Offline rschaffr
#1 Posted : 15 December 2003 20:55:52(UTC)
rschaffr
When I was at the display in Merkilngen, I noted that their turnouts moved with realistic motion, not the snap motion you usually have with electomagnetic switch motors. Does anyone know a source for such devices?
-Ron
Offline dampf
#2 Posted : 15 December 2003 22:39:10(UTC)
dampf
Yep, Brawa sells them biggrin... check the catalogue...
Jay
jay kempen
Offline rschaffr
#3 Posted : 15 December 2003 22:49:07(UTC)
rschaffr
Jay:
Didn't even think of Brawa...
-Ron
-Ron
Offline grattieri
#4 Posted : 16 December 2003 09:35:18(UTC)
grattieri
I suggest to check also Tortoise Slow Motion switching machines.
Ciao Marco
br01
Offline Thanos
#5 Posted : 16 December 2003 09:52:25(UTC)
Thanos
This is a shock to me!! I never knew that there are slow moving turnout motors! [:0] If I knew that I wouldn't have bought a single motor from Marklin!!! [:(] Thanks for the info though!!! It will be good for everybody!!!
Thanos
Offline grattieri
#6 Posted : 16 December 2003 10:20:48(UTC)
grattieri
Dear Thanos
I remember very well that Tortoise Slow Motion is
strongly raccomanded by Model Railroader ; I have
read some articles about fitting and trimming this
kind of motors . In any case it's necessary to remove
the spring of the turnouts and to fit these motors
underfloor.
Ciao Marco
br01
Offline Noel Loganathan
#7 Posted : 16 December 2003 23:19:24(UTC)
Noel Loganathan
Hi all
We have seen the tortoise work. They look realistic and the speeds can be adjusted (if I can recall correctly)
However it is bulky and green. Perhaps looks better when hidden - I mean under the layout.
Cheers for now
Noel
Noel
Offline Nuno
#8 Posted : 17 December 2003 17:48:14(UTC)
Nuno
I once read about these slow motion motors for turnouts, but I thought they were meant for big scales.
Are they really worthwhile for H0? I mean, is their effect really noticeable? We are talking of a motion of about 3 milimeters...
In any case, where can I find these Tortoise motors? Could you indicate a web-site address, please?
Or are Brawa ones better?
Nuno Smile
Offline rschaffr
#9 Posted : 17 December 2003 20:14:04(UTC)
rschaffr
Nuno:
It really is a noticable difference. I plan to use them in the visible areas of my layout. I'll still use the electromagnetic in the hidden areas, due to expense.
-Ron
-Ron
#10 Posted : 17 December 2003 22:34:28(UTC)
I dunno..... These may be too slow for miss 4, who won't wait for a slow turnout.. Like her mother, who has experienced the top speed of everything mechanical we own, she knows the top speed of the Swiss 460s!Cool
Offline Nuno
#11 Posted : 18 December 2003 21:57:45(UTC)
Nuno
I am now quite enthusiastic about this! But I have a lot of questions...
Which one do you recommend? Brawa or Tortoise? Does anyone of you have any of these?
How do you make the connections? Can you hide the motor completely under the layout?
Do you have any pictures or schemes about this?
Nuno Smile
Offline rschaffr
#12 Posted : 18 December 2003 22:47:42(UTC)
rschaffr
Nuno:
I now have two Brawa motors on order. As soon as I get them I'll let you know how they work out.
-Ron
-Ron
Offline rschaffr
#13 Posted : 18 December 2003 22:48:57(UTC)
rschaffr
Heh. Just got e-mail from the Lok Shop. I have two Brawa motors on BACK-order.
-Ron
-Ron
Offline Nuno
#14 Posted : 20 December 2003 01:53:49(UTC)
Nuno
Thanks Ron, that's great!
I'll be waiting for the results of your tests.
Nuno Smile
#15 Posted : 20 December 2003 02:41:02(UTC)
Views messages in topic : 11,162
I seem to recall that also Peco has some nice slow-motion stuff...
Kevin, didn't you use these on your layout?
Offline KLB
#16 Posted : 20 December 2003 18:53:51(UTC)
KLB
I use Peco's on my layout,but they are more like snapping turtles biggrin
I have seen Tortoise's in action,slow,very nice made for under baseboard monting.The reason I went for the Peco's was price,I got them for about $5.00 a piece,where as the cheapest price for the Tortoise(at the time) was $13.95 and this is when you buy them in bulk,...wink
Kevin!
Moderator,Märklin Bar&Grill
http://groups.yahoo.com/group/MarklinBandG/
Offline Bart
#17 Posted : 22 December 2003 01:58:43(UTC)
Bart
There are several slow turnout motors, like Hoffmann, Peco, Brawa and Lemaco (may actually be the same as Brawa).
Personally, I am not too fond of these mechanical motors with many moving parts and contacts. They are noisy, and although I may be completely wrong, I am not sure about their durability. My M-turnouts from the early 1960s still function, and I would like to see my present acquisitions also to last for at least 40 years. Moreover, the Brawa costs aroud Eur 16.50 at Lokshop, which I can't afford.
Planning a large layout wtih approx. 90 turnouts (which probably will never be finished [:p]), I am still searching for cheap, simple and durable motors.
On my test track, I have been testing the Viessmann 4550 drive, which is the base part of the Viessmann semaphore signals. It uses the electromagnetic principle with 2 solenoid coils, but the piston moves through a fluid damper, so that the movement is slow, and even adjustable. Also, since it has been designed to drive signals, it has an additional switch (the 2 red wires), which may be used for feedback of the turnout state or for other purposes.
Mounted horizontally under the baseboard, its wire is bend to a 90' angle upward to directly drive my K-turnout.
However, I am not happy with its function yet. It is quite large (approx 10cm), and its wire is difficult to adjust (read: not at all). I will try to add a formal joint and axle under the baseboard, to adjust the travel and to prevent the sideways movements, but this would add to the price and the amount of work. Thus, I'm searching for other solutions.
I am now testing the Hoffmann / Conrad switch motors, which may not be very durable as well (just a pessimistic guess), but at least, they are cheap (Eur 6). They are very well adjustable and easy to be installed, which is a great relief after all the problems I had with the Mä under-baseboard mounting sets 7548/7549. I will let you know my Hoffmann experience in the future.
*Bart
This page was generated in 1.007 seconds.
