#1 Posted : 19 April 2024 17:48:40(UTC)
I did watched new video at Youtube that there are customer who did bought Märklins new BR78.10 39782 and just after few minutes by pull wagon set the locomotive slips on the tracks!
With difference video links they did show same problem.
So a tip...if you shall buy BR78.10 think first before you buy it.
The locomotive model is not even worth 499,00 € to buy.
Cursing
#2 Posted : 19 April 2024 19:51:45(UTC)
Cursing
Could we have a link to the video please
Offline Marklineisenbahn
#3 Posted : 19 April 2024 20:19:53(UTC)
Marklineisenbahn
Cursing
Goofy ,
Hopefully you have a great time bashing the brand ! Let me tell you something buy one first and see for yourself and don’t depend on what you have seen or heard on U-tube !
What others are saying cause internet is full of trolls! Some even get paid for their content and complains.
After all, you are a constant discontent and pessimist from the get go regardless of the situation. So stop complaining cause you don’t have a locomotive.
Myself actually I own one BR78.10 and I can’t complain about it.
Marklineisenbahn
thanks 7 users liked this useful post by Marklineisenbahn
#4 Posted : 19 April 2024 23:48:27(UTC)
Goofy probably saw this video:
Unfortunately he missed this text under the video:
"Ein Duell der BR78.10 und der BR38 von Märklin im Gleiswendel hoch fahren unter 3% steigung! Leider hat die BR78.10 nicht es geschaft mit der Fahrstufe 59 von 100 km konstant durch zu fahren wie bei BR38 war das eher besser mit der Fahr leisteung. Zum schluss kommt kurz die BR64 mit konstanter Geschwindigkeit locker hoch."
Google translation:
"A duel between the BR78.10 and the BR38 from Märklin in the spiral track driving up under a 3% gradient! Unfortunately, the BR78.10 was not able to drive consistently over 100 km at speed level 59, as with the BR38 the driving performance was rather better. Finally, the BR64 comes up easily at a constant speed"
And this comment from the guy who made the video:
"Die beiden sind im R1 im Wendel nicht sehr gut hoch gekommen aber die kleine BR64 hat das besser hin bekommen. Vielleicht liegt es am Wendel aber habe ihn extra umgebaut. Leider kann will ich die ganze Anlage nicht völlig neu bauen da ich kein Haus habe"
Google translation:
"The two of them didn't get up the helix very well in the R1, but the small BR64 did a better job. Maybe it's the helix but I rebuilt it specifically. Unfortunately, I can't build the entire complex from scratch because I don't have a house"
Of course there's no reason to mention the 3% grade on a radius 1 badly build helix, if you just want to bash Märklin BigGrin
P.S: It can't be this video Goofy has seen:
#5 Posted : 20 April 2024 06:57:41(UTC)
Offline Copenhagen
#6 Posted : 20 April 2024 10:03:57(UTC)
Copenhagen
This is so Goofy (try and google "what does goofy mean" BigGrin
The first link is just to a long list of youtube videos!
The second shows the locomotive going up an incline presumably without any problems? It starts from a standstill and then slowly moves forward and accelerates.
The third shows the locomotive on a flat layout.
Of course Maerklin is not fault free. I have a Maerklin steamer where the traction tires should have been placed on another axle to improve the traction capabilities.
#7 Posted : 20 April 2024 10:04:06(UTC)
@Goofy: This is actually funny, you have just proven the opposite of what you wanted LOL Laugh LOL
Your first link takes us to all videos with the 39782, that doesn't give us anything BigGrin
The second link takes us to the same video I posted above, made by a guy who wants to show how well his 39782 behaves,
when starting from standstill on a curved grade Laugh LOL Laugh
The third video is made on a layout with a clearly visible "hole" in the tracks, so bad that the wheels of the 39782 is even spinning
when slowing down ( from 10:25 in the video - and also noticed by some of the commenters on Youtube ), because the locomotive
is more or less hanging on the leading axles BigGrin
If you look at the video at 11:05, after the departure of the train, you can clearly se the "hole" / "bend" in the tracks, where it should
have been a smooth transition.
One of the comments related to the steep change in grade:
"I'm not sure if my comment is stupid, but was this place intentionally built so steeply that it shouldn't be? I mean you can see with the naked eye how the route climbs on the short stretch!"
And you have clearly missed the several comments from the other video viewers, telling how well the locomotive behaves on 4% grades LOL
"I now have a huge system with gradients that the locomotive doesn't care about and I also have the train on it. My highest gradient is 2 percent and without any problems and we also tested it with my friend, he has it too and the train at 4 percent without any problems!!"
"An hour ago I had both trains running one after the other with my friend with 4 percent no problems"
This one apparently had a problem with the loco pulling the tender off:
"I'm surprised that the locomotive even pulls the cars. On my 78 1001 the tender came off immediately while towing. This is a cheap connection with no grooves to lock into place. A few drops of glue and the tender brought close to the locomotive. The locomotive stops, drives and pulls the cars over my layout with gradients of just over 4%. The locomotive tender problem also appeared on 781002. Greetings Roland"
thanks 5 users liked this useful post by Purellum
#8 Posted : 20 April 2024 11:18:55(UTC)
Just hook up wagons on the locomotive and it start at once slips.
Did you even watched videos???
Confused
#9 Posted : 20 April 2024 13:00:23(UTC)
Yes, I watched the videos, and especially this one, linked by you, which shows the exactly opposite of what you're saying:
One of the comments to this video is, Google translated:
"The result is impressive. Starting with the trailer in a curve with an incline. And that with 2 traction tires"
LOL Laugh LOL Laugh
The big question is: Did you watch the videos, and did you understand what they're about? BigGrin
Offline bph
#10 Posted : 20 April 2024 13:10:14(UTC)
Well spotted ThumpUp
Actually, the performance is quite decent when you take into consideration that it's on poorly laid tracks with a 5% incline and with a "hole" and in a curve. (ref from the youtuber: Ja, an der Teststelle sind es 5% MIT LEICHTER NEIGUNG in der Kurve. Ansonsten würde der Zug auch die 5% hier packen).
Several of his other locomotives also struggle in the exact same spot, E.g. in this video at 12:35 https://youtu.be/rvkq9eUI3oI?t=755
And as you say the "second video" is made to show that the locomotive actually performs quite well.
#11 Posted : 20 April 2024 13:42:48(UTC)
Some others Märklin locomotives does also have slips problem which you can see in others videos. I am pretty sure that the problem are Märklin tractive effort like BR78.10 are wrong. The place of rubber tires are wrong. That is the problem which you confuse about it.
#12 Posted : 20 April 2024 14:52:33(UTC)
Not only Märklin, it's actually a quite normal thing BigGrin
Many has tried to replicate this in models, so far only Märklin has made it so it looks real BigGrin
#13 Posted : 21 April 2024 11:18:30(UTC)
I think we went through this before especially with the new BR 38, so Märklin added another axle with rubber tyres, they may, if necessary do the same with 78.10
#14 Posted : 23 April 2024 05:17:37(UTC)
What!?
It is same problem like before.
There are just only two rubber tyres in the wrong wheels.
#15 Posted : 23 April 2024 05:23:06(UTC)
Here i have tried to help you with information and i know that there are members here who have also complained about Märklin locomotives which usually slide in curves with wagons in tow.
And you´re kidding??
It´s a tragic to see that you are not serious when we discuss a problem that cost nearly 500 € that are waste money.
Confused
/* And on that note we close this topic. */
Edited by moderator 23 April 2024 21:01:43(UTC)  | Reason: Not specified
This page was generated in 0.673 seconds.
