Offline gbraux
#1 Posted : 12 November 2005 21:37:29(UTC)
gbraux
I have a "very very very" strange problem when running 76391 digital signals (i use them in an analog way ...).
I have 3 76391 signals.
--> When I connect (yellow & brown cable) each signal alone on my 60VA transformer, the connected signal works (red light ON...).
--> When I connect 2 signals on my 60VA transformers, the 2 signals work (the two signals have red light ON).
--> When i connect my 3 signals at the same time (on the same 60VA transformer), it DON'T work ... No red light, and a strange "blinking" noise comming from the relays on the 3 signals ...
The strangest thing in this story is that each signals works with no problem when they are connected alone on the transformer ... Still work when two are connected, but not when 3 are powered ...
Any ideas to resolve this problem ?
Guillaume
Offline perz
#2 Posted : 12 November 2005 22:41:15(UTC)
perz
No other load on the transformer ?
Offline gbraux
#3 Posted : 13 November 2005 00:16:16(UTC)
gbraux
[size=1" face="Verdana" id="quote]quote: No other load on the transformer ?
--> Absolutely not ... The 60VA transformer is only connected to the signals
It may come from a transformer failure (i cannot test this transformer "on load" as my mobile station is at marklin "reparturenservice"; but the transformer worked well with the MS before ...).
#4 Posted : 13 November 2005 01:54:11(UTC)
Another transformer to test this would be a good idea... Where are you? One of us might live nearby and can lend you a transformer for a test..
This page was generated in 0.355 seconds.
