Offline H5463
#1 Posted : 01 April 2021 14:08:41(UTC)
H5463
Looking for grease to oil the engine for the first time. It seems Trix 66626 is not good enough. Any suggestion? Thanks!
By the way, when is the best timing to oil? The introduction says every 40 hours of running. But some advise half year to avoid oiling too much.
Also, any suggestion of tools to open the loco without damaging the car cast?
Appreciated.
#2 Posted : 01 April 2021 14:22:43(UTC)
I use Fleischmann oil and Roco grease.
If you lubricate the loco, run it for one hour and store it for one year, then consider lubricating it again the next time you run it.
Worm drives make no sound when they run dry, so better inspect too often to avoid damages. Do not lube if you still see sufficient grease.
Which loco? Which gauge?
#3 Posted : 01 April 2021 14:24:12(UTC)
WHAT loco exactly do you want to open??? Each loco has its own story.
About oiling; Locos with worm-drives or gears of plastic needs "teflon-grease" or the likes, instead of oil.
About the interval; I don't use a specific plan (my bad), but rather oil on a hunch, and audio-visual hints from the actual running.
I tend to over-oil, as a lot of my engines are quite old and used, so later I have to go around scraping gunk off my wheels. Glare
Don't oil the outside running-gears (rods) on the steamers. Don´t oil brushes and coals. Don´t oil point-mechanisms.
#4 Posted : 01 April 2021 16:08:46(UTC)
What do you mean "not good enough" ?
Trix 66626 is not an oil, it is a grease for putting on worm gears and related areas.
Marklin has an oil, as does Faller and a number of other manufacturers, but any light oil like sewing machine oil will be suitable for oiling an armature or axles.
Offline H5463
#5 Posted : 01 April 2021 16:10:13(UTC)
H5463
I got Marklin and Roco H0 engines. Just purchased them for several months. I didn't run them more than 30 minutes a day. Should I worry about grease now? I don't know locos having their ways to open! I thought they are the same. Thanks for enlightening:)
#6 Posted : 01 April 2021 16:31:58(UTC)
AFAIK Roco locos should be lubed before first use. Märklin rolling stock should be lubed before first use.
Märklin locos tend to be extreme: dry as a bone or over-oiled and crying for degreasing. Better to check them if you are not sure.
Some have screw(s) at the bottom, some have screw(s) on top, some are clipped on, some are held by the buffers. Useful tricks to open them vary by model.
In rare cases the Märklin manual tells you the body is clipped on while it actually is held by a screw (certain models of BR 185.2).
Offline dickinsonj
#7 Posted : 01 April 2021 18:37:40(UTC)
Good advice. I have opened new Märklin locos with no grease on the worm gears, excess grease and in one case one dry worm gear and one which was heavily lubricated. So, I now check them all out before running because you never know exactly what you will find.
Online marklinist5999
#8 Posted : 01 April 2021 18:50:45(UTC)
Hetman by Musikworks in South River N.J. makes different viscosity clear synthetic olubricants. I got it on Amazon. I chose the medium bearing and linkage grade. It's great!
You don't need much, and it doesn't gob up and catch dirt. I got it for my grandfather clock, but use it on my locomotives too.
These are also used in musical instruments for the wind key's, and moving parts.
Offline bph
#9 Posted : 02 April 2021 19:37:39(UTC)
I would say that the Trix 66626 is good enough, but of course, there might be better alternatives.
It's nothing special about it, it's a very common industrial grease. (And overpriced)
The "Trix" grease are designed for:
Heavy duty bearings and general industrial lubrication. ·
Heavy duty plain and rolling element bearings operating
under harsh conditions including shock loading in wet
environments.
The maker states:
Outstanding Load Carrying Capacity
Improved Mechanical Stability
Oxidation Stability
Operating temperature range -20 0 C to +130 0 C.
And I assume Marklin has tested it to make sure it's safe to use with their plastic.
What you should be aware of is that if you change the grease type, and mix two types, you might get a chemical reaction. E.G it might harden.
So before you change to a different type of grease, make sure they are compatible or clan the gears completly.
#10 Posted : 02 April 2021 20:10:34(UTC)
Hi "H5463" (can we have a name/nickname?, always more comfortable) BigGrin
Most (all actually) Loco's come with a booklet or sheet which should show the method of opening it, and the recommended lubrication points.
If you have any Locos without this, just ask here, someone else will surely have it and can post it up so you can print off if you wish and keep on file.
HTH
Steve / Cookee
Offline tonyfh
#11 Posted : 03 April 2021 10:12:53(UTC)
tonyfh
Hello H5463,
My experience with lubricants:
Faller oil, I stay away from this, maybe they changed the formula because my experience is from several years ago but after storage (a year or so) my locos are stuck completely.
Märklin oil, no problems with that apart from the thick applicatornozzle that is a bit difficult to use in tight locations.
LGB oil, no problems, has a great thin applicator nozzle (already several years old so it may have changed now)
But for a US based person, why not use Labelle 108? it has a great thin applicator nozzle and works like a dream.
For grease, I don't have any experience with that because I mostly have old locos and don't run my modern ones very often, but why not use Labelle 106, it contains PTFE and is plastic compatible.
About the Labelle products, https://labelle-lubricants.com, it seems Model Railroader readers had good experience with them and they should be widely available in the US.
And about opening locos, as noted before, the best way to find out is reading the manual, they all open up different ways.
But most Märklins open up after removing one or more screws, sorry no experience with Roco locos .
Good luck with your maintenance work.
Tony.
thanks 2 users liked this useful post by tonyfh
Offline MalinAC
#12 Posted : 03 April 2021 12:47:15(UTC)
MalinAC
Ireland
I always use Labelle products and never had any problems with them Cool Cool
thanks 3 users liked this useful post by MalinAC
Offline H5463
#13 Posted : 04 April 2021 04:28:20(UTC)
H5463
Thank you all for the wonderful suggestions!
Edited by user 14 May 2021 14:40:29(UTC)  | Reason: Not specified
#14 Posted : 04 April 2021 07:02:17(UTC)
I have Marklin 36244 (BR 24), 26983(BR 112) and Roco 79817 (BLS 174).
36244 Manual here See pages 32 and 33
26983 Manual here See pages 24 - 29
No idea about the Roco manual, check the box it came in.
This page was generated in 0.593 seconds.
