Offline jonas_sthlm
#1 Posted : 26 November 2025 11:52:30(UTC)
jonas_sthlm
Does anyone know if it would be harmful for an SDS motor if you connect it to some type of power backup easy capacitor on +Ub/GND?
I install them on others without any problems so...
This installation has a buffer capacitor installed.
BLDC Motor Controller für bürstenlose Motoren (C-Sinus, SDS und Maxon EC)
Edited by user 29 November 2025 09:26:01(UTC)  | Reason: Not specified
Offline jonas_sthlm
#2 Posted : 27 November 2025 17:02:31(UTC)
jonas_sthlm
I gave it a try with 1000uF 25V capacitor, but it doesn’t seem like the LED stays on for longer Mellow
The sound module was connected here for39894Br189/441 with its original LokPilot V3.0 M4 decoder.
I tried with a 2200uF 25V and connected an LED directly on capacitor, and it lights up when the power is cut but not the locomotive.
So, the conclusion is that the capacitor doesn’t function with the standard SDS configuration when the GND (-) is connected directly to the engine Huh
It turned into a slightly simpler solution by using a direct cable LOL
Edited by user 29 November 2025 09:32:10(UTC)  | Reason: Not specified
Online kiwiAlan
#3 Posted : 28 November 2025 14:03:08(UTC)
If you are connecting it directly to the chassis of the loco, no that will not work.
Offline jonas_sthlm
#4 Posted : 28 November 2025 14:49:12(UTC)
jonas_sthlm
I don't follow you, doesn't ground with chassi...
Follow the connection line as it goes into the connection for the SDS engine.
This link has an interesting article, so fischer-modell.de can maybe be the solution...
Offline jonas_sthlm
#5 Posted : 28 November 2025 23:54:07(UTC)
jonas_sthlm
It seems to work better with T44...
It works with the LED stay on longer when standing still, but the movement stops immediately if it loses power Mellow
I feel like there are just too many components on the circuit board for a capacitor to keep it running and AUX4, even with 2200uF.
I’ll probably remove the capacitor if it doesn’t seem to provide more than LED functionality after some test driving.
Edited by user 29 November 2025 16:50:05(UTC)  | Reason: Not specified
thanks 2 users liked this useful post by jonas_sthlm
Online bph
#6 Posted : 29 November 2025 15:30:19(UTC)
Good work, thanks for the pictures and information.
Offline jonas_sthlm
#7 Posted : 30 November 2025 12:56:01(UTC)
jonas_sthlm
Would have been nice to see some kind of video of the BR 218 that confirms that installation.
So I will try move the capacitors over to a newer T44 without the SDS motor and see the results later.
This page was generated in 0.542 seconds.
