Offline davidt
#1 Posted : 04 January 2012 20:47:22(UTC)
davidt
HI,
Blink I AM LOOKING FOR THE DIMENSION OF THE HO TRACK - A SECTION VIEWBlink
PLEASE ADVICE WHERE CAN I GET IT
THANK YOU
DAVID BigGrin
Offline Yumgui
#2 Posted : 04 January 2012 21:13:12(UTC)
Yumgui
Hi David,
Welcome to the forum ... maybe you could present yourself first before firing off questions ...
In the meantime, maybe this is what you are looking for :
Yum ThumpUp
#3 Posted : 04 January 2012 21:16:36(UTC)
Hi and Welcome to the forum, David.
Trackplan booklet (Curved Dimension table on page 7). in German found on (PDF 16MB) http://lctm.atarrabi.org...teca/Libros/pdf/0390.pdf
Offline Renato
#4 Posted : 06 January 2012 10:12:07(UTC)
Renato
Hi David,
Welcome to this fantastic forum.
Renato
Offline davidt
#5 Posted : 07 January 2012 19:46:01(UTC)
davidt
thank you all for the information - i knew this information exist and i looked for a long time
at our family there is a tradition to build the system every year for a period of month.
we started to built it yearly since about 1960.
my grand parents emigrated from Germany just before the second world war begun and since than we have it.
best regards and thank you
David
thanks 1 user liked this useful post by davidt
Offline quarkhirad
#6 Posted : 05 May 2015 07:07:36(UTC)
quarkhirad
India
Hey Yumgui
Hi i am looking for the track dimenssion of marklin ho C track. You have given the M track section view. Can i get the same for C track.
khirad
Offline madhu.gn.71
#7 Posted : 05 May 2015 10:09:27(UTC)
madhu.gn.71
India
Hello khirad,
For C track this is what I had explored so far:
Broschüre_C-Gleis_Gleispläne_Ergänzungspackungen.pdf from Maerklin Site and cgleis_length calculations.pdf by Bogobit which I had downloaded from the internet long back.
Madhu
File Attachment(s):
cgleis_length calculations.pdf (56kb) downloaded 315 time(s).
Offline quarkhirad
#8 Posted : 06 May 2015 14:03:51(UTC)
quarkhirad
India
Originally Posted by: madhu.gn.71 Go to Quoted Post
Hello khirad,
Madhu
This is amazing . BigGrin BigGrin .
Though my question is is the marklin C track cross section view the same as M track.
khirad
Offline mike-mun@ugol.com
#9 Posted : 11 August 2015 00:43:56(UTC)
mike-mun@ugol.com
No, the cross section of M track and C Track is slightly different. The C Track bed is 2mm wider than the M Track bed. and they use totally different electrical connections. The width difference causes big problems when you try to use older bridge sections from various vendors (Including Marklin) with C Track; the track slot is too narrow for C track to fit, and there is NO easy fix. Make sure any bridge you obtain specifically states it will fit C Track or ALL track styles! M Track will fit into C Track bridges, but will be be a slightly loose. Just shim it a bit. Also there is sometimes an issue with some pre-made passenger station platform sets, but that can usually be tweaked. To use C Track with a narrow platform (between parallel tracks), make sure the platform is the newer 38mm wide, and not the older 40mm wide.
This page was generated in 0.635 seconds.
