Offline elsleuth
#1 Posted : 12 February 2010 21:48:32(UTC)
elsleuth
What are the capabilities of the Marklin Memory 6043? Can the unit control four trains at the same time automatically? I would like to use it to control four trains in a pattern in and out of a train station using two separate tracks. Is this possible? Kent in California
Online clapcott
#2 Posted : 12 February 2010 22:53:11(UTC)
Yes it is possible. In fact it is one of the 2 prime functions of the unit.
However the process is indirect as the Memory (6043) is not able to send Locomotive/decoder commands, it can be used only to switch accessories.
As well as the 6043 you would need ...
- a controller (602x)
- accessory decoders (6083x/6084x)
- - with electronic points / signals
- feedback detection (6088x) for automation
- programing capability (usually the 6040 keyboard, or interface)
Thus to stop a train you would utilize a signal with an accompanying dead section (track power turned off when signal aspect is red).
There is no timer function available so what is required is a looping sequence of "cause and effect" - one (moving) train triggers a sequence that starts another. The sequence usually also includes the setting of an appropriate route.
Using the dead section concept , trains do stop abruptly. An option to insert a slowdown circuit is possible, however the operation of this depends on the locomotive motor/decoder capabilities. The direction of travel also needs to be taken into account.
A side issue is that early decoders would only retain their memory ( of speed and direction) for a few seconds. As a result they would not start when the signal went green. A trick to provide a "trickle of power" to the dead section gets you around this.
If you think you have a 6043 lined up for a good price, I suggest you double-check the business case against a 605x(interface) utilizing a PC, or an investment towards a CS.
Either of which perform the same function but with a bit more flexibility and functionality.
For example a PC can add
- Locomotive commands
- - controlled slowdown
- - function activation (Lights, telex, sound ...)
- - reverse
- Timings (delays / auto start)
- Randomization
- Flexibility (e.g. a different number of trains in the fiddle yard)
All that said, if you have a fixed sequence in mind that you just wont to be able to turn power on and press go then the 6043 is the way to go
Offline jeehring
#3 Posted : 13 February 2010 03:42:07(UTC)
jeehring
Memory gives me a lot of fun. I find it a real funny little thing. It's a small automaton with its proper logic ( locked/unlocked, priorities,...).
Comparing to a PC, what I like with the Memory is that you "work" on sight, on the track, instead of a virtual modelling on screen ...
Memory can give different results, depending on the installation...( some nice technical articles into former Insider Magazines , 2000/2001...). For slowing down, 72441 module (or similar circuit) may be connected to tracks.
Of course, Memory is not as powerful & complete as a PC + software...
Looking for an English instruction manual for Marklin Memory 6043 (Digital)
by Fireguy911 16/12/2020 19:59:22(UTC)
Marklin memory 6043 manual (Digital)
by yannos 13/11/2005 20:01:51(UTC)
This page was generated in 0.333 seconds.
