Offline Vadim
#1 Posted : 01 April 2021 11:57:22(UTC)
Vadim
Russian Federation
Marklin 37621
Is it possible to Install sound decoder?
#2 Posted : 01 April 2021 13:30:01(UTC)
Yes. Some decoders accept add on sound decoders with pin connectors for plug on it ribbon cable connection. Some decoders can be changed by a fairly easy unplugging and or re soldering. Otherwise you gut the old decoder and start fresh like a total Digital conversion. It isn't terribly difficult.
Be sure to use a heat sink. Also be cautious if using solder flux. It can erode some plastics. Use heat shrink splice wraps where wires are tied together. Measure the headlight output voltage from the decoder to determine if resistors for flicker free less are needed. Some choose to add a buffer capacitor for track voltage variances for motor speed constant where tracks are dirty or have a weak connection. Roco includes them on AC models, Marklin doesn't. I think it is because 3 rail AC track has better conductivity.
In closing, don't be shocked if you fry a decoder. Most people have. Sometimes all it takes us a pinched wire between the frame and body, causing a short.
If you don't think you can tackle it, have a shop do it. If near St. Petersburg, there is at least one. I know of a young guy who Is very good at thus. He works at one, and the rail museum. His name is Anton.
#3 Posted : 01 April 2021 14:30:36(UTC)
Welcome to the forum!
Originally Posted by: Vadim Go to Quoted Post
Marklin 37621
Sure it is.
Now the loco has a special decoder with motor drivers for two motors.
New sound decoders only have a single motor output and you'd have to wire both motors in parallel. This won't make performance better.
Space should not be an issue and the motors are already DC motors, so with sufficient soldering skills installing a sound decoder is a simple task.
Marklin 60976 Diesel sound decoder install (Digital)
by Gerald Lynch Yesterday at 22:19:01(UTC)
Sound Decoder (H0-scale)
by Harvey 26/06/2025 15:13:31(UTC)
msd sound decoder (Digital)
by vupti 17/11/2024 14:19:09(UTC)
Problem with Piko sound decoder 5.1 (Digital)
by Goofy 24/08/2024 07:36:38(UTC)
Marklin sound decoder bootloader/firmware update (60977) (Digital)
by dlwestphalen 08/08/2023 03:02:32(UTC)
Installing MSD3 Sound Decoder in SBB Ae 8/14 (Märklin 37593) (Digital)
by Johnvr 24/02/2023 07:46:31(UTC)
Sound decoder problems (Digital)
by Charles Farrugia 26/11/2022 16:58:44(UTC)
Conversion of the snow plow with recent loksound decoder (Digital)
by French_Fabrice 20/11/2022 18:16:17(UTC)
Which High efficiency motor retrift kit and sound decoder for Marklin ho br 218 diesel? (Digital)
by marklinist5999 21/02/2022 14:31:47(UTC)
Connecting a Jagerndorfer ho cable car set with an ESU 56002 sound decoder to a CS3 from track power (Digital)
by marklinist5999 03/01/2022 20:36:33(UTC)
ESU sound decoder instructions (H0-scale)
by river6109 07/12/2021 11:36:41(UTC)
Märklin 55741 Köf II Sound decoder (Big scale)
by pa-pauls 10/03/2021 21:53:42(UTC)
Sound decoder (H0-scale)
by gbrendem 05/02/2021 14:26:03(UTC)
A slight night mare programming a Zimo sound decoder (Digital)
by river6109 21/10/2020 04:09:12(UTC)
Problem with sound decoders 60975, 60976, 60977 (Digital)
by Best Ripper 17/09/2020 21:11:02(UTC)
Marklin Br24 sound decoder dead (H0-scale)
by fossie 08/06/2020 14:53:12(UTC)
Mfx Sound decoders having random ANNOYING issues (Digital)
by Martin T 02/04/2020 22:27:32(UTC)
CS3 sound decoder update.. Missing files (Digital)
by Nick_40034 25/02/2019 00:34:12(UTC)
60987 sound decoder problems. (Digital)
by Nonno FULVIO 11/01/2019 17:41:57(UTC)
Smoke Unit with ESU Loksound Decoder (H0-scale)
by skeeterbuck 20/12/2018 03:26:34(UTC)
4 AUX sound decoder (Digital)
by Nick2017 07/08/2018 20:20:46(UTC)
Sound Decoder (Digital)
by skeeterbuck 02/06/2018 00:01:46(UTC)
Has anyone had a problem with a Marklin sound decoder (Digital)
by dominator 30/04/2018 06:41:13(UTC)
Sound Decoder for Marklin 5579 (Big scale)
by Jaime 13/04/2018 02:23:40(UTC)
OBB 1116 - Sound Decoder (H0-scale)
by kganotop 09/04/2018 21:40:57(UTC)
sound decoders (Digital)
by river6109 20/07/2017 04:01:09(UTC)
Märklin sound decoder (Digital)
by river6109 07/03/2017 09:35:44(UTC)
Programming / Uploading sound scenes / files into ESU LokSound decoders (Digital)
by Minok 01/03/2017 00:06:32(UTC)
English Tutorial re Sound Project for mSD/3 Sound Decoder/Programming (Digital)
by Malcolm Smith 12/01/2017 02:26:31(UTC)
37184 Sound Decoder Issue (Digital)
by mb300e4m 12/12/2016 01:50:46(UTC)
Piko 96225 AC and Marklin MFX sound decoder help (H0-scale)
by danmarklinman 18/10/2016 20:22:16(UTC)
Reset Sound decoder on 39016 BR 01 (Digital)
by trainsman2001 18/05/2016 21:06:18(UTC)
Sound decoder problem (Digital)
by Inox 20/07/2015 23:33:29(UTC)
Märklin V80 (36080) Sound Decoder conversion (with Video) (H0-scale)
by Moritz-BR365 09/07/2015 08:26:52(UTC)
VT11.5 with dual sound decoders (H0-scale)
by biedmatt 27/06/2015 14:13:54(UTC)
ESU LokSound Decoder - English Instruction Booklet?? (Digital)
by Joseph Meiring 23/06/2015 21:29:22(UTC)
Märklin Ludmilla BR 232 now with Doehler&Haass Sound Decoder - Matthias Henning sound (with video!) (H0-scale)
by Moritz-BR365 03/06/2015 08:41:49(UTC)
ESU Loksound decoders for "old" V200 diesel 3021? (Digital)
by Joseph Meiring 31/05/2015 19:38:57(UTC)
Zimo sound decoder and Marklin Mobile Station 2 (Digital)
by Unholz 29/05/2015 14:45:38(UTC)
What Loksound Decoder Is This? (Digital)
by trainstamp 30/04/2015 16:04:14(UTC)
ESU Loksound Decoder (Digital)
by ice 1 21/01/2015 13:35:54(UTC)
Sound decoders in 3309 BR85? (Digital)
by Joseph Meiring 22/10/2014 23:19:56(UTC)
suitable sound decoder for Roco BLS Ae 6/8 (Digital)
by river6109 07/06/2014 10:50:39(UTC)
With or without sound decoder (Digital)
by Goofy 05/06/2014 18:28:24(UTC)
Sound decoders for loco's (Digital)
by Shamu 01/04/2014 07:36:32(UTC)
Sound decoder for Märklin Ludmilla (Digital)
by Hackcell 07/02/2014 17:40:46(UTC)
Roco ESU M4 sound decoder? (Digital)
by Goofy 06/01/2014 12:12:32(UTC)
ESU M4 sound decoder and 3 pole motor (Digital)
by Goofy 06/01/2014 11:36:47(UTC)
Have you ever been frustrated from a loco with sound decoder and noisy motor? (H0-scale)
by H0 12/12/2013 09:35:34(UTC)
ESU or Marklin Sound Decoder (Digital)
by camcath 04/10/2013 23:17:32(UTC)
This page was generated in 0.433 seconds.
