Offline Topher
#1 Posted : 11 September 2002 01:28:45(UTC)
Topher
I am trying to evaluate the WinTrack software using the demo. I cannot figure out how to flip just one piece of track 180 degrees. For example the tracks are appending to the right, but now I wish to add a turnout in the 'other' direction. Do I have to start a new section of track (Edit, New Start Position) to do this?
After doing this I have a number of sections that I need to merge. What do the 'link end points' and 'merge track ends' do? I would expect one of them should 'connect' the two ends by moving one section of the track. Even if I disconnect my track to make sure I have a small section that is free to move, neither link nor merge works.
The demo does not come with the help file.
Topher
Offline daniel
#2 Posted : 13 September 2002 13:58:33(UTC)
daniel
hi Topher ,
first sorry but my English is ...bad<img src=icon_smile_sad.gif border=0 align=middle>
I hope I can help you with your little problem : look in the functionlist , left from " flex " and " flex 20° " you see 3 buttons ;left track , right track and left and right track with an arrow in between , that's the button to flip your track or your turnout in the other direction
daniel
Marklin ...yes !
Marklin ...yes !
This page was generated in 0.392 seconds.
