Offline gachar001
#1 Posted : 20 April 2009 23:06:29(UTC)
gachar001
India
My 37361 Ae 6/6 loco does not have the horn function when used with my CS2. Most other sounds and functions are there. The horn is available when used on the MS. I deleted the loco from the CS2 and added it again with the same results.
My other Ae 6/6 which came with the 29680 starter set (which I assume is functionally identical to the 37361) has all the functions and many more sounds on the CS2 than the 37361.
How can this be fixed?
EDIT - I take back the following paragraph since I was mistaken. The problem above still exists.
Also, my locos with Loksound 3.5 show only 4 functions with the CS2. They had 5 when used with the MS (For example, Light, Sound on/off, horn 1, horn 2 and blower sound). On the CS2 they show only 4 including the light). Do I need to program the other functions on to the CS2? If so, how? The decoders have many other functions (8 - I think) when I view them with my LokProgrammer. Do I need to play with the CV 49 to activate all sounds?
Thanks.
Gautham
Atlanta, GA USA
#2 Posted : 21 April 2009 23:20:51(UTC)
What function number is the horns?
Offline gachar001
#3 Posted : 22 April 2009 03:23:27(UTC)
gachar001
India
<br />What function number is the horns?
In the CS2, the Ae 6/6 which came with the 29680 starter set has the horn in the F3 position (4th key from top). On the 37361, this position is blank. Also in the 37361, the F6 position is blank whereas the other loco has a sound function.
Gautham
Atlanta, GA USA
Offline gachar001
#4 Posted : 26 April 2009 18:28:08(UTC)
gachar001
India
This problem has been fixed using advice I received on another post.
Gautham
Atlanta, GA USA
This page was generated in 0.285 seconds.
