Offline Moris
#1 Posted : 06 January 2026 09:26:28(UTC)
Moris
Hi All
I'm planning to add some bumpers with light (24978) to my digital layout powered by a CS3+. These bumpers use the outer rail (O) as the return path for the lamp, which means I'd have to connect the brown wire from the 6647 analog transformer I use to power miscellaneous lights to the outer rail of my layout. Could this be dangerous for the CS3 in any way?
Thanks, regards.
Maurizio
60216 CS3+ with 60175 Booster, Mostly Era III & IV German and USA Diesel & Steam Loks, C-Track Layout (always under construction...)
#2 Posted : 06 January 2026 09:42:10(UTC)
It's dangerous if the yellow output of the 6647 touches the centre rail of the CS3.
Offline Moris
#3 Posted : 06 January 2026 10:13:39(UTC)
Moris
It's dangerous if the yellow output of the 6647 touches the center rail of the CS3.
Thanks... there's no risk the yellow output of the 6647 touches the center rail of the CS3, only the brown outputs/wires of the CS3 and 6647 (ground) would be connected together via the outer rail.
This page was generated in 0.217 seconds.
