Offline sop
#1 Posted : 02 August 2011 07:17:06(UTC)
sop
I am looking for the 74920 transformer but does not know the exact model.
Turntable as I read the user manual trans 6002.
So if you use 74920 and 7286, you must use two separate transformer?
Who can help me? thanks.
Offline Renato
#2 Posted : 03 August 2011 17:49:33(UTC)
Renato
Hi and welcome to the forum.
You need only one separate transformer to feed both the 74920 and 7286 items.
This is only mandatory if you are using the MS1, MS2 or the other Central Stations of Marklin Systems. In these cases you need 1 (one) transformer for the digital control device and 1 (one) separate transformer for the other electromagnetic accessories.
If this is the case, you can use the 6002 transformer or even the old blue transformers (0-L connections, i.e. brown-yellow sockets).
Hope this helps
Renato
Offline sop
#3 Posted : 03 August 2011 19:15:46(UTC)
sop
thank for your information ,Renato
Sop
This page was generated in 0.432 seconds.
