Offline aos
#1 Posted : 21 July 2009 21:06:35(UTC)
aos
Please help me. I have a load of old marklin catenary (actually, it is all brand new as I have never used it since I bought it in the 80's). Looking at the Marklin catalog of the day, it says that on a standard 5100 semi-circle, I should have 5 masts equally spaced with 4 * 7018 lengths of wire connecting them together. I have tried this and when I gently push an electric loco along the track, the pantographs pop up because the wires are way off centre at the middle of each wire [:(] What am I doing wrong? There does not seem to be sufficient length on the wires to bend them into position. If I build a complete 5100 loop and connect the wires onto the masts, it looks like the whole construction is about to collapse inwards [:0] Do I actually need an extra adjustment piece to introduce a bit of 'slack'? Also, what is the exact configuration for a 5200 circle? Thanks in advance. Sorry if it seems a bit of a daft question, [:I] but I have tried it according to the Marklin catalog and it does not work!!
Offline Ian555
#2 Posted : 21 July 2009 21:25:46(UTC)
Ian555
Hi Alan
Ran the overhead on the last layout for 2 years with no problems using both 5100 and 5200 curves.Will look at it next week and you can
keep me rite with the Wintrack.See you then.
Ian
Offline aos
#3 Posted : 21 July 2009 21:29:14(UTC)
aos
Thanks Ian. Were you using the configuration I specified? I shall brush up on Wintrack. Good luck at Santa Pod. Alan
Offline Ian555
#4 Posted : 21 July 2009 21:48:26(UTC)
Ian555
Hi Alan
I seem to remember(layout in boxes for last 20 years)I gently bent the wire to the same curve as the track and that was were the next
mast would be and so on.When the loop was complete you got a piece
of wire that was adjustable between the last 2 masts.Might not be the correct way of doing it but worked really well.
Ian
Offline drstapes
#5 Posted : 22 July 2009 01:24:55(UTC)
drstapes
i would agree with Ian,you have to bend the catenary wires to the curvature of the track and position the masts carefully so that there is no tension.
Geoff (UK)
Offline aos
#6 Posted : 22 July 2009 10:25:11(UTC)
aos
Thanks Geoff. Looks like the Marklin catalog is wrong then!
Offline Renato
#7 Posted : 22 July 2009 12:35:32(UTC)
Renato
Hi Alan,
having a look at the Marklin 0354 layouts catalog, I see that for 6x5100 track pieces, 4x7018 catenary pieces and 5x7009 masts are needed, BUT if the 1st mast is on the edge of the 1st track, the 5th mast is NOT on the edge of the 6th track (and the 3rd mast is NOT on the edge between 3rd and 4th tracks.
Of course you have to bend the catenary elements and compensate for length differences in the straight parts of the layout.
Let me know if you would like to receive by e-mail scans of the 2 pages of the a.m. catalog showing different tracks and catenary configurations (unfortunately not for 5200 tracks, but if I send you the proper track layout, you have all the tracks, accessories and catenary parts listed).
Bye
Renato
Offline aos
#8 Posted : 22 July 2009 13:50:35(UTC)
aos
Thanks Renato, I have emailed you. Alan
This page was generated in 0.708 seconds.
