Offline Bondijohn
#1 Posted : 19 June 2021 04:34:19(UTC)
Bondijohn
I recently took delivery of the Marklin 37995 with the two steam loks. They’re not yet shown in “What’s arrived” as I’m having trouble loading the photographs of other recent deliveries but that is another matter.
The locomotive 37995- 02 was put onto the layout for a test run. I can run two locomotives on the layout using the CS 2, but when I started running either of the other two 37995-02 started on it’s own and at full speed. I had no control over the steamer. LOL
I haven’t opened her up yet but am hoping wiser heads may lead in the right directions. Confused
Kind regards,
#2 Posted : 19 June 2021 05:01:00(UTC)
Marklin 37995 is the weathered Big Boy 4014 from the years 2013-2014.
#3 Posted : 19 June 2021 05:06:07(UTC)
Hi John,
For a locomotive newly placed on a layout this is not an unusual occurrence.
For one of a number of reasons, the locomotive decoder does not recognise the there is a digital controller (in this case MS-2) in charge and is operating as an analogue (non-digital) on the full voltage.
I am not familiar with this locomotive set to know what sort of decoder is installed.
Depending on that information, other people may give you ananswer.
Is your locomotive a Union Pacific Big Boy?
#4 Posted : 19 June 2021 08:00:50(UTC)
At least the problem happened when connected to a controller. I would be much more worried if a locomotive started racing around when the track was not connected to a controller/power supply...
Unplug your controller and plug it in again. Hopefully it will recognize the locomotive.
You can try adding the locomotive from the database and see if it recognizes it then.
If not, confirm that your locomotive is the digital version and not an analog version.
If you have an analog transformer, connect a few track sections and power the locomotive for a few seconds and then place back on the digital track and hopefully it will be recognized then.
#5 Posted : 19 June 2021 13:44:07(UTC)
Kind regards,
At one point there was an update for the msd3 decoders because of this being a problem when a loco was first put on the track and would run off while the mfx identification was made. See my post over here ...
Online Rocca
#6 Posted : 19 June 2021 14:10:31(UTC)
Rocca
Hi, John,
Maybe it is just that you've toomuch lokos on the layout, so you could try to connect some tracks on the programming slot you find in the back of your CS2. The System would have to recognize the new loco directly.
Good Luck!!
Stefano
Kind regards,
#7 Posted : 19 June 2021 19:52:14(UTC)
The loco is an MFX one so it must register.
When for any reason the loco goes full speed, the registration may be more difficult (because of electrical noise by full speed circulation.
The solution?
I would try to install the loco upside-down on a foam bed and make a good electrical connection , then power up and give it time for registration.
Possibly activate the function "Find lost MFX locos" if after plenty more than one minute, no registration starts.
Patience is key as I noticed that Märklin has increased the sequence times for registration on latest s/w versions.
Now I use mostly a CS3 where the function search for lost MFX locos is very effective but takes time.
Of course I assume that MFX DCC, MM2 protocols are allowed at your CS2. Your loco is MFX and MM2 I believe.
Note: on multi protocol decoders and multi protocol Central Unit, you may have funny situations where the loco is programmed as DCC and the CS blocks DCC protocol. In this example, the loco receives power but no orders. That is why, when trying to "find" a new loco, all protocols must be allowed on your CS.
Good luck
Offline Bondijohn
#8 Posted : 22 June 2021 00:31:12(UTC)
Bondijohn
Thank you for your responses. I’ll have another try over the weekend and let you all know how I went.
Foumaro- my apologies. The set is a 37955, the locomotives are 37955-01 and 37955-02.
Kind regards,
thanks 1 user liked this useful post by Bondijohn
#9 Posted : 22 June 2021 07:54:19(UTC)
No need for apology.Maybe you can think about the possibility to change the decoders,if you can afford it.They are perfect and they deserve better electronics.You do not need to change the motors,so i think that is an easy conversion.
Enjoy your locos.ThumpUp
#10 Posted : 22 June 2021 09:00:16(UTC)
Some of these dirt-cheap decoders are faulty and will not return to speed step 0 after long periods without power (e.g. in the box).
Make sure to select the loco on the controller before placing it on the track.
Both locos from this set have the same default address. Change the address of one of those locos on the programming track ASAP.
If the set was bought second-hand and the address is not known, then this could be problem.
If the set was bought second-hand, then maybe check if the loco is really digital. The cheap locos from this set can be used to swap shells with older analogue locos.
Offline DasBert33
#11 Posted : 22 June 2021 13:03:48(UTC)
DasBert33
1. If you are not using analog operation, and the loco has a programmable decoder, disable analog operation in the decoder. Do the same for any other protocols that the decoder supports that you don't want to use. (had a similar issue with a Brawa V36) (program it using DCC cvs)
2. Check the voltage of the CS2. It is maybe on the low side, making the decoder think it is on an analog layout, getting it to start running. If you can slightly increase it, do so, however too high a voltage is not good for the capacitors on some decoders...
3. As said by Jean, disable unused protocols in the CS2 as well.
4. Check the wiring to the layout, make sure you have no power loss due to inadequate (=too thin, too few) wiring. This can lead to voltage drops, see 2. Also check that there is no forbidden electronics in between the CS2 output and the track, like suppression coils.
5. Change the address of the 'bad' locos. I still have an issue with an older BR03.10 (37911) where it responds to commands of switches when using motorola address '31'. Changing the address helped. (but it is only a workaround and no fix)
6. Consider replacing the decoder(s) if nothing above helps.
#12 Posted : 22 June 2021 13:22:20(UTC)
The dirt-cheap factory-installed decoder does not support anything beside MM protocol, and analogue mode cannot be disabled.
Offline DasBert33
#13 Posted : 22 June 2021 15:25:45(UTC)
DasBert33
In that case I would revert to option #6: change the decoder. It will also improve running a lot and fix the running-away issue.
I have replaced most of the 60760 decoders I had (I assume you are referring to similar decoders?) already.
#14 Posted : 22 June 2021 15:41:39(UTC)
It's a decoder with a 21MTC socket, but features are identical to the 60760 decoder. Usually works OK, but still a very basic decoder.
Offline owidgie
#15 Posted : 22 June 2021 22:41:14(UTC)
owidgie
Check that the red and brown wires aren't reversed in both the CS2 plug and track connections. This sometimes causes confusion in older decoders.
Rick
This page was generated in 0.686 seconds.
