Offline Boris Orloff
#1 Posted : 03 September 2025 00:28:38(UTC)
Boris Orloff
I have a fairly large layout run by a CS3+. Recently I had to replace my main bus under the table as the CS3 was giving me that a short existing somewhere on the main line. I reconnected the first feed and everything worked fine. When I connected the second feed no matter where it was, my CS3 reset itself. When I removed the second feed all was fine again. Has anyone else encountered this problem?
Offline BenP
#2 Posted : 03 September 2025 01:01:20(UTC)
BenP
Second feed R-B wires crossed?
B
thanks 2 users liked this useful post by BenP
Online rhfil
#3 Posted : 03 September 2025 13:21:56(UTC)
rhfil
Get a multi-meter and start checking dc voltage from the closest to the CS3 and out. If the voltage changes polarity you have reversed the wires. I am assuming you have three rail.
#4 Posted : 03 September 2025 18:31:15(UTC)
Boris Orloff
I tried it both ways at each location. It still resets when I try it with the second feed.
thanks 1 user liked this useful post by Boris Orloff
#5 Posted : 03 September 2025 19:11:34(UTC)
Hi Boris
You know by now that your CS3 has NO problems and that you have a short circuit on the second feed
Here is the process to locate where the problem is:
  1. remove all rolling stock from your layout and check if the short is still there
  2. break the faulty zone into smaller zones tryng to detect when the short appear while adding a new set of tracks
  3. investigate the small zone causing the short on continue until the one track level
  4. the result may be obvious or very unconspicuous. E.g. in M track a switch point spring burnt by a short and extended to the stud line. Another example is the result of using a dremel disk producing fine and invisible metal dust making the short, a forgotten tool on a track
#6 Posted : 03 September 2025 19:48:15(UTC)
When the first feed are okey and still you have all trains on the track without short circuits.
If you feed the second and it appears short circuits you did swapped the wires somewhere.
Are you use booster too?
Online rhfil
#7 Posted : 03 September 2025 21:34:33(UTC)
rhfil
He indicates that wherever he connects the second feed he shorts out. So, if he is doing it correctly the problem can't be on a section of track but in the second feed. But I wonder if he has isolated the sections of the layout that he is feeding with the busses. If not that might be a solution. Or at least a means of working towards a solution.
Offline PerR
#8 Posted : 03 September 2025 22:43:30(UTC)
PerR
if your CS3 resets, maybe you should check your configuration of the powersupply in the CS3 configuration in the GFP3 section.
If there is a mismatch between the powersupply you are using for your CS3, and the configuration in the GFP3 section, you can get into problems.
If you have an 60 VA powersupply and your configuration in GFP3 is set to a 100 VA powersupply (60101), then the currentlimiter is set to 5 Ampere, and because a 60 VA powersupply is designed to deliver 3 Ampere, the the currentlimiter will not be able to register a short circuit, and the CS3 could reset due to voltage drop from the powersupply.
I have seen a lot of times that the GFP3 configuration is wrong, and the users are not aware of what could happen if the configuration is wrong.
Per
thanks 1 user liked this useful post by PerR
#9 Posted : 04 September 2025 03:04:20(UTC)
Boris Orloff
The CS3 was set for a 60101 but I can't set it for the actual one that I use a 60 watt 60065 (that is what the manual calls for). The pull down menu only has 60042, 60043 and 60045. The voltage indicator reads 19.4v.
Offline PerR
#10 Posted : 04 September 2025 07:51:12(UTC)
PerR
for sure, you should not set it to 60101, because 60101 is a 100 VA powersupply, and this setting will result in that the current limitter is set to 5 Ampere.
You are right that not all types of powersupply is in the pulldown list, but what is important is that you select one with the same number of VA as the one you use.
This is true for the setting in a CS3, but for boosters it is more complicated, because boosters are still allowed to use a transformer or a powersupply.
For boosters it is also very important the type (transformer or powersupply) is set right, else there is a risk for that the CS3 reports an "over voltage" error.
Per
#11 Posted : 04 September 2025 17:11:20(UTC)
Hi Boris
The CS3 power settings are there to adjust the current limit on the CS3 so that, when a short is detected, the CS3 cuts off the power before the current surge is transmitted to the power supply (60101 for 5 A, 60045 for 3 A). Failure for the CS3 to switch off in good time, the power supply feeding the CS3 switchs off, causing the CS3 to cold-start after the thermal protection is waived off.
Märklin has produced so many power supplies that listing the references was a mistake (too many of them) but rather a power value (100 W, 60 W or the current value 5A, 3 A)
So, long speech to say you should select the 60045 if you have a 60 W PSU.
Offline BenP
#12 Posted : 04 September 2025 17:27:03(UTC)
BenP
Hi Boris
Make sure to adapt wiring for 5A to avoid heating hazard, which should be thicker than 3A standard gauge wires. I continue to use 22-24 gauge to track with 3A power supply, but thicker from CS to power hubs and decoders.
Ben
#13 Posted : 06 September 2025 06:20:48(UTC)
Boris Orloff
I have tried all the posts to date. My CS3+ still registers a short but it does not short out automatically. Is there a way to tell if the CS3 is defective or needs a factory reset?
Offline PerR
#14 Posted : 06 September 2025 11:34:12(UTC)
PerR
please try to read out the current when only the first feed is connected to the CS3.
Then disconnect the first feed, and connect the second feed, and read out the current.
If the sum of the current of these two readings is above 3 Ampere, then I guess that your layout has grown to a size where it is time to think about adding a booster.
If the sum of the current is below or far below 3 Ampere, then I guess that you should look for a fault in the wiring.
Per
NB: you can see the current in the GFP3 section under System.
thanks 2 users liked this useful post by PerR
#15 Posted : 06 September 2025 11:36:45(UTC)
Ho Boris
On my CS3 in the Track Format processor section there is a screen to select the power source model and you must be set to use the first line (60041, 60061) if as I understand you have a 60 W Märklin power supply.
Before you do a CS3 reset
The current-sensing is made by a small-value resistor and a voltage drop measure and you have two of these: the main track and the programming track. Chances that this device is failing are rather small.
Disconnect the track connectors on the CS3 and check the current measure, both measures should read zero. If not your CS3 has a hardware problem (likely not to be solved by a software reset or a program change
If you have (or can get) a power resistor (e.g.: 10 W 100Ω) you should be able to measure a current 100Ω gives you a reading of 0.18A
The CS3 reset procedure
Because it will erase all your records (track plans, devices,settings) it is best to make a back-up on an external memory (USB memory stick, plug-in sim card (I use 32 GByte one)
Once this is done, you select CS3/ restore and, among the files to be restored, one is called LEER.ZIP (Meaning empty in German). If you select this one, it will clear all previous setting BUT it will not erase all your previous recording (have to do this one by one manually.
Edited by user 06 September 2025 18:40:02(UTC)  | Reason: Not specified
#16 Posted : 07 September 2025 17:14:42(UTC)
Boris Orloff
Thanks for the advise.
Offline bgemski
#17 Posted : 01 October 2025 16:09:27(UTC)
bgemski
I'm a little late to the discussion here but I'll add in something that might have been overlooked. I had my CS3 hooked up working great, then I added a power center for extra outlets. that is where I started having issues. Turns out the power center was flaky. I in turn bought a new one and all the errors disappeared. So that being said how is your CS3 plugged in?
thanks 1 user liked this useful post by bgemski
Online rhfil
#18 Posted : 01 October 2025 19:43:17(UTC)
rhfil
I once had an electrical device which strangely did not come fully on but was fixed by reversing the two bladed plug in the socket.
#19 Posted : 03 December 2025 22:39:40(UTC)
Boris Orloff
I bought a new CS3 thinking it was defective. It wasn't, i got the same message- short on the main line.
I rewired the entire layout and it checks out fine with a volt meter.
When I connect any feeder to the tracks, it automatically shuts down.
I checked all the track for loose objects such as metal on the tracks and there are no problems.
Any ideas?
Online rhfil
#20 Posted : 03 December 2025 22:55:34(UTC)
rhfil
Simplify. Reduce the layout to only the feeder track. Then keep adding sections until you get the message again. If you have a short with just the feeder track replace it.
#21 Posted : 17 December 2025 05:28:54(UTC)
Boris Orloff
Does each of the feeds to the track need to be isolated from the other feeds?
Offline Copenhagen
#22 Posted : 17 December 2025 11:59:38(UTC)
Copenhagen
Sorry to hear about your ongoing problem. The method with one main power line under the layout and with feeder wires connected (correctly) to that line at various points/intervals is quite normal. At least when talking about a single power supply for the whole thing. This is what I do on my layout.
There must be something going on where you connect the feeder wires to the main bus. Or where you connect the feeders to the track?
Before I built this layout I used a couple of the feeder wires made by Marklin that were placed and hidden under the C track. The ones you place at certain intervals on the layout.
Online rhfil
#23 Posted : 17 December 2025 13:08:33(UTC)
rhfil
"Does each of the feeds to the track need to be isolated from the other feeds?"
Not if you have wired it correctly but doing so might make it easier to find a short.
#24 Posted : 17 December 2025 14:09:19(UTC)
All I can suggest is to check each feeder wire for correct polarity. Have you any other accessories, signals or or turnout decoders using track power feeds? If any one of them is connected in reverse polarity, they could cause a short.
Online rhfil
#25 Posted : 17 December 2025 14:37:11(UTC)
rhfil
Find some other way of powering the layout like a 9 volt battery and then using a multimeter set on dc voltage check the polarity of each of the feeds. If you have one wired incorrectly the polarity should be reversed. Might also show up on the track itself but not sure.
#26 Posted : 17 December 2025 18:43:39(UTC)
Boris Orloff
I had the entire layout on multiple feeds but I added a new loop about 20 lf and everything went bad from there. Now if I add a second feed anywhere on the layout, I get the same message that I overloaded the main loop. I will try isolating the new loop.
Offline Copenhagen
#27 Posted : 18 December 2025 00:03:46(UTC)
Copenhagen
Does this mean that everything works well with the new loop attached and that you can run trains on it without problems - as long as no new feeder wires are attached?
Edited by user 18 December 2025 17:08:15(UTC)  | Reason: Spelling
More CS3 problems ( not + version) (Digital)
by sudibarba 13/09/2018 05:36:07(UTC)
This page was generated in 0.767 seconds.
