Offline Ian555
#1 Posted : 05 July 2012 15:39:43(UTC)
Ian555
No, it's not a quiz, just trying to get some info on the wagon.
Ian.
Uploaded with ImageShack.us
Offline Jeremy Palmer
#2 Posted : 05 July 2012 17:35:29(UTC)
Jeremy Palmer
Barbados
I really need to read topic heading better, thought you meant the dude on the bridge.......................
Jeremy.
Jeremy.
Offline Ian555
#3 Posted : 05 July 2012 17:39:49(UTC)
Ian555
Hi Jeremy,
Surely not a forum member....LOL
Ian.
#4 Posted : 05 July 2012 17:44:18(UTC)
It's a 4511, pulverised coal silo wagon.
RayF attached the following image(s):
#5 Posted : 05 July 2012 17:51:43(UTC)
According to Helmut Kern, this wagon was produced from 1955 to 1979.
It was also available as a kit under catalogue number 4911 from 1958 to 1969. and as Primex model 4551 from 1980 to 1987
#6 Posted : 05 July 2012 18:01:44(UTC)
The '4511' white letting show on it, See red circle.
#7 Posted : 05 July 2012 18:11:10(UTC)
Ian,
Your wagon is or was a kit (4911).
#8 Posted : 05 July 2012 18:17:18(UTC)
Ian,
How can you tell, John?
Offline Ian555
#9 Posted : 05 July 2012 18:51:34(UTC)
Ian555
Hi Ray,
Thanks. ThumpUp
Ian.
#10 Posted : 05 July 2012 19:26:29(UTC)
Ian,
I think it is 4911, You note there is a missing - ladder, buffer, etc?
Offline Ian555
#11 Posted : 05 July 2012 20:05:27(UTC)
Ian555
Wow!!!, lot's of interest in a wagon I got for nothing.Smile
The number is 4511 on the side of it, and Stephen is right, both ladders are missing, an end hand rail and 3 of the buffer's.
On a positive note, it has the original spring underneath, and apart from the missing parts is in not to bad a condition.
Thanks for all the feedback on the wagon. ThumpUp ThumpUp
Ian.
Offline Western Pacific
#12 Posted : 05 July 2012 20:22:37(UTC)
Western Pacific
Ian,
One way of telling is to have a look at the buffers. On models of the 45xx series they are metal, but on corresponding 49xx series wagons they are plastic*). The way I mounted the plastic buffers back in the 1960-ies was to use a flat screwdriver, heat it over a candle and then press on the backside of the buffer which is easily seen from the underside of the wagon. In other words, doing a sort of "heat riveting" of the buffers.
So Ian can check if the remaining buffer is plastic, then I'm pretty sure that it is a 4911.
____
*) At least this applies to the relatively few 45xx and 49xx of the same type that I have.
Offline Ian555
#13 Posted : 05 July 2012 20:34:07(UTC)
Ian555
Hi Per,
The buffer is metal.
Ian.
Offline Ian555
#14 Posted : 07 July 2012 17:16:24(UTC)
Ian555
I found another 4511 in my hidden station. ThumpUp
Photo's tomorrow.
Ian.
#15 Posted : 08 July 2012 04:58:44(UTC)
Ian,
Ray,
I grew up with them
a.) there aren't any buffers left (the kit was supplied with plastic buffers) [these buffers had to be melted from the back to secure it to the frame and any excess heat deformed them or there was no substance left to hold them onto the frame]{superglue wasn't available than}
b.) your couplings had a split pin
I bought them as a kid when money was not plenty and we had no trees in the backgardenBigGrin
#16 Posted : 08 July 2012 05:08:25(UTC)
Hi Per,
Ian.
Ian,
this is unusual, the picture you've supplied indicates the coupling is secured by a split pin, so you can construct the coupling your self and as one other member mentioned and myself the kit form came with plastic couplings.
It is a bit odd to loose 3 metal buffers and this rarely happens with any Märklin older carriages unless you forcefully remove them.
So whoever had the carriage, part from the missing stepladders someone, if it is in fact a metal coupling has added it to it.
In the end it is still the same carriage, worth almost equal to a Scottish castle (they are going cheap at the moment) but the main different feature was the split pin and plastic buffers.
Offline Ian555
#17 Posted : 08 July 2012 06:48:04(UTC)
Ian555
Hi John,
Thanks for the information on the 4511 wagon and the Scottish castles. Smile
Although I'm still confused, was it a kit built wagon.
Ian.
Offline Ian555
#18 Posted : 08 July 2012 06:52:58(UTC)
Ian555
Here's some photo's of another 4511 wagon, this one I found in my hidden station, great place to put stuff and then forget you've got it. Smile
Ian.
Offline Ian555
#19 Posted : 08 July 2012 06:56:54(UTC)
Ian555
Ian.
Offline Ian555
#20 Posted : 08 July 2012 07:00:53(UTC)
Ian555
Couple more photo's of my second 4511 wagon.
Ian.
#21 Posted : 08 July 2012 21:19:17(UTC)
Very nice, Ian!
I'm also confused about whether it's a kit or not...
Offline Ian555
#22 Posted : 08 July 2012 21:55:19(UTC)
Ian555
Hi Ray,
Thanks. ThumpUp
Of course, being an avid banana van collector, some might say, I'm easily confused. Smile
Ian.
This page was generated in 0.806 seconds.
