Offline VidKidz
#1 Posted : 05 February 2010 05:29:24(UTC)
VidKidz
Hi.
I am new to Marklin but have no local dealer near me, so before I start to dive in and buy via mail order, I figured that I'd ask about what can be done with my available "train" space. I am thinking about putting up a small layout in a 13' x 5' area but am concerned that not much can be done with such a small area. Can anyone refer me to some online layouts or track plans that utilize a comparable size?
Thanks!
Offline atilla
#2 Posted : 05 February 2010 06:45:26(UTC)
atilla
Take a look at some of the layouts posted here. People do some nice things with small layouts. One thought in a book, was to make a simple straightish run of track through a scenic section, have it enter a tunnel and go to a large hidden yard under the scenic area. Now you have a place where you can run your trains one at a time as a continuous kinetic display.
#3 Posted : 05 February 2010 07:21:54(UTC)
Steve,
Welcome to the layout forum.
It could help if you also include metric measurements for our metric countries, nevertheless your size is'nt small, small.
There are hundreds of different options you can choose from regarding layouts are concerend.
Literatur or layout plans can be obtained through a dealer (postal service).
Having determined the size of your proposed layout, it is always a good start, to identify or laydown some things you realy would like on your layout.
Research further how big these items or scenic features are, e.g. buildings, factories, homes, stations etc etc. and than you can compare the room you need to accomodate them, if they fit into the landscape.
You also can make a scetch of your proposed size and outline what you think is essential on your layout.
You have to take into considerations how many locos and rollingstock you have or purchase in the future.
This could lead to not having enough room and you may consider or need a shadow freight station or siding which is usually build on another level. Is your layout going to be flat or will it have some inclines, bridges, waterways, tunnels or hills ?
Having track plans can help to get some sort of an idea what you intend to do and there are plans out there which utilises, the room available to you.
Your age could also be considered.
If you are young and enthusiastic or old and even more enthusiastic, a layout track plan could differ from an experienced or inexperienced person regarding expectations.
One also has to come to terms with, what is in your mind and dreams, including
the realty in front of you.
You have to able to link all three together, because boredom can suddenly appear from nowhere.
Sometimes you need skills you did'nt have before and by building a layout, you are learning very fast and changes in your mind will occur on a regular basis.
You've partly conceeded not much can be done but you'll be surprised having multilevels and helixes can transform a small layout to something substantial.
regards.,
#4 Posted : 05 February 2010 12:38:21(UTC)
Good reply John. As said your layout is not really small and by building upwards you can double or treble the size.
Dont know what you have from Marklin at present but a starter set is always a good idea and they usually come with a helpful booklet containing track plans etc.
#5 Posted : 05 February 2010 12:40:49(UTC)
13X 5 converts to approx 3.9M X 1.5 Mtrs plenty of space to build a nice Layout.
I have 4 M by 1.7 and lots of space.
Have a look at topics in Me and My Layout and also at Layout plans on the Marklin Web site
Offline Writhdar
#6 Posted : 05 February 2010 17:31:59(UTC)
Writhdar
You do have a nice amount of space. I've attached a number of links to layout sites - and, as others in the post have mentioned, there are a number of layout & layout plans in this forum. I would suggest that, even if you have no carpentry skills, you should try for some multi-level. Realize that after building your first layout, you soon may very well want to modify it based on your experiences.
Marklin Magazine layout pages
http://www.maerklin.de/mm/gleisplan_downloads.php
Florian's layout page
http://www.frankenbahn.de/gleisplan/AnlagenplanungE.htm
LCTM (from a forum member)
http://www.lctm.info/Biblioteca/Libros/index.htm
the gleisplan.ch site (don't remember how I came across this)
http://www.gleisplan.ch/index.p...&id=52&Itemid=74
layout depot
http://www.layoutdepot.com/
Track planning software --- a number of forum members use Wintrack (english edition website http://www.wintrack.de/usa.html ). I use Xtrkcad, which is freeware http://www.xtrkcad.org/Wikka/HomePage
--- it has some quirks but I'm satisfied with it.
Offline rhobson1968
#7 Posted : 05 February 2010 20:09:11(UTC)
rhobson1968
I would buy a Marklin C Layout book to get started. There is one listed on EBay under 300366225365. Also, check out Blueridgehobbies.com They are a great source to buy from and they are cheaper than everyone else that sells on-line. Yes, even Charlie.
Never quit building.
Offline Darren W
#8 Posted : 05 February 2010 20:52:11(UTC)
Darren W
Like several members has already said 13' x 5' is a good size for a Marklin Layout. Marklin uses smaller raduis curves and so much more can be accomodated in the space. If you have been looking in North American magazines like Model Railroader they show lots of layouts that completely fill a basement. Using North American 2-rail thinking 4'x8' is only good for a loop and a couple of sidings. I have seen amazing Marklin track plans in the same space. Good luck with your research and let us know what you are going to build.
Cheers...
Darren
Offline VidKidz
#9 Posted : 05 February 2010 22:45:54(UTC)
VidKidz
Thanks for all of the great replies everyone!
I guess I am thinking that not much can be done with my space because I currently run O Gauge Lionel trains, and not much can be done at all with my available space in "O". Also, as noted above, most of the American train magazines feature these huge 30'x20' layouts and I am having a hard time figuring out in my head what I can do with the space I have in HO. Not having a dealer close to me makes it a bit harder as well as I don't have the option of just running down the street to the dealer to see things in person.
I did check out the links above and am very attracted to a layout such as this:
I would need to rework this one a bit to incorporate a small town area as I must have some Faller/Kibri/Vollmer city/town structures. :)
This page was generated in 0.868 seconds.
