Offline charles Sharpe
#1 Posted : 03 December 2009 08:26:05(UTC)
charles Sharpe
Hello.
I thought I was getting on to well. In the last day or two I have programmed seven signals and all went well. then yesterday I went to do the last two for the moment and they just don't want to work. I can get them so they blink red then green I the take the metal clip off the pc board connect them to the track and they just stay on red. I an using a CS2/c track. Any suggestions.
CHARLES SHARPE
Offline Tex
#2 Posted : 05 December 2009 21:53:56(UTC)
Tex
Charles
I had the flashing response on the first signal I installed. I was told that this was due to failure to remove the clip and when I did, the signal worked correctly. If you have removed the clip and the signal flashes it sounds like you have a defective signals. I have four new signals coming in a few and would like to find out how your problem was corrected.
Tex
#3 Posted : 06 December 2009 06:01:53(UTC)
charles Sharpe
Hello Tex.
I am waiting for the replacements to come in at my supplier and the I will go and collect them. As soon as I get them I will let you know how I get on.
CHARLES SHARPE
This page was generated in 0.319 seconds.
