Offline tiono
#1 Posted : 27 August 2012 15:37:02(UTC)
tiono
I am not a big fan of Marklin's passenger coaches, but few years back when Marklin released the Silberling coaches in 1:93 instead of 1:100, I ordered a set expecting to see improved details from their new tooling.
#43800 Type B4nzb-64 second class coach
#43810 Type AB4nb-59 first & second class coach
#43820 Type BD4nf-59 control car, second class & baggage
The coaches are excellent on painting and lettering quality. The exterior details is also excellent; it has separately applied hand-rail, door-steps with raised pattern, and good under-carriage equipments exterior. However those under-chassis equipments are just resembling a simple plate, there is no blocks of equipments nor undercarriage pipes.
The interior details is still basic, I would say that there is no improvement on this area.
In regards of interior and under-chassis details, these coaches are still not in par to most Roco or LS Models coaches. But considering its price is lower than comparable offering from Roco or LS Models, then these Marklin coaches are still relevant.
Below are the photographs:
The wheel boogie:
The printing is excellent. The set 43800, 43810, and 43820 carry Stuttgart-Tubingen route plate printed on its side.
Separately applied hand-rail:
Raised pattern on the door steps instead of just plain flat surface as common on Marklin's older coaches.
Details on undercarriage exterior is well defined although there is no details below the chassis.
This photo shows the "empty" under-chassis, basically no details there.
Rear view of control cab BD4nf (#43820), note the nice wipers
The control cab is equipped with two red and three white lights, changing automatically according to direction of travel. The lights are all LEDs.
Travel direction switch located at the boogie of the control-cab, and connector for current-conducting coupler.
The electronic pcb on control-cab
The interior of AB4nb (#43810) and B4nzb (#43800).
thanks 3 users liked this useful post by tiono
#2 Posted : 27 August 2012 16:33:14(UTC)
Thank you for the detailed presentation and the great photos.BigGrin
Offline Gert-Jan
#3 Posted : 21 December 2014 20:32:03(UTC)
Gert-Jan
I have three Silberlinge from starters set 29720
Silberlinge 2. Klasse Bn 719
Silberlinge 1./2. Klasse ABn 703
Silberlinge 2. Klasse BDnf 738 steuerwagen "Hasenkasten"
I would like to add one 2nd class coach.
Märklin 43800 being Silberlinge 2. Klasse (B4nzb-64)
Is this optical identical/compatible with the ones from the set?
Both have length of 28.2 cm.
Mosty era III DB.
Offline Gregor
#4 Posted : 23 June 2015 17:26:41(UTC)
Gregor
Hi Gert-Jan
Probably way too late, I did not notice your question before.
Starter set 29720 is ERA IV with UIC numbers below the DB logo.
The 43800, 810 and 820 are ERA III with no UIC numbers.
Other than that I believe they are identical.
Gregor
This page was generated in 0.480 seconds.
