Offline hotrainset
#1 Posted : 20 April 2005 21:23:58(UTC)
hotrainset
I have a dc system track with the Harry Potter theme. I have recently purchased an beautiful Marklin Harry Potter train that is in the ac system that I would like to convert to dc so that I can run it on my track. Do any of you know how to do this? If so, can you give me directions. Much appreciated.
Please feel free to email me directly at info@moxie-webdesign.com
Offline rugauger
#2 Posted : 21 April 2005 01:46:00(UTC)
rugauger
Hi Marlene, and welcome to the forum!
Unfortunately, it will not be easy to convert your Marklin set to run on DC track. In DC, one of the rails is the + and the other the - . To be able to run on DC, the two wheels on each axle have to be electrically insulated from each other, otherwise you will get a short circuit. And Marklin does not have insulated wheels since it uses the centre pickup for the + and BOTH rails for the - .
Whilst you could possibly change all the axles in the Marklin coaches, changing them on the loco will be nearly impossible, at least without specialist equipment.
Since this forum is made up of Marklin afficionados, I suggest you go the other way: get rid of your DC track and run your DC equipment on Marklin track... Smile
Richard
Offline HueyCE
#3 Posted : 21 April 2005 01:47:52(UTC)
HueyCE
Welcome to the forum Marlene.
Ira
Offline McLae
#4 Posted : 21 April 2005 03:11:18(UTC)
McLae
The only technique I can think that might work:
Order the AC spare parts, and retrofit these on the DC item. Of course this only works if the item is available as AC and DC (such as wheels and Trix or some Roco Loks). wink
The McLae
Offline Sam
#5 Posted : 21 April 2005 08:08:01(UTC)
Sam
Wow! A female!!!
That is a breath of fresh air..
Welcome to the Forum.. I would advise against tampering with the Harry Potter Marklin, as it's a limited edition item, and some day (not too soon, but some day), will be worth a lot to a collector.
I would, if I were you, set up a small 3-rail circuit in your layout, even if it's just a small station, or a few feet of track, and display the Marklin there, parked at the station.
This is of course my opinion, and you need to do what you want in the end that will make you happy. The cost of total conversion is not going to be astronomical, but it will be high. I know of a few people who specilze in this type of work (one in the SF Bay Area), but he have 6 month back logs, and charge a lot (more the the cost of the set). Another is not as busy and less experienced, but will charge much less. Goto www.Trainsahead.com and email him... his name is Raman.
Era I-V / HO & 1 Gauge / C-Track & Mobil Station, with Central Station.
Offline Guus
#6 Posted : 21 April 2005 14:47:53(UTC)
Guus
Hi Marlene,
Welcome to the forum Smile.
Guus
Kind regards,
Guus
Online Munich 1860
#7 Posted : 21 April 2005 16:38:06(UTC)
Munich 1860
Hello Marlene,
and also welcome here. I noticed from looking at your well-made homepage that indeed this Harry Potter theme is your favorite. If you find the time, you should try to get hold of an old copy of Marklin Magazine, namely 5/2004 (maybe through Ebay).
In it somebody created a unique Harry Potter layout. A rotating motor was built into the layout and hidden underneath it. On a tiny rod that was rotated by the motor, you could find a model of the Weasley's family car ....
In effect, every time the train came out of the tunnel, it was chased by the car, which seemed to fly in the air !!!
This was one kind of a funny idea !!! Maybe some of our friends on this forum have some pictures scanned and could post them, making it unnecessary for you to search for the whole magazine ???
Online Munich 1860
#8 Posted : 21 April 2005 16:49:37(UTC)
Munich 1860
Hello again,
I think I found photos of it on the net ... But now I think copyright should be at least remembered and the origin mentioned:
http://www.ige-hg.de/Home/home.html You want "Bildergalerie", German for picture galleries
Have fun !!!
Johann
Edited by moderator 11 January 2011 16:31:34(UTC)  | Reason: Not specified
Offline Hans_Dietrich
#9 Posted : 21 April 2005 17:06:22(UTC)
Hans_Dietrich
Hi and welcome to the forum.
I had a look at our Harry Potter train and I have to agree with the above comments.
Unless you could obtain isolated wheel sets as spare parts (I don't think they exist from Marklin), it would be very labor intensive to modify the wheels. And then you would have to fashion contacts to pick up the current from the wheels. Of course, it could be done.
You said that your layout has a Harry Potter theme. Do you have already a DC Harry Potter train? We also have the Bachmann DC Harry Potter set. And while I consider the Maerklin set a Maerklin "Hobby" e.g. entry level quality set, the Maerklin train is very much superior compared to the Bachmann one. That said, yes, give the Maerklin train a run. You may find that it is worth the effort to have the Maerklin train as part of your layout as Sam suggested.
I assume you did buy the whole set with tracks?
Sorry for not having a better answer ... Hans
Hans ... Epoch I to V, M-track, IB with MS
Offline rschaffr
#10 Posted : 21 April 2005 17:14:36(UTC)
rschaffr
Marlene: Welcome. Very nice work. I agree wit the others...perhaps the conversion COULD be done, but it may not run well or be worth the effort. I believe that Weinert sells DC wheel sets for their loks...perhaps some could be found to fit yours if you really intend to proceed with this.
-Ron
#11 Posted : 21 April 2005 18:13:29(UTC)
Hans_Dietrich
Oh, I just saw your very nice layout on your web site!
It is possible to convert the Bachmann train to run on Maerklin AC.SmileSmileSmile
There is one other solution I can think of. One forum member (in Italy I think) has modified Maerklin C-track to be used both as a 2-rail and a 3-rail system, but NOT simultaneously.
As such, Peco, is selling center rail contacts which would allow you to modify your DC-rail. See what it would look like at
https://www.marklin-user...452&SearchTerms=peco
By adding the center rail contact and making the proper track connections you could run trains either in 2-rail or 3-rail mode, but not at the same time.
Sorry, but all the suggestions seem to be cost and/or labor intensive.
Hans
#12 Posted : 21 April 2005 19:29:28(UTC)
Hi Marlene, welcome Smile to The Forum. Congratulations - very nice site, beautyful layout! And your "Rocket" is just cute ... [:p]
BTW, I'd NEVER invest my hard earned cash in such a conversion - since nothing will be right in the end ... [xx(]
Best Regards
Offline hotrainset
#13 Posted : 21 April 2005 23:55:00(UTC)
hotrainset
Thank you all very much for your comments and compliments. Smile Very much appreciated. So now I have do to some thinking about this. Do I convert it or not is the question.
To answer some of your questions. I do also have the Harry Potter Bachman set which is inferior to the Marklin set (I only got the trains, not the whole package, got it on ebay). I have the Weasley car as well and was planning to hang it up near the castle almost crashing into the willow tree which I don't have up yet.
I guess I am a rareity (a woman building all of this). My Dad gave me some trains and I proceeded from there.
Keep the comments coming please if there are any more out there. Thanks!!
#14 Posted : 22 April 2005 00:17:48(UTC)
Welcone to forumSmile
#15 Posted : 22 April 2005 02:02:58(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by hotrainset
<br />I guess I am a rareity (a woman building all of this)
Not at all, Ma'am - just browse the members section Smile
This page was generated in 0.747 seconds.
