Offline MikeO
#1 Posted : 16 June 2022 02:31:51(UTC)
MikeO
Hello Z Community - MikeO here... anyone know how to find out the minimum radius needed to run the Marklin 88634 Diesel and 87343 Passenger Cars? Thank you.
#2 Posted : 16 June 2022 15:55:11(UTC)
Hi Mike
Welcome to our great forum.
Z cars and locos are designed for track diameter as short as 290 mm. Their designs are tested with a little narrower diameters but it is safe not to go below this value.
Yes some short locos and cars may accept smaller diameters but you never know what you will purchase next so better stay within the standard. Usually try to avoid S-shaped arrangements with the narrower curves.
#3 Posted : 17 June 2022 09:28:49(UTC)
The minimum radius available from Märklin is 145 mm. I assume that all rolling stock will handle this radius unless the product specification in the catalogue or the manual gives other information.
The 81873 starter set comes with a BR 216 loco and three Popwagen coaches - and 195 mm radius curves. So I assume that 195 mm is safe for long coaches and longer locomotives.
My experience from H0 track is that avoiding small radii will reduce problems with some rolling stock, especially if you like long trains.
Edited by user 20 June 2022 09:23:56(UTC)  | Reason: Not specified
Offline Carim
#4 Posted : 17 June 2022 18:52:10(UTC)
Carim
Views messages in topic : 686
Hi Tom,
I am afraid that I have to disagree with you Blushing , in Z gauge the tightest radius curve made by Märklin is 145mm (8510).
Carim
Offline MikeO
#5 Posted : 17 June 2022 22:52:27(UTC)
MikeO
I should have mentioned I am using Rokuhan track R018 that has a 2.76 radius - very tight.
Trying to determine a wider radius to use (Rokuhan)... e.g. 145mm (5.70866") or 195mm (7.67717)......... 222mm (8.74016") is too wide for my Z layout.
I find it very surprising that Marklin does not document minimum radius for its engines and rolling stock!!!
#6 Posted : 20 June 2022 09:31:47(UTC)
Thanks. I stand corrected.
I should have known: They sometimes show a Z gauge layout on a 12" LP record. Blushing
I have no idea which radius is included with the starter set 81520. Is it 195 mm?
They expect you to go "all Märklin". With H0, they only specify a minimum radius for rolling stock that cannot handle the R0 industrial radius. I guess they use a similar approach for Z gauge.
You can use Märklin flextrack to go below the 145 mm radius, but that is just trial and error.
They completely ignore track from Rokuhan, Kato, or others.
The 81001 train set is one example where Märklin specify that it cannot be used on the 145 mm radius (restriction applies to the freight cars only).
Lsmodels and acme minimum radius help (H0-scale)
by danmarklinman 07/02/2021 12:31:07(UTC)
Minimum radius of parallel curves 57mm apart? (Track plans)
by scraigen 07/09/2018 18:52:13(UTC)
Does Anyone Know the Minimum Radius for Rivarossi Models? (Aln 668 Specifically) (H0-scale)
by 5HorizonsRR 22/03/2018 01:12:29(UTC)
Would you buy a Märklin loco with a minimum radius of 420 mm? (H0-scale)
by H0 16/01/2011 19:30:01(UTC)
Minimum radius for operation - 360" - For all locomotives? (H0-scale)
by AlexandrS 08/05/2010 00:08:35(UTC)
minimum radius for steamers (H0-scale)
by steamfriend 16/10/2004 16:23:56(UTC)
This page was generated in 0.453 seconds.
