Offline aos
#1 Posted : 28 December 2008 22:16:13(UTC)
aos
I need to purchase some of the above tracks. I have some 5104 and 5105' and they work with no problems. What is the difference between these and 5146 and 5147 track sections apart from the obvious size. If they perform the same function, which would you choose as a personal preference. Thanks.
Offline amartinezv
#2 Posted : 29 December 2008 00:50:21(UTC)
amartinezv
You can do the track by yourself, I do mine, as you can see at:
http://www.terra.es/pers...os/Trucos2.htm#deteccion
Please use a translator, bus it is very easy
Another marklinist Dale Schultz also does something very similar
Luck and greetings
Antonio Martínez
www.raildigital.es/davidruso
Offline aos
#3 Posted : 29 December 2008 00:59:22(UTC)
aos
Amartinezv - Many thanks. My daughter is learning Spanish, so I shall ask her to interpret for me. I have taken a quick looksee and it does look easy.
Offline Minibahn
#4 Posted : 29 December 2008 01:33:31(UTC)
Minibahn
with 5104 and 5105 every wheel gives the function, with 5146 and 5147 every pickup gives the function and you have different functions for each direction.
Regards Charles
Offline aos
#5 Posted : 13 June 2009 18:02:58(UTC)
aos
I have managed to purchase a number of 5104 and 5105 metal track contact sections. I have been testing that they are all working ok.
Does anybody know the maximum number of electrical items, say solenoid operated points and signals which can be operated from one contract track?
I don't want to cause an electrical overload and thus craete a fire hazard.
Is it documented within the Marklin website at all? Thanks in advance.
Anybody any thoughts?
Offline evillarreal
#6 Posted : 25 February 2020 02:32:27(UTC)
evillarreal
Bolivia
Luck and greetings
Hola Antonio,
El enlace lleva a otro sitio, tendrías uno actualizado?
Muchas gracias y saludos desde Bolivia
Enrique
#7 Posted : 25 February 2020 10:08:23(UTC)
Just be careful with trying to drive too many solenoids from a single contact. Those circuit tracks are finicky enough without adding to the problems.
In theory, you can drive as many solenoids as your trafo will allow. You will need to know the current-draw of the device and then ensure you have sufficient (VA) available.
But the bigger concern is the more current you draw, the bigger will be the arcing when the contact breaks and this over time will burn the contacts leading to unreliability. As I said, those contacts are touchy, and not easy to clean without distorting them - they are a bear to adjust.
They are really intended to operate just one, maybe two solenoids. If you want to operate more, say for automatic route-setting in a cascading storage yard then you are better off using the circuit track to power a more robust universal relay and have that relay power the others. Or do it with electronics BigGrin
Jay
Offline amartinezv
#8 Posted : 25 February 2020 10:25:32(UTC)
amartinezv
Luck and greetings
Hola Antonio,
Enrique
Hola,
Mi pagina deje de actualizarla ya hace bastante tiempo, pero todavia está online
http://www.raildigital.e...os/Trucos2.htm#deteccion
Ultimamente he empleado otro método, que consiste basicamente en aislar un rail del cuerpo de la via, es algo laborioso pero funciona, pero no lo he documentado.
Saludos
I stopped updating my page a long time ago, but it's still online
Lately I have employed another method, which basically consists of isolating a rail from the body of the track, it is a laborious thing but it works, but I have not documented it.
Greetings
Antonio Martínez
This page was generated in 0.532 seconds.
