Offline Vardex
#1 Posted : 20 September 2006 00:51:58(UTC)
Vardex
You have been a member since:: 26/01/2006(UTC)
Since there is (possible) a need for tips and tricks of how to restore an old model, this is how it's done (by me).
The example here is an old E41,let's start:
Before I start getting the paint of I use the old model to match the new paint. As you can see on the picture a lot of attempts were taken before I got the colour right
Normally you would remove the lights and windows first,but I was too lazy for it!
When you make a coulour write down how many drops of every colour you use,then you have a recepy in case something goes wrong. You then can go to a base you had before very fast,and work from that point on.
After this is all don you can get the old paint of.
For metal models I use thinner. Put the model in,wait a few minutes and brush yhe old paint of with a toothbrush.(test first if this doesn't solve)
Small corners are done by a rather stiff paintbrush
Once all the paint is off I clean the model with a detergent that has a scrubbing effect,such as Cif
Than the model is blown dry with compressed air,but a hairdryer also does the job.
Don't let it air dry,because the zinc alloy will oxidize very fast.
Pay special attention to the different holes and corners,because water will very easily stay in them.
After cleaning and drying it looks like this
Now it's time to paint.
Since I use nitropaint a primer isn't needed,but in this case I used clear primer. The casting already is rather bad,this is why I used it.
It doesn't show,so no picture of this. Don't forget the inside!
The E41 is rather difficult because of the silver line,so I decided to do this first,together with the vents.
When spraying the vents ,spray upwards first to get the paint in the grooves (see picture)
Don't use too much pressure,otherwise you will blow the paint out of the grooves.
And then downwards to get a nice finish of the vents.
When the vents are done than paint the silver lining,the result is shown in the last picture of today.
Next time I will show how to mask the model and the green part of the model is painted.
to be continued...
Bart
#2 Posted : 20 September 2006 00:58:53(UTC)
Great,Keep posted soon.
#3 Posted : 20 September 2006 01:07:48(UTC)
Great Article! Please continue!
Offline HueyCE
#4 Posted : 20 September 2006 01:08:32(UTC)
HueyCE
Neat, I always enjoy these how-to reports.
Ira
Offline PierreGILLARD
#5 Posted : 20 September 2006 02:19:12(UTC)
PierreGILLARD
If you aren't, you should become teacher ! Smile
You have a great pedagogic sense. Congratulations.
Pierre.
Offline Alberto Pedrini
#6 Posted : 20 September 2006 04:50:45(UTC)
Alberto Pedrini
Congratulations Bart, very good "how do it".
The pics are "profi serie"
continue please...
Alberto
Marklinfan Club Italia
www.marklinfan.net
Offline pat
#7 Posted : 20 September 2006 09:51:06(UTC)
pat
Excellent tips,great work thankyou
worse things happen at sea
Offline mj
#8 Posted : 20 September 2006 10:14:30(UTC)
mj
Really great job, Bart! Please continue! Smile
Magnus
Offline orubias
#9 Posted : 20 September 2006 10:55:58(UTC)
orubias
Keep on, good job, nice restoring lessons! Smile
Band on the run
Offline nuno sousa
#10 Posted : 20 September 2006 11:17:31(UTC)
nuno sousa
Thanks for sharing! Great work!
Nuno Sousa
Offline Guus
#11 Posted : 20 September 2006 12:54:58(UTC)
Guus
Thanks Bart.
Please continue your reports.Can't get enough of "how to do" articles.
Nice photos as well [:p].
Guus
Kind regards,
Guus
#12 Posted : 20 September 2006 13:30:14(UTC)
Terrific work and well documented instructions.
Nev
#13 Posted : 20 September 2006 13:34:41(UTC)
Thank you!
Excellent! Keep it up!
Offline Sander van Wijk
#14 Posted : 20 September 2006 14:40:08(UTC)
Sander van Wijk
I'm amazed by your talents as a teacher, please, continue... wink
Sander
#15 Posted : 20 September 2006 14:47:09(UTC)
Excellent, Bart - many thanks. Please give us more ... Smile
#16 Posted : 20 September 2006 14:56:05(UTC)
I so want to see more of this restoration that every time someone posts to this thread I click on it hoping that there are more pictures from Bart. Unfortunately it always seems to be someone else saying they want to see more.
Oh no! I've done the same thing now!
biggrin
Offline al_pignolo
#17 Posted : 20 September 2006 17:54:35(UTC)
al_pignolo
MANY THANKS... [:p][:p][:p] very, very useful... why don't you publish a book (such as: how to restore models?...)
Now I'm just waiting for the arriving of nitro-paint to start with mine!... biggrin
Pietro
Offline Oscar
#18 Posted : 20 September 2006 18:29:36(UTC)
Oscar
Good job!! I want to see the rest!!
Offline Vardex
#19 Posted : 21 September 2006 23:09:50(UTC)
Vardex
First of all let me start with thanking for all the nice replies.
Next update tomorrow! Then it's time for painting the black and green parts of the loco.
Today the only thing is a picture of another 3037 I am working on,that is almost finished. Just to get an impression of how it's going to look.
Tomorrow I will demonstrate 2 different ways to mask the vents (an easy and a difficult way!). The model shown here was done the easy way.
That's it for today,enjoy the picture.
Bart
#20 Posted : 22 September 2006 01:36:16(UTC)
That looks better than the original factory finish on mine.
Looking forward to seing more.[:p]
Offline Vardex
#21 Posted : 23 September 2006 00:57:40(UTC)
Vardex
Part deux!biggrin
Now that we have done the vents and silver lining it's time to add some colour to the model.
I decided to do the green part first.
The final result depends on you masking for a great deal,so take your time for this.
The only thing we don't want to spoil are the vents and the silver lining,so we must mask these with care.
For masking I use crepp tape and scotch magic tape. Crepp for not critical parts,and scotch for the sharp lining.
Let's start.
First of all we will have to cut very fine pieces of tape that cover the doorlines. These can be a little to narrow but certainly not to wide,the tape is rather stiff.
Get a piece of labelstickers and pull the labels off,the paper underneath it is important.
Place the paper on something you can eventually cut,and place a piece of scotch on it.
Take a ruler and cut a very fine line with a sharp blade.
For better view you can colour the scotch using a marker.
After this cut the tape in pieces about 3cm long and pick them up with a toothpick.
Toothpics come in handy when placing delicate pieces of tape on the model.
Tape the model,aligning the tape to the upper side of the silver lining,and working from one side to another,
Also cut some tape for the front,this makes sure the silver lining here is covered. Go all around the front,from door to door.
When this is all done we use the crepp to cover the rest of the doorlining,using crepp.
Cut a part that is wider than the door and place it on the model,using the toothpick again.
Also align with the top of the former tape.
Using the toothpick push the tape into all the corners that need to be covered,making sure it doesn't leave a gap with the scotchtape.
Rest of the lining is after this covered with a piece of scotch.
Fronts are covered with a few pieces of crepp.
Notice the upper part of the silver line isn't covered,this isn't important because later on we will paint this seperately with a brush.
And now the vents;
Place a piece of crepp on your labeling paper and draw two lines on it. This should be the size of the vents,in this case 7mm.
Also draw vertical lines the width of the vents (a little over 12 mm.
Than cut the tape,first hight,than width and pull off the remaining tape.
Now we hve tape that covers the vents. Use a scissor to rounden the corners a little bit.
Place them on the model ,toothpick again, and also use this to fiddle the corners a little bit.
And the result of the masking job
Now we can spray the green paint,paint the inside first.
When doing the outside apply a thin layer first,going from left to right and from top to bottom. Go all around the model. So side,front,side,front.
After this spray the windows and lights with special care,and the rest of the model going from left to right,top to bottom again.
This should be the result when the tape has been removed.
UserPostedImage.
Bart
Offline Vardex
#22 Posted : 23 September 2006 01:14:57(UTC)
Vardex
There is also another way for the vents,I tried this later and think it is easier.
This other model was sprayed green first,than black was applied,lining inclusive.
Silver lining was done taping the green and black part (rather difficult) and vents are described here.
Base is this
Place a piece of scotch on the model,including the high edges of the vent.
Bottom
And top
Cut tape for the space between the vents,place a knive on the tap and turn.
Tape the sides of the vents also including the high edges.
Cut little pieces of tape for the edges and place them on the model.
It doesn't matter that these pieces are straight and the corners of the vents round. When spraying paint will go under them,right to the high edge of the vent.
And the completed masking job
That's it for now,next update sometimes next week.
Bart
#23 Posted : 23 September 2006 01:20:27(UTC)
Great,keep the good work.
#24 Posted : 23 September 2006 01:55:15(UTC)
Alberto Pedrini
Cool[:p]
Alberto
www.marklinfan.net
#25 Posted : 23 September 2006 02:06:41(UTC)
PierreGILLARD
Great paint job, Bart ! [:p]
Have you already tried Maskol or equivalent for masking ?
Pierre.
#26 Posted : 23 September 2006 03:01:25(UTC)
Terrific Instructions.
Nev
Offline Vardex
#27 Posted : 23 September 2006 03:07:05(UTC)
Vardex
<br />Great paint job, Bart ! [:p]
Pierre.
Maskol isn't suitable for nitropaint. The paint gets so hard and durable that you won't get it of.
When removing tape you break the paint on the edges of the tape,maskol is to flexible to achieve this.
Bart
Offline Brakeman
#28 Posted : 23 September 2006 06:17:20(UTC)
Brakeman
Excellent job Bart!
What paint are you using? I mean brand not type.
What do you prefer for the red steamer frames and wheels?
BR,
Juha
Offline HueyCE
#29 Posted : 23 September 2006 19:30:57(UTC)
HueyCE
Seems to me either method requires some patience when doing the masking to prevent overspray. Both shells look great though. Looking forward to the continuation next week.
Ira
#30 Posted : 26 September 2006 14:15:42(UTC)
Thanks alot again.
I am eagerly awaiting the next series!
(When you get to explaining decals and numbering/texting I will decide if I will try my hand on some of my models... ;-)
Specifically about the E41; Would it be worth using a dremel to grind down all the electrical details molded on the roof, and substitute it with spareparts from the catanary system? (isolators, wires, etc...)
Offline Vardex
#31 Posted : 26 September 2006 16:33:31(UTC)
Vardex
<br />Thanks alot again.
Texting is simply done on my printer using white or clear decal paper,and the correct font (DIN 1451 DB). Plates ands signs are photographed and then scaled down.
I am trying to get an alps printer that can also print white,but unfortunately I can't afford one right now.
When it comes to improving the roof,this is easily done. Grind everything down and use a file for the last bits.
I did it once using sommerfeldt insulators,but you best can order the complete set from a roco 141.
I also have a new source for decals to rub on,I am getting the first ones next week. Hope quality is alright.
Bart
Offline Vardex
#32 Posted : 05 October 2006 23:56:08(UTC)
Vardex
Update #3.
First about the question what brand of paint I use; I have no idea! I order them from TTN-shop,and they won't tell me.[V]
Also something about the viscosity of the paint; this should be a little thicker than milk. (buttermilk?)
Again,use low pressure (1.6 bar),and spray rather thick layers.
Nitropaint dries fast,so if one of the above mentioned isn't correct then your layer of paint gets rough.
It also shouldn't be too cold,IMHO above 20 degrees.
In today's update the roof and the black part are painted.
Let's start with the roof.
To tape the front of the roof cut a narrow piece of crepp. This allows you to bent it a little to follow the contour of the roof.
Press it where there is material (between the windows),but don't press in the window area, simply because there isn't anything to press it on.
The edge of the roof has to take care that no paint flies under.
After this tape the sides to the edge of the roof. Since the vents stick out a little I use a dot of paper to press the paper to the edge of the roof.
In general; never put to much pressure on the tape,this will avoid you ripping the paint off when removing the tape. Very big surfaces are best underlayed with plain paper. Also slowly remove the tape after a paintjob.
When all the green parts are covered it's time to spray again.
Start spraying the vents on the roof to make sure paint gets in their small holes.
After this spray the sides of the wires and insulators, also to make sure they are covered all the way through with paint.
And the pantomotors
Next the roof is completely sprayed,starting in the middle, from front to back.
Don't spray downwards on the sides of the roof to make sure you won't spray under the tape.
Also the oilcooler is done now. Watch out for the opposite side of the shell,don't spray to much silver on it!
Et voila!
The black part...
Taping the black part is almost the same as for the green part.
Make yourself some very fine lines of scotch tape (or buy some tape),and go all around taping the silver to where the black starts.
Cover the doors again with small pieces of crepp.
For the fronts cut a narrow piece of crepp and place it on the step,in a way that the underside of the crepp is a little below the silver lining when viewing from the front.
Then fold it using your fingernail and a toothpick. Make sure it doesn't leave a gap with the scotchtape.
Cover the rest with crepp, also making sure the scotch is covered.
Also cover the oilcooler.
Spray the inside first (make a nice patternSmile) by spraying the oppsite side of the shell. Watch out in the window area,if you spray through the windows baint will fly on the outer green parts of the shell!.
If you aren't sure,tape the windows from the inside.
Make sure you don't forget the sides of the trafo etc.
When this is done turn the model over and spray the outside black.
This is the result for today.
Tomorrow the model will be finished (if nothing goes wrong!). Than letters and red parts on the roof are painted. Also a clear gloss finish is applied. This was done on the first 3037 models.
When this model is done,I'll start a topic about improving a 3054.
I will remove the two ugly screws from the roof,and cut the frame in half! Let me surprise youbiggrinbiggrin
Bart
Offline mj
#33 Posted : 06 October 2006 00:14:12(UTC)
mj
Bart, you are a master of this! Looks better than new! I'm really impressed! Smile
Magnus
Offline Vardex
#34 Posted : 06 October 2006 00:17:25(UTC)
Vardex
[size=1" face="Verdana" id="quote]quote:Originally posted by mj
<br />Bart, you are a master of this! Looks better than new! I'm really impressed! Smile
Thanks!
I have never seen a new one,I am not old enough.biggrinbiggrin
Bart
#35 Posted : 06 October 2006 00:51:12(UTC)
I just have to agree with all the above posts. You are an artist, Bart!
Offline Guus
#36 Posted : 06 October 2006 03:02:22(UTC)
Guus
Hi Bart,
Like I've said before absolutely beautiful.As are your pictures [:p]
Better than a book on restauration!
Kind regards
Guus
Kind regards,
Guus
Offline HueyCE
#37 Posted : 06 October 2006 03:40:49(UTC)
HueyCE
Very nicely done, your instructions are 1st class.
Ira
Offline Vardex
#38 Posted : 06 October 2006 16:24:14(UTC)
Vardex
Last update!
Model is almost finished. The only things still to do is the silver lining at the front,roof and lettering.
When silver lining at the fron is done put a little tope over the lights to prevent them from getting silver.
Then paint the line using the side of your brush. This way you won't accidentaly paint the top of the step.
Red lines on the roof are done the same way.
When lettering is done it is adviced to tape the area surrounding the letters.
Letters are done by tapping with a brush and rather thin paint. Apply paint to the brush and use a piece of paper to remove paint that is to much from the brush. Move the brush towards you on the paper without turning it around. This way the brush becomes flat for easy tapping.
You can either use nitropaint or an enamel (humbrol). The advantage of nitro is it,s durability and fast drying. An enamel can be removed, using white spirit, when something goes wrong.
Finally clearcoat is applied.
After the lettering wash all grease from your fingers of,using mild soap and a soft brush.
Then make sure the model is completely dry and clean. Also check your airbrush,especially when you sprayed a metallic paint before. It should be very clean.
Spraying the clear is done the same way as the green or black. Inside first,and then the outside going from left to right,top to bottom etc.
After this all parts are put back on again. When installing the buffers,put some oil in the mounting holes. This will help installing them. Also put a piece of plastic over them when tapping them in.
To finish this topic a picture of the completed 3037. Hope you enjoyed it.
Bart
Offline WelshMatt
#39 Posted : 06 October 2006 16:29:57(UTC)
WelshMatt
That looks as good as new if not better to me - very nice paintwork!
Matt from Wales.
#40 Posted : 06 October 2006 20:07:46(UTC)
Incredible. Congratulations!
#41 Posted : 06 October 2006 20:11:02(UTC)
Congratulations!!!
Offline al_pignolo
#42 Posted : 06 October 2006 23:58:23(UTC)
al_pignolo
[size=1" face="Verdana" id="quote]quote:Originally posted by Vardex
<br />When this model is done,I'll start a topic about improving a 3054.
Bart
You ALWAYS surprise us.... biggrin
I see you haven't painted the little writings under the cabins... whew... I was much worried about it... wink
#43 Posted : 07 October 2006 00:12:34(UTC)
Excellent job.
Excellent description.
A 10!
Thanks a lot!!!
#44 Posted : 07 October 2006 18:55:30(UTC)
excellent ! thanks also for all the extra time it takes to take the pictures along the way...
Offline HueyCE
#45 Posted : 08 October 2006 01:57:52(UTC)
HueyCE
Excellent how-to. Alot of this can be applied to restoring other locomotives.
Ira
Offline ulf999
#46 Posted : 24 April 2007 22:22:45(UTC)
ulf999
EXCELLENT thread and a beautiful work! Thanks (I totally missed this one last year [:I])
Guest (12)
This page was generated in 1.744 seconds.
