital)
by dpetrovichev 21/05/2013 01:24:22(UTC)
This page was generated in 1.192 seconds.
