2 Pages<12
Offline Copenhagen
#51 Posted : 18 November 2021 22:37:02(UTC)
Copenhagen
Maybe the headline should have been: Trick or Treat?
Any discussion that brings clarity to matters and have advice, tips, solutions etc is always welcome.
#52 Posted : 20 November 2021 11:35:20(UTC)
Here was me thinking this thread had finished. Just clean tracks and sliders on a regular basis and the trains keep running. They do on my layout anyway.
I thought it had died as well, but again, Goofy comes along with "i have seen ..." without providing a link to what he was watching, so we can only suppose there is insubstantiated information here.
True or False? The answer is Yes.
LOL
Just write in the Youtube by search Märklin clean dirt tracks and you see a lot of video tip!
LOL LOL LOL
Offline Copenhagen
#53 Posted : 20 November 2021 11:53:32(UTC)
Copenhagen
LOL
LOL LOL LOL
Okay. Went to youtube, typed in: Märklin clean dirt tracks -> top result Marklinofsweden: No more track cleaning - problem solved.
https://m.youtube.com/watch?v=0olM5Zq1zlY
He's a sensible Swede, lots of talk about the tracks, not about the studs or the pickup shoe. The final solution is at about 14:40: Run your trains often and use a wooden block!
Oh forgot some smileys. Here you go: LOL LOL LOL
Online dickinsonj
#54 Posted : 21 November 2021 01:37:54(UTC)
I have never had any contact issues between a slider and the pukos - just the wheels and rails. Your track would have to be filthy or never used for the pukos to be a problem IMO.
This discussion is basically pointless - how to fix a problem that doesn't normally exist.
Why am I not surprised?
#55 Posted : 21 November 2021 05:09:23(UTC)
Any metal with different components put together will cause problems, for instance you cant weld stainless steel and steel together without leaving a dark mark., your common problem is oxidation and humidity., none will happen if your layout is in a dry invironment.
another example is when I use ball bearings, the armature sits within the ball bearing and there is no movement and the inner and outer ball bearing is made of the same metal, the ball bearing its self sits within the motor block.
for instance some manufacturers use stainless steel pick up shoes which are not ideal with metal pukos., a,) stainless steel is not the prefered electrical conductor and it leaves arcing spots on the slider.,
I don't think this topic is pointless but the way it was created "true or false" leaves some questions about its true valuation.
I think one has to know or be aware what metal does when it comes into contact with air, salt water, moisture, humidity and other metal components.
Offline Legless
#56 Posted : 21 November 2021 09:18:19(UTC)
Legless
Maybe Goofy should test out gold and silver metal sliders and report which is the better conduit with the pucko’s.
Legless
thanks 2 users liked this useful post by Legless
#57 Posted : 21 November 2021 12:08:24(UTC)
I think he should try gold pukos, after all they are the items that are corroding ... Cool
#58 Posted : 21 November 2021 13:30:42(UTC)
does it have to be 9, 18 or 24 carrat gold ?
#59 Posted : 21 November 2021 21:31:12(UTC)
Okay. Went to youtube, typed in: Märklin clean dirt tracks -&gt; top result Marklinofsweden: No more track cleaning - problem solved.
That's just like Yin and Yang - Antimarklinofsweden and Marklinofsweden LOL
#60 Posted : 22 November 2021 12:14:13(UTC)
Administrators can lock threads, but they can also lock user. One way or other the issue will be resolved. Cool
Yep we can even though self appointed moderator Goofy says we can't, I assure everyone we can and I'm about to...
In fact...no they can´t......
I still don't think Goofy has given a proper link to what he is talking about, first it was Facebook, next it was Youtube soon it will be Twitter......
My response to that.....?? YouTwitFace!
I must apologise for prolonging eveyone's agony by not monitoring this thread sooner.
Thread is now locked.
thanks 5 users liked this useful post by Bigdaddynz
Guest (4)
2 Pages<12
This page was generated in 0.584 seconds.
